Page 9 of 9
Re: Python plugin: Sonos
Posted: Tuesday 27 June 2017 13:08
by tester22
Dnpwwo wrote:@rathmannm,
I'm not sure this is a Python plugin issue because the log shows that the plugin is not loaded.
2017-06-24 08:44:26.347 Error: (Sonos) failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-06-24 08:44:26.347 Error: (Sonos Livingroom) Module Import failed, exception: 'ImportError'
2017-06-24 08:44:26.348 Error: (Sonos Livingroom) Module Import failed: ' Name: plugin'
2017-06-24 08:44:26.525 Error: (Sonos) failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-06-24 08:44:26.526 Error: (Sonos Kitchen) Module Import failed, exception: 'ImportError'
2017-06-24 08:44:26.526 Error: (Sonos Kitchen) Module Import failed: ' Name: plugin'
but if you post the exact plugin.py file I can try and 'not load it' as well to see if I can reproduce the issue. I haven't seen import failure cause stability issues previously though.
You could try removing the '_pycache_' folder in the Sonos plugins folder if you have one. I have had issues when upgrading a plugin where Python got a little confused.
Still same issue:
2017-06-27 12:50:55.630  (Veras rum) Debug log level set to: 'true'.
2017-06-27 12:50:55.631  (Veras rum) 'Mode3':'Sonos'
2017-06-27 12:50:55.631  (Veras rum) 'Author':'tester22'
2017-06-27 12:50:55.631  (Veras rum) 'Key':'Sonos'
2017-06-27 12:50:55.631  (Veras rum) 'Mode6':'Debug'
2017-06-27 12:50:55.631  (Veras rum) 'Address':'10.0.1.14'
2017-06-27 12:50:55.631  (Veras rum) 'Port':'0'
2017-06-27 12:50:55.632  (Veras rum) 'HardwareID':'15'
2017-06-27 12:50:55.632  (Veras rum) 'HomeFolder':'/home/pi/domoticz/plugins/Sonos/'
2017-06-27 12:50:55.632  (Veras rum) 'Mode1':'30'
2017-06-27 12:50:55.632  (Veras rum) 'Version':'2.0'
2017-06-27 12:50:55.632  (Veras rum) 'Mode2':'Volume'
2017-06-27 12:50:55.632  (Veras rum) 'Name':'Veras rum'
2017-06-27 12:50:55.632  (Veras rum) Device count: 2
2017-06-27 12:50:55.632  (Veras rum) Device:           1 - ID: 131, Name: 'Sonos Veras rum', nValue: 0, sValue: ''
2017-06-27 12:50:55.633  (Veras rum) Internal ID:     '131'
2017-06-27 12:50:55.633  (Veras rum) External ID:     '000000F'
2017-06-27 12:50:55.633  (Veras rum) Device Name:     'Sonos Veras rum'
2017-06-27 12:50:55.633  (Veras rum) Device nValue:    0
2017-06-27 12:50:55.633  (Veras rum) Device sValue:   ''
2017-06-27 12:50:55.633  (Veras rum) Device LastLevel: 0
2017-06-27 12:50:55.633  (Veras rum) Device:           2 - ID: 134, Name: 'Veras rum - Volume', nValue: 2, sValue: '2'
2017-06-27 12:50:55.633  (Veras rum) Internal ID:     '134'
2017-06-27 12:50:55.634  (Veras rum) External ID:     '000000F'
2017-06-27 12:50:55.634  (Veras rum) Device Name:     'Veras rum - Volume'
2017-06-27 12:50:55.634  (Veras rum) Device nValue:    2
2017-06-27 12:50:55.634  (Veras rum) Device sValue:   '2'
2017-06-27 12:50:55.634  (Veras rum) Device LastLevel: 2
2017-06-27 12:50:55.642  (Hjalmars rum) Debug log level set to: 'true'.
2017-06-27 12:50:55.643  (Hjalmars rum) 'Author':'tester22'
2017-06-27 12:50:55.643  (Hjalmars rum) 'Key':'Sonos'
2017-06-27 12:50:55.643  (Hjalmars rum) 'Mode6':'Debug'
2017-06-27 12:50:55.643  (Hjalmars rum) 'Address':'10.0.1.11'
2017-06-27 12:50:55.643  (Hjalmars rum) 'Port':'0'
2017-06-27 12:50:55.643  (Hjalmars rum) 'HardwareID':'16'
2017-06-27 12:50:55.643  (Hjalmars rum) 'HomeFolder':'/home/pi/domoticz/plugins/Sonos/'
2017-06-27 12:50:55.643  (Hjalmars rum) 'Mode1':'30'
2017-06-27 12:50:55.644  (Hjalmars rum) 'Version':'2.0'
2017-06-27 12:50:55.644  (Hjalmars rum) 'Mode2':'Volume'
2017-06-27 12:50:55.644  (Hjalmars rum) 'Name':'Hjalmars rum'
2017-06-27 12:50:55.644  (Hjalmars rum) Device count: 2
2017-06-27 12:50:55.644  (Hjalmars rum) Device:           1 - ID: 132, Name: 'Hjalmar rum - Status', nValue: 0, sValue: ''
2017-06-27 12:50:55.644  (Hjalmars rum) Internal ID:     '132'
2017-06-27 12:50:55.645  (Hjalmars rum) External ID:     '0000010'
2017-06-27 12:50:55.645  (Hjalmars rum) Device Name:     'Hjalmar rum - Status'
2017-06-27 12:50:55.645  (Hjalmars rum) Device nValue:    0
2017-06-27 12:50:55.645  (Hjalmars rum) Device sValue:   ''
2017-06-27 12:50:55.645  (Hjalmars rum) Device LastLevel: 0
2017-06-27 12:50:55.645  (Hjalmars rum) Device:           2 - ID: 133, Name: 'Hjalmars rum - Volume', nValue: 0, sValue: '25'
2017-06-27 12:50:55.645  (Hjalmars rum) Internal ID:     '133'
2017-06-27 12:50:55.646  (Hjalmars rum) Device Name:     'Hjalmars rum - Volume'
2017-06-27 12:50:55.646  (Hjalmars rum) Device nValue:    0
2017-06-27 12:50:55.646  (Hjalmars rum) Device sValue:   '25'
2017-06-27 12:50:55.646  (Hjalmars rum) Device LastLevel: 15
2017-06-27 12:50:55.646  (Veras rum) Heartbeat interval set to: 30.
2017-06-27 12:50:55.646  (Hjalmars rum) Heartbeat interval set to: 30.
2017-06-27 12:50:57.717  Incoming connection from: 127.0.0.1
2017-06-27 12:50:57.787  (RFLink) Temp + Humidity (Sovrum)
2017-06-27 12:51:02.805  (Vardagsrummet) Update 1:'' (Sonos Vardagsrummet)
2017-06-27 12:51:02.916  (Vardagsrummet) Update 1:'Fatboy Slim - Gangster Trippin' (Sonos Vardagsrummet)
2017-06-27 12:51:03.718  (Veras rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:51:04.713  (Hjalmars rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:51:08.291  Incoming connection from: 10.0.1.252
2017-06-27 12:51:23.673  (MySensors) Temp (Kontoret)
2017-06-27 12:51:24.353  (RFLink) Temp + Humidity (Köket)
2017-06-27 12:51:27.536  (MySensors) Temp + Humidity + Baro (TempHumBaro)
2017-06-27 12:51:27.561  (MySensors) General/Barometer (Baro)
2017-06-27 12:51:32.695  (RFLink) Temp + Humidity (Sovrum)
2017-06-27 12:51:33.689  (Veras rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:51:34.736  (Hjalmars rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:51:40.853  (RFLink) Temp + Humidity (Vinden)
2017-06-27 12:51:55.236  (MySensors) Temp (Kontoret)
2017-06-27 12:51:55.299  (MySensors) Temp (Ute)
2017-06-27 12:51:59.355  (RFLink) Temp + Humidity (Köket)
2017-06-27 12:52:00.668  (MySensors) Temp + Humidity + Baro (TempHumBaro)
2017-06-27 12:52:00.962  Error: TV hardware (17) thread seems to have ended unexpectedly
2017-06-27 12:52:03.713  (Veras rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:52:04.803  (Hjalmars rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:52:07.697  (RFLink) Temp + Humidity (Sovrum)
2017-06-27 12:52:26.837  (MySensors) Temp (Kontoret)
2017-06-27 12:52:26.887  (MySensors) Temp (Ute)
2017-06-27 12:52:33.733  (Veras rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:52:33.819  (MySensors) Temp + Humidity + Baro (TempHumBaro)
2017-06-27 12:52:33.839  (MySensors) Temp + Humidity + Baro (TempHumBaro)
2017-06-27 12:52:33.856  (MySensors) General/Barometer (Baro)
2017-06-27 12:52:34.357  (RFLink) Temp + Humidity (Köket)
2017-06-27 12:52:34.731  (Hjalmars rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:52:42.698  (RFLink) Temp + Humidity (Sovrum)
2017-06-27 12:52:58.434  (MySensors) Temp (Kontoret)
2017-06-27 12:52:58.489  (MySensors) Temp (Ute)
2017-06-27 12:53:00.976  Error: TV hardware (17) thread seems to have ended unexpectedly
2017-06-27 12:53:03.729  (Veras rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:53:04.728  (Hjalmars rum) Calling message handler 'onHeartbeat'.
2017-06-27 12:53:06.961  (MySensors) Temp + Humidity + Baro (TempHumBaro)
2017-06-27 12:53:09.363  (RFLink) Temp + Humidity (Köket)
2017-06-27 12:53:17.694  Error: Domoticz received fatal signal 11 !...
2017-06-27 12:53:17.705  Error:   /home/pi/domoticz/domoticz() [0x1ccd84]
2017-06-27 12:53:17.706  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cce3c]
2017-06-27 12:53:17.706  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76ac8160]
Posted: Wednesday 28 June 2017 0:13
by rathmannm
Thanks for looking into this. I have removed the '_pycache_' folder but that didn't make any difference. It's interesting that tester22 has got the exact same error in the log. Also as soon as I remove the Sonos script Domoticz starts without any issues so it really seems the culprit to me.
If you want to try for yourself I am using the latest version of the plugin:
https://github.com/tester22/Domoticz-So ... ster/Sonos
Cheers,
Manuel
Posted: Friday 30 June 2017 10:00
by mvzut
mvzut wrote:
mvzut wrote:
tester22 wrote:Managed to get the built in xml parser to work.
Currently only player state and title.
Volume and mute is not loaded nor radio stations.
Works, thanks! You say that (only) radio stations are not shown, but when I play something from a streaming service like Spotify it also doesn't show the title.
Hmmm, looks like I was too optimistic, Domoticz froze after a few minutes. Can't seem to get it running stable. Is it working reliable at your side?
Tried it again today, there have been a few beta updates of Domoticz since the last time I tried. I removed the __pycache__ folder first. It seems to work again for me! Song names are also shown. I only added one player this time, I will add some more when this continues to run stable.
Posted: Monday 03 July 2017 14:16
by droop7
Hi Everybody,
I'm not very new by domoticz using (since 3 years now)... but its the first time i use python.
I installed plugin on my rasp but i can't see where i can add my sonos devices after reboot.
Maybe it's a dummy question but i'm not english spoken normally... so i searched but didn't fin any post that can help me.
Anyone an idée??
Regards,
Posted: Monday 03 July 2017 23:54
by rathmannm
mvzut wrote:
mvzut wrote:
mvzut wrote: Works, thanks! You say that (only) radio stations are not shown, but when I play something from a streaming service like Spotify it also doesn't show the title.
Actually did you remove all the Sonos setup within Domoticz, then remove the __pycache__ folder and then re-add the plugin and manually setup all of the configuration? So far I only deleted the __pycache__ folder with leaving everything else in place and got nowhere...
Thanks,
Manuel
Posted: Tuesday 18 July 2017 23:43
by G3rard
Unfortunately tester22 is no longer maintaining the code for this plugin.
But I agreed with him that I will continue developing and maintaining the code for the Sonos plugin.
I am currently working on a new version which also shows the radio station and the volume again and has an option to go to the previous or next song. Will see if I can add some more options to the Control switch. Any ideas are welcome.
Next to that I will also have a look if I can load the favorites so they (at least the first 10 due to the limit of the items in the selector switch) can be operated from Domoticz.
When I have the new version ready for testing, I will post that here.
Posted: Wednesday 19 July 2017 14:25
by leecollings
Hey Gerard,
That looks pretty cool. I had to switch back from Beta to Stable so for now don't have any native SOnos control from Domoticz, but I'm using jishi's node script, which works pretty good for now.
Would it be possible to build something similar to how his 'clipall' command works, as a native Notification in Domoticz?
https://github.com/jishi/node-sonos-http-api
Posted: Saturday 29 July 2017 10:32
by G3rard
The test version of the new plugin is nearly ready.
It will have on option to play a file on the Sonos via the notification system in Domoticz :D
That way a file can be played from any other switch or LUA by sending it as a notification to the Sonos.
The Sonos will then play that file and after that continue playing the song (on the same position) or radio station it was playing before the notification.
I aim to have the test version ready this weekend so you can also try it yourself.
Posted: Monday 31 July 2017 10:00
by leecollings
This looks brilliant! Does this single notification get played to all sonos speakers in the system, or is there any control over which ones can be applied?
Is there any idea, on how long the process usually takes to go from this stage to appearing in the stable release?
WHilst on that subject, is there any updated roadmap or schedule for the next stable release?
Posted: Tuesday 01 August 2017 22:55
by G3rard
The notification will get played on the Sonos you choose in the overview with the checkboxes. So if you have for example 2 Sonos, you can both select them and the message will be played on both.
The beauty of the Python plugins is that is independent from the Domoticz releases (except for breaking changes in the Python framework in Domoticz of course).
So I am currently working on the plugin with the latest Domoticz stable version from 30th July.
Once the plugin is ready, you can just add the plugin to Domoticz and it will be available for you. No need to wait for a Domoticz release, assuming you have the latest stable version in use.
Currently working on a way to show your favorite TuneIn radio stations in a Domoticz selector switch. Once that is added I need to do some code cleanup and after that the plugin is ready for testing.
Posted: Wednesday 02 August 2017 0:36
by Skippiemanz
Wow! Great updates! Can't wait to test your plugin!
Posted: Wednesday 02 August 2017 9:11
by leecollings
G3rard wrote:The notification will get played on the Sonos you choose in the overview with the checkboxes. So if you have for example 2 Sonos, you can both select them and the message will be played on both.
Sounds pretty awesome. I'm hoping this plugin will have the ability to instantly play stored MP3 messages for notifications, with minimal delay. I'm currently using the Node Sonos http api for a doorbell, but there's anywhere between 5 - 15 seconds of delay between the button push and the audio played, which isn't ideal.
One last thing, where can I find your plugin? Is it currently on GH?
Posted: Wednesday 02 August 2017 9:15
by Dynamic
Looks awesome... Can't wait to try it out!
Posted: Wednesday 02 August 2017 9:59
by leecollings
Hey Gerard,
Looking at your forked GH repo (https://github.com/gerard33/sonos-php), and just want to ask a question.
Do 'zones' have to be single players via IP, or can you also create zones that feature an array of IPs?
Posted: Wednesday 02 August 2017 14:14
by G3rard
That is a php Sonos solution, it is not the Python script I am working on now.
The Python script is not yet on Github. Will place it there asap and post it there. But I still need some time to finish the radio station favorites and clean up the code.
Posted: Saturday 05 August 2017 0:06
by G3rard
The new version of the Sonos Python plugin is ready for testing.
See this topic viewtopic.php?f=65&t=18710#p144455.
For any questions/discussions please make a post in that topic.
Re: Python plugin: Sonos [old version]
Posted: Saturday 05 August 2017 10:13
by junr
Thanks!!!
The testing has started ;-)
Posted: Thursday 16 August 2018 10:18
by leecollings
Hey,
What's the update to this? Nearly a year ago, is the plugin ready for stable release yet?
I'm itching to integrate this into my system!
