Python Plugin: Samsung TV
psychomaniac
Re: Python Plugin: Samsung TV
Post by psychomaniac »
alright, i managed to upgrade websocket, i also had to update setuptools... looks like i have to update everything, has something to do with Volumio image i guess. I also updatet websocket-client but unfortunately, that also doesn't work. It looks like this isn't the sollution, i still get the same error, see the spoiler for the output. Does anyone have an idea how to solve this one?
volumio@volumio:/$ samsungctl -i --host 192.168.0.123 --method websocket
File "/usr/local/bin/samsungctl", line 9, in <module>
load_entry_point('samsungctl==0.7.1', 'console_scripts', 'samsungctl')()
File "/usr/lib/python3.4/samsungctl/__main__.py", line 110, in main
with Remote(config) as remote:
File "/usr/lib/python3.4/samsungctl/remote.py", line 11, in __init__
self.remote = RemoteWebsocket(config)
File "/usr/lib/python3.4/samsungctl/remote_websocket.py", line 30, in __init__
self._read_response()
File "/usr/lib/python3.4/samsungctl/remote_websocket.py", line 67, in _read_response
response = self.connection.recv()
File "/usr/lib/python3.4/websocket/_core.py", line 310, in recv
opcode, data = self.recv_data()
File "/usr/lib/python3.4/websocket/_core.py", line 327, in recv_data
opcode, frame = self.recv_data_frame(control_frame)
File "/usr/lib/python3.4/websocket/_core.py", line 340, in recv_data_frame
frame = self.recv_frame()
File "/usr/lib/python3.4/websocket/_core.py", line 374, in recv_frame
return self.frame_buffer.recv_frame()
File "/usr/lib/python3.4/websocket/_abnf.py", line 383, in recv_frame
frame.validate(self.skip_utf8_validation)
File "/usr/lib/python3.4/websocket/_abnf.py", line 182, in validate
raise WebSocketProtocolException("Invalid close opcode.")
websocket._exceptions.WebSocketProtocolException: Invalid close opcode.
psychomaniac
Meanwhile I used another Pi image, Raspbian and updated fully. But the samsungctl script still doesn't work. I still get the following:
pi@raspberrypi:/usr/local/bin $ samsungctl -i --host 192.168.0.127 --method websocket
File "/usr/local/bin/samsungctl", line 11, in <module>
sys.exit(main())
File "/usr/lib/python3.5/samsungctl/__main__.py", line 110, in main
File "/usr/lib/python3.5/samsungctl/remote.py", line 11, in __init__
File "/usr/lib/python3.5/samsungctl/remote_websocket.py", line 30, in __init__
File "/usr/lib/python3.5/samsungctl/remote_websocket.py", line 67, in _read_response
File "/home/pi/.local/lib/python3.5/site-packages/websocket/_core.py", line 310, in recv
File "/home/pi/.local/lib/python3.5/site-packages/websocket/_core.py", line 327, in recv_data
File "/home/pi/.local/lib/python3.5/site-packages/websocket/_core.py", line 340, in recv_data_frame
File "/home/pi/.local/lib/python3.5/site-packages/websocket/_core.py", line 374, in recv_frame
File "/home/pi/.local/lib/python3.5/site-packages/websocket/_abnf.py", line 383, in recv_frame
File "/home/pi/.local/lib/python3.5/site-packages/websocket/_abnf.py", line 182, in validate
Does anyone know what this means? I'm don't even know what Invalid close opcode means.
Hope someone would help me with this :).
psychomaniac
On Github there is a thread about this:
https://github.com/kdschlosser/samsungctl/issues/2
Looks like samsung did some adjustments in it's latest firmware. It uses tokens now to communicate. Couple of devs are trying to fix this in the last month.
dextm80
Domoticz version: 4.10159
Post by dextm80 »
2018-11-30 22:36:27.244 Error: Samsung 65ks7000 hardware (4) thread seems to have ended unexpectedly
....for more and more time
anyone that get this issue?
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
kdschlosser
Post by kdschlosser »
I am the developer working on the issue... the link that @psychomaniac posted... it is actually solved just ironing out the last bit of it. The whole samsungctl library has been worked over.
it now supports an easy to use Config class.
it also supports automatic discovery of any TV.
it supports more then one TV.
list installed applications (2016+)
start applications (2016+)(< 2014 you have to know the app id)
get the status of an application (2016+)
change the TV source (direct)(< 2014) (possibly <=2015).
change the source label(< 2014)(possibly <=2015)
get the source(< 2014)(possibly <=2015)
get the plugged state of the source(< 2014)(possibly <=2015)
change the channel (direct)(< 2014)(possibly <=2015)
get the channel(< 2014)(possibly <=2015)
get channel meta data(< 2014)(possibly <=2015)
change the channel label(< 2014)(possibly <=2015)
get the volume(all)
set the volume(all)
get mute(all)
set mute (not toggle)(all)
get the brightness(< 2014)(possibly <=2015)
set the brightness(< 2014)(possibly <=2015)
get the contrast(< 2014)(possibly <=2015)
set the contrast(< 2014)(possibly <=2015)
get the color temp(< 2014)(possibly <=2015)
set the color temp(< 2014)(possibly <=2015)
get the sharpness(< 2014)(possibly <=2015)
set the sharpness(< 2014)(possibly <=2015)
get aspect ratio(2016+)
set aspect ratio(2016+)
zoom control(2016+)
track number(all)
track duration(all)
track metadata(all)
track uri(all)
relative play time(all)
absolute play time(all)
relative play count(all)
absolute play count(all)
number of tracks(all)
media duration(all)
current uri(all)
current uri metadata(all)
next uri(all)
next uri metadata(all)
play medium(all)
record medium(all)
write status(all)
power on (2016+)
seek(all)
play speeds(all)
display onscreen messages (???)
open browser with url (< 2014) (2016+)
mouse functions moving, left click right click (2016+)
and all of the metrics you can think of.
frame TV support
TV voice recognition support
remote touch pad support
panel size
resolution
mfg year
series
panel technology (QLED, LED, Plasma, LCD, DLP, OLED)
network type
wifi mac address
operating system
mfg region
tuner count
dtv support
pvr support
and that is just to name a few.
and probably the biggest feature. it is now extremely easy to get notifications for volume changing, channel changing, source changing, power state.
almost anything listed above
the library is now python 2.7+ compatible
I am not sure what features are available for the 2014 (H) and 2015 (J) years yet. I have not had anyone test this. But the library now does support those funky AES/Rijndael encrypted websocket connections.
what I do need is some people willing to test. people that has a grasp of python and also how to provide the correct information so I can debug this thing. I only own a pre 2014 model so I am not able to test the websocket end of thing. The "legacy" works like a charm.
kdschlosser
opcode = Operation Code. these are codes that are used to identify the type of websocket communication that is taking place. whether it be closing the connection. or an ack packet. a ping. there is a different code for the various types of data that is being sent or received. the Samsung TV is closing the connection with an opcode that is not known to the websocket-client library. hence the error
dextm80
Post by dextm80 »
how can i update it?
1x Fibaro Wall Plug
Philips Hue Bridge
kdschlosser
this plugin does not use the samsungctl library i do not believe. The author of the plugin would have to take a look and see what they can do with samsungctl of they wanted to have this plugin use it. if you are not familiar with python it is a little bit involved to explain it to ya.
bimedana
Post by bimedana »
Looks like websocket isn't upgraded. So i tried that but that also fails.
kdschlosser
ok I have a working fix for the websocket issue. If someone wants to update this plugin they can either use my code as a whole or they can take the bits a pieces to make this one work. I have not finished up with the rest of the additions just yet. I am still ironing the kinks out of it. But the websocket portion works fine
Here is is.
zak45
Domoticz version: V2024.4
Post by zak45 »
kdschlosser wrote: Saturday 22 December 2018 16:19 ok I have a working fix for the websocket issue. If someone wants to update this plugin they can either use my code as a whole or they can take the bits a pieces to make this one work. I have not finished up with the rest of the additions just yet. I am still ironing the kinks out of it. But the websocket portion works fine
Here is is.
Will give it a try, thanks
mark.sellwood
Post by mark.sellwood »
I tried this out yesterday and see the following:-
pi@SPARE-PI:~ $ samsungctl --host 192.168.1.66 --method websocket --name myremote KEY_VOLDOWN
error from callback <bound method RemoteWebsocket.on_open of <samsungctl.remote_websocket.RemoteWebsocket object at 0xb6212a10>>: on_open() missing 1 required positional argument: 'ws'
error from callback <bound method RemoteWebsocket.on_message of <samsungctl.remote_websocket.RemoteWebsocket object at 0xb6212a10>>: on_message() missing 1 required positional argument: 'message'
load_entry_point('samsungctl==0.8.0b0', 'console_scripts', 'samsungctl')()
File "/usr/local/lib/python3.4/dist-packages/samsungctl-0.8.0b0-py3.4.egg/samsungctl/__main__.py", line 181, in main
File "/usr/local/lib/python3.4/dist-packages/samsungctl-0.8.0b0-py3.4.egg/samsungctl/remote.py", line 13, in __init__
File "/usr/local/lib/python3.4/dist-packages/samsungctl-0.8.0b0-py3.4.egg/samsungctl/remote_websocket.py", line 50, in __init__
self.open()
File "/usr/local/lib/python3.4/dist-packages/samsungctl-0.8.0b0-py3.4.egg/samsungctl/remote_websocket.py", line 127, in open
raise RuntimeError('Connection Failure')
RuntimeError: Connection Failure
Am I missing something?
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Dim33
Post by Dim33 »
dd@ubuntu:~$ samsungctl -i --host 192.168.1.48
  File "/home/dd/.local/bin/samsungctl", line 10, in <module>
    sys.exit(main())
  File "/home/dd/.local/lib/python3.7/site-packages/samsungctl/__main__.py", line 102, in main
    config = _read_config()
  File "/home/dd/.local/lib/python3.7/site-packages/samsungctl/__main__.py", line 38, in _read_config
    config_file = open(path)
PermissionError: [Errno 13] Permission denied: '/home/dd/.config/samsungctl.conf'
What's the problem ?
Thanks for your help.
Jazzle
Post by Jazzle »
Trying to get the kdschlosser version from Github working for months now, though am now really stuck with 2 issues at this moment.
I have installed all prerequisites correctly as it seems except for "curses".
- In the hardware tab, samsung tv still is not available, no clue how to get this there
- when trying to connect to the tv first time, by sending the command samsungctl --host 192.168.1.100 --config-file "/PATH/FILE.NAME" KEY_MENU
do i refer to the samsungctl.conf file? as i read it this is not necessary though.
I have tried both options but get the notification " unrecognized arguments"
What am i doing wrong?
erasor2010
Post by erasor2010 »
i have a problem with the samsung plugin, it cant be loaded by domoticz
2020-01-24 09:14:51.832 Error: (SamsungTV) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/SamsungTV/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-01-24 09:14:51.832 Error: (TV-Bad) Module Import failed, exception: 'ModuleNotFoundError'
2020-01-24 09:14:51.832 Error: (TV-Bad) Module Import failed: ' Name: samsungctl'
2020-01-24 09:14:51.832 Error: (TV-Bad) Error Line details not available
python 3.7 is my standard version
python --version
Python 3.7.3
i can use the samsungctl on command line with
samsungctl -i --host xx.xx.xx.xx
can someone help me
radzik
Samsung UE55MU6102 doesn't work :-(
Post by radzik »
My configuration is Windows 10, 64-bit and tv Samsung model UE55MU6102 .
All logs are clear. All components including samsungctl (samsungctl 0.8.0b) and websocket-client correctly installed.
Unfortunately, after a few hours of struggle I gave up, none of the commands work and no message is displayed on TV :-(
Help please!
I'm trying to send different commands to the TV, but nothing happens :-( just a message:
For command:
samsungctl --method legacy --host 192.168.1.2 --port 8001 -v KEY_MUTE
File "C:\Program Files (x86)\Python38-32\lib\site-packages\samsungctl-0.8.0b0-py3.8.egg\samsungctl\remote_legacy.py", line 76, in open
self.sock.connect((self.config.host, self.config.port))
ConnectionRefusedError: [WinError 10061] Nie można nawiązać połączenia, ponieważ komputer docelowy aktywnie go odmawia
During handling of the above exception, another exception occurred:
File "C:\Program Files (x86)\Python38-32\Scripts\samsungctl-script.py", line 11, in <module>
File "C:\Program Files (x86)\Python38-32\lib\site-packages\samsungctl-0.8.0b0-py3.8.egg\samsungctl\__main__.py", line 355, in main
File "C:\Program Files (x86)\Python38-32\lib\site-packages\samsungctl-0.8.0b0-py3.8.egg\samsungctl\remote.py", line 67, in __enter__
self.open()
File "C:\Program Files (x86)\Python38-32\lib\site-packages\samsungctl-0.8.0b0-py3.8.egg\samsungctl\utils.py", line 24, in wrapper
return func(*args, **kwargs)
File "C:\Program Files (x86)\Python38-32\lib\site-packages\samsungctl-0.8.0b0-py3.8.egg\samsungctl\remote_legacy.py", line 79, in open
raise RuntimeError('Unable to pair with TV.. Is the TV on?!?')
RuntimeError: Unable to pair with TV.. Is the TV on?!?
in this way:
samsungctl --method websocket --host 192.168.1.2 --port 8001 -v KEY_MUTE
command line doesn't respond and freezing :-(
Somebody can help me.
Thank you in advance.
kniazio
Domoticz version: 3.7243
Post by kniazio »
Pawcio wrote: Saturday 03 November 2018 23:10 Ok,
it means that samsung has slightly different protocol on different TV models which are communicating over ws.
Version from the Oct 31, waits for the ""ms.channel.connect" json response before keys processing (it wasn't present in the previous one).
Mark, could you turn on debugs and sends me logs? I'll check whats going on.
In the mean time please find the first plugin version with power off functionality added.
I hope it will work this time for you.
After installing your plugin, only two input and power on devices added to me
I can turn on the TV when it is turned off by the remote control but I can't turn it off. The Input button does not work at all
