Page 9 of 20
Re: Buienradar Weather Lookup Plugin
Posted: Thursday 01 June 2017 16:17
by Snowtiger
Snowtiger wrote:Update Domoticz Bèta 3.7602 - Buienradar (Weather Lookup) Type in Hardware types is missing and no actual information is delivered anymore by the Plugin.
Somebody else with the same experience?
I submitted an issue in Github - it has to do with changes in the Python system used for the newest Domoticz Bèta
Posted: Thursday 01 June 2017 16:33
by ffes
Snowtiger wrote:Snowtiger wrote:Update Domoticz Bèta 3.7602 - Buienradar (Weather Lookup) Type in Hardware types is missing and no actual information is delivered anymore by the Plugin.
I've seen the issue on GitHub. From the top of my head, the changes that are mention in "advance warning" are not used by my plugin, so I need to dive in to see what goes wrong.
Posted: Thursday 01 June 2017 16:55
by mivo
same problem with my own plugin - prebuilt beta binary tarballs are compiled without Python suport - from v3.7602 hash f39f21d.
viewtopic.php?f=6&t=17778#p136671
Posted: Friday 02 June 2017 10:15
by assenzuid
After the Domoticz Beta 3.7602 the plugin has stop working.
Posted: Friday 02 June 2017 23:15
by ffes
After a short investigation I also noticed that the plugins are disabled at the moment in the master branch and in the downloadable beta release. It is mentioned in many other posts in this forum as well. So it is up to the devs of domoticz to fix the issue and enable Python plugins again. When I build domoticz myself and enable Python plugins the Buienradar plugin just work.
Posted: Wednesday 07 June 2017 15:22
by differentieel
thank for doing this job for us - - works like charm - - but only in the DEV version
Posted: Wednesday 07 June 2017 16:18
by assenzuid
update to v3.7686 beta and the plugin is working again.
Posted: Wednesday 07 June 2017 19:58
by Brutus
assenzuid wrote:update to v3.7686 beta and the plugin is working again.
After installing this version my Domoticz keeps crashing at booting...
Windows 10 v3.7686
Buienradar.nl plugin,
Kodi Plugin 1.7.0 (Disabled)
It think the Buienradar plugin needs to be updated because of the new phyton interface?
Posted: Wednesday 07 June 2017 19:59
by assenzuid
Mine is also not running stable, web interface stops working
Posted: Wednesday 07 June 2017 22:21
by Snowtiger
Buienradar is working again at Bèta 3.7686, for flooding log file see -
http://www.domoticz.com/forum/viewtopic ... 20#p136763 or just remove the files, the demo files mentioned in the post are already present.
Posted: Saturday 17 June 2017 11:04
by Harald777
On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
Hope to see this fixed in the near future.
Posted: Sunday 18 June 2017 14:09
by Snowtiger
Harald777 wrote:On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any more
Posted: Sunday 18 June 2017 17:18
by Harald777
Snowtiger wrote:Harald777 wrote:On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
Thanks for the info, updating now.
Hope the issue are solved and indeed I have been reading that it is python related.
Posted: Sunday 18 June 2017 17:55
by Snowtiger
Harald777 wrote:Snowtiger wrote:Harald777 wrote:On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
to be precise - the problems where Python related but in the new Domoticz events system - had nothing to do with Buienradar plugin
Posted: Sunday 18 June 2017 22:24
by Harald777
Snowtiger wrote:Harald777 wrote:Snowtiger wrote:update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any more
Yes I know. Hope to see this fixed soon. Really love this plugin but for now i switched of the plugins completely. Just had another Domoticz crash on latest beta. Two crashes a day is too much.
Verstuurd vanaf mijn Nexus 5X met Tapatalk
Posted: Tuesday 20 June 2017 21:54
by Harald777
Is someone running this plugin stable? I am still getting domoticz shut downs 3 times a day when I use this "python" plugin. Only renaming my plugin folder solves the issue.
Perhaps a new and fresh domoticz installation solves the problem?????
Verstuurd vanaf mijn Nexus 9 met Tapatalk
Posted: Friday 23 June 2017 14:02
by ffes
Some major work has been done on the python plugins in Domoticz recently. Not sure how stable it is at the moment. My Domotics at home is not running as it should be (problem with my hardware), so I can only test a little.
Posted: Friday 23 June 2017 20:23
by Harald777
ffes wrote:Some major work has been done on the python plugins in Domoticz recently. Not sure how stable it is at the moment. My Domotics at home is not running as it should be (problem with my hardware), so I can only test a little.
Hope to see this plugin working again in the near future.
Today updated my pi, including all installed packages.
Activated the Buienradar plugin and unfortunately within a few hours Domoticz was offline again.
Posted: Thursday 06 July 2017 20:19
by Brutus
Is it possible to include the "Solar Irradiance" and "Visibility" ?
They come visible at the log but not as a device.
Posted: Monday 21 August 2017 23:58
by G3rard
I have made some updates to the Buienradar script of @ffes.
Added the following devices (data from xml.buienradar.nl):
* Visibility
* Solar radiation
* Rain rate
* Weather forecast
* Rain forecast (uses data from
https://gps.buienradar.nl/getrr.php?lat=51&lon=3)
Check
this Dutch site for more information on the rain forecast.
I have made a pull request for this and hopefully it will be merged
- devices.png (111.54 KiB) Viewed 3770 times
