This is the behaviour of domoticz. Cannot be modified by a plugin.iTDB wrote: Sunday 05 April 2020 21:21 It looks like you need to set the Timer to 60 sec, otherwise you will get next error every minuteIs there a way to set that to 1 or 2 hours without this error.Error: IP Checker hardware (Idx) thread seems to have ended unexpectedly
Python Plugin: Wan IP Checker
- ycahome
- Domoticz version: lat Beta
Re: Python Plugin: Wan IP Checker
https://www.youtube.com/siakavelisgr
Bob123bob
I made a pull request that fix this issue https://github.com/ycahome/WAN-IP-CHECKER/pull/2
Check changes here : https://github.com/ycahome/WAN-IP-CHECKER/pull/2/files
or
Use my fork instead at https://github.com/gilmrt/Domoticz-WAN- ... ker-Plugin
or
Wait for pull request to be merged and update
The issue was the heartbeat run only at poll interval and must run less that every 30s
I applied recommandations
or
or
Warning: Setting this interval to greater than 30 seconds will cause a 'thread seems to have ended unexpectedly' message to be written to the log file every 30 seconds. The plugin will function correctly but this message can not be suppressed because it is a standard warning from Domoticz that a piece of hardware may have stopped responding.
If a plugin wants to heartbeat every 100 seconds it should be coded with the heartbeat interval set to 10, 20 or 25 seconds and only take action every 6th, 5th or 4th time the callback is invoked.
- ycahome
Bob123bob wrote: Saturday 02 May 2020 14:38 I made a pull request that fix this issue https://github.com/ycahome/WAN-IP-CHECKER/pull/2
Your Pull Request has been merged. regards.
Current version:
v.1.2.6 : Fix (by gilmrt) for "Error: IP WAN hardware (XX) thread seems to have ended unexpectedly"
pe1ago
Re: Plugin - Wan IP Checker
Same question here. Is there already a solution to send a Telegram message?andi216 wrote: Wednesday 30 August 2017 16:37 Hello
How can I send a notification to the Telegram if it changes wan ip?
(A simple method ... I'm not a programmer)
- ycahome
I didn't had the chance to test it but, I think that if you set telegram's settings at Setup/Settings/Notifications/Telegram and enable Notifications on th plugin, you will get a notification for every WAN ip change. I personally receive it by email.
Actually, plugin uses Domoticz's notification settings.
regards,
pe1ago
First Thanks. That works but it will not sent the new WAN ip address only a change message.
I like to get the IP so I now how to get back into domoticz without the need for a DDNS.
Any chance?
Any chance?
- ycahome
Hello,pe1ago wrote: Thursday 11 November 2021 15:12 First Thanks. That works but it will not sent the new WAN ip address only a change message.
Any chance?![]()
what this plugin is designed to do (with "notify" enabled) is to send an email with:
- subject "WAN-IP-Changed"
-body the new WAN IP address.
can you post here what you receive?
pe1ago
I have personal reasons not to work with email on Domoticz, al do it works that way.
I love to receive a telegram with the new IP. If possible of coarse.
- ycahome
You have sent 4 posts to this forum.pe1ago wrote: Thursday 11 November 2021 16:19 I have personal reasons not to work with email on Domoticz, al do it works that way.
in 1 of them you mention that the message you get "not contains the WAN IP"
on another you say that you don't want to use email but telegram.
cannot imagine what are the other two posts
Maybe you can try to search awhile before you post.
Start with some tests to see how notification system of Domoticz really works (its only 4 posts above after all)
Hesmink
Is there any way to force the checker to request only for ipv4?
I now get an ipv6 address from https://ifconfig.me/ip
Hesmink
To answer my own question: https://ipv4.icanhazip.comHesmink wrote: Friday 19 January 2024 20:42 Is there any way to force the checker to request only for ipv4?
lost
Not using this plugin, but from a lua time script that checks for changes periodically (stores them in a user var & if changed sends a mail with info+access links or at least once a week) I use theses URLs to get both:
https://api.ipify.org
https://api64.ipify.org
IPv6 can also be retrieved direcly from machine interface /sbin/ifconfig or similar tool as this one is global, but using external URLs allows checking true connectivity is OK & make both checks the same. IPv6 should almost never change are providers prefixes are not.
IMO, that's useful to get both: Already being compelled to use some hot-spots AP that were not under my control (hotels etc, especially in foreign countries where mobile phone network could also not be used) with no more available DHCP leases for hours due to heavy use by many people: So no IPv4 connectivity. But ipV6, addressing being global, could be used and having the address needed as in such case DNS may also be affected by lack of IPv4 (external port filtered in AP configuration), so no domain usable.
=> My advice: Don't choose, get both & in a way that may be used offline if needed (mail client that keep already loaded messages locally)!
Hi guys. This method does`t work anymore?
viewtopic.php?t=14489&sid=03c00c6ca0ceb ... 1dc0c1cc57
Fredom
- Domoticz version: 2026.3
This wan works for me for years nowCdzn wrote: Friday 22 November 2024 11:49 Hi guys. This method does`t work anymore?
timer = { 'every 1 minutes' }
logging = {
level = domoticz.LOG_FORCE,
marker = '[WAN IP]'
execute = function(dz, devNil)
local dzb = dz.LOG_FORCE
local getIp = 'curl -s http://whatismyip.akamai.com/'
local tmpFile = '/home/your name/domoticz/scripts/wanip.txt'
local actIp = ''
local devIp = dz.devices('WAN IP')
local currIp = devIp.text
os.execute(getIp..' > '..tmpFile)
actIp = io.open(tmpFile):read()
if actIp == nil then
actIp = 'Cannot retrieve WAN IP'
if actIp ~= currIp then
msgTxt = 'WAN IP has changed: '..currIp..' ==> '..actIp
dz.log(msgTxt, dzb)
dz.notify('WAN IP', msgTxt, dz.PRIORITY_EMERGENCY)
devIp.updateText(actIp)
os.execute('rm '..tmpFile)
dz.log('No change in WAN IP', dzb)
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
Fred
- dyter
- Domoticz version: 8841
I create a device "Ping Internet" for alert if internet down or wan changed
if devicechanged['Ping Internet'] then
time = os.date("%H:%M")
if devicechanged['Ping Internet'] == 'On' then
commandArray['SendNotification']= 'Internet maison rétablit à '..time..'#####telegram'
local function get_ip(url)
local result = (io.popen('curl -m 1 -s ' .. url):read("*a")):match("%d+%.%d+%.%d+%.%d+")
return result
ipwan = get_ip('https://api.ipify.org') or get_ip('https://icanhazip.com') or get_ip('https://ifconfig.me')
print(ipwan or "Erreur")
if ipwan ~= uservariables["ipwan"] then
commandArray['Variable:ipwan']= ipwan
commandArray['SendNotification']= 'Attention adresse WAN changée: '..ipwan..'#####telegram'
if otherdevices['Escaliers'] == 'On' then
commandArray['Escaliers']='Off'
elseif devicechanged['Ping Internet'] == 'Off' then
if (time < '08:00' or time > '19:00') and otherdevices['Alarme'] == "En service" then
commandArray['Escaliers']='On'
Domoticz v2024.1 on Synology Docker host, RFLink, ESPEasy wemos D1, Ecodevices, relays x8, dahua doorbell, reolink cameras ....
- sincze
- Domoticz version: 2024.4
Thanks that helpedHesmink wrote: Friday 19 January 2024 20:48To answer my own question: https://ipv4.icanhazip.comHesmink wrote: Friday 19 January 2024 20:42 Is there any way to force the checker to request only for ipv4?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
