Page 9 of 18
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Posted: Tuesday 08 November 2016 7:10
by Derik
corbin wrote:To compile my latest version, follow the instructions on the wiki at http://www.domoticz.com/wiki/Installing ... rom_Source
but you will need to change
git clone https://github.com/domoticz/domoticz.git dev-domoticz
to
git clone https://github.com/corbinmunce/domoticz.git dev-domoticz
@ corbin,
Was thinking that your solution is a extra option for the Yeelight...
What are the different things in your build and the last beta?
Do i get no problem with my system, when i use your git?
When are your options in the last beta? [ that is what i run always. ]
otherwise, wat are the extra's when i use the git from you?
Posted: Tuesday 08 November 2016 8:42
by corbin
I don't think you will have any problem as it is forked from the beta.
It just has some of the functionality you mentioned - brightness up, brightness down, night mode. If it is too much trouble to compile, wait till I've got it in the official beta.
Posted: Saturday 12 November 2016 21:44
by corbin
I have a question with how Domoticz should operate:
If a light is in an off state, and you then use Domoticz to change the brightness or colour of that light, would you like Domoticz to turn the light on before adjusting the colour/brightness?
Re: RE: Re: [Plugin now available in Beta] Help with Yeelight Bulb
Posted: Saturday 12 November 2016 21:52
by deennoo
corbin wrote:I have a question with how Domoticz should operate:
Just order 2 yeelight, one rgbw and one ww/wc.
Actually got some milight, don't know if this a api limitation, but when turn On to 50% and bulb was previous at 75% we can see the change, who is not good on a bedroom light.
If brightness/color can be change before turn ON, this will make it more 'qualitative'
Posted: Saturday 12 November 2016 22:08
by corbin
The brightness can be changed before switching on (actually I'm currently sending the on command first, then immediately after I send the brightness command, in practice this appears to turn on the light at the specified brightness immediately)
So there is no problem to turn the light on at the specific brightness.
And I think I will leave it operating this way - always sending the on command first - so any command other than off will turn the light on.
Posted: Sunday 13 November 2016 8:56
by domer
RGBW bulbs and led strips arrived and got them working but led strip is recognized as "white" whereas it should be RGBW. How I can change this?
Posted: Sunday 13 November 2016 9:41
by gizmocuz
domer wrote:RGBW bulbs and led strips arrived and got them working but led strip is recognized as "white" whereas it should be RGBW. How I can change this?
Thats hard to debug, you have to sniff with wireshark
But try adding it manually (from the hardware setup page), specifying it's IP address and the type RGBW
Posted: Sunday 13 November 2016 11:31
by domer
gizmocuz wrote:Thats hard to debug, you have to sniff with wireshark
Did it easy way and added it manually and strip works as RGBW now. Thanks!
Posted: Sunday 13 November 2016 22:18
by ErikJ
Are there are some more users who have difficulties to get the right warm white color? In my configuration the color is between very warm white (little orange) or warm white with a slightly green. At this moment I use the code: ff8800 (hue 30). I also have Hue bulbs but they have a different code for the same color: d0ff00 (hue 71). If I switch the codes between the hue and the Yeelight they are not the same (Hue color on Yeelight turns green, and Yeelight color on hue more orange).
If I use the Yeelink app on my iPhone, I can configure the perfect color. A color which is more similar with a traditional warm white bulb. The annoying thing is that I cannot recreate that color within Domoticz.
Are there some more options to adjust the colors different?
Posted: Monday 14 November 2016 1:46
by deennoo
As yeelight got lot of product. This one looks great : http://m.gearbest.com/table-lamps/pp_36 ... d=10195626
A WW WC desklamp got a wifi connection, does api is the same as the e27 ones ?
Posted: Monday 14 November 2016 11:32
by corbin
ErikJ wrote:Hi,
Can you experiment to find the correct code for warm light?
I've tried the two hex codes, and can confirm I'm getting orange for FF8800 and green for D0FF00.
I don't know what warm white should look like - maybe take a screenshot from the iPhone App?
Also you could try experimenting by with this command, just change the decimal value and ip address-
0xFF8800 - 16746496 (Decimal)
echo -ne '{"id":1,"method":"set_rgb","params":[16746496, "smooth", 500]}\r\n' | nc -w1 192.168.5.17 55443
Method: set_rgb
Usage: This method is used to change the color of a smart LED.
Parameters: 3.
"rgb_value" is the target color, whose type is integer. It should be
expressed in decimal integer ranges from 0 to 16777215 (hex: 0xFFFFFF).
 "effect": Refer to "set_ct_abx" method.
 "duration": Refer to "set_ct_abx" method.
Request Example: {"id":1,"method":"set_rgb","params":[255, "smooth", 500]}
Response Example: {"id":1, "result":["ok"]}
NOTE: Only accepted if the smart LED is currently in "on" state.
Posted: Monday 14 November 2016 11:33
by corbin
deennoo wrote:As yeelight got lot of product. This one looks great : http://m.gearbest.com/table-lamps/pp_36 ... d=10195626
It should work with the same api, but like the strip light I don't have one to test.
Posted: Monday 14 November 2016 11:49
by corbin
The colour codes here http://planetpixelemporium.com/tutorialpages/light.html look to match up to what the Yeelight outputs.
ie Cool White Fluorescent
212, 235, 255 = D4EBFF = 13954047
echo -ne '{"id":1,"method":"set_rgb","params":[13954047, "smooth", 500]}\r\n' | nc -w1 192.168.5.17 55443
Posted: Monday 14 November 2016 22:03
by ErikJ
corbin wrote:The colour codes here http://planetpixelemporium.com/tutorialpages/light.html look to match up to what the Yeelight outputs.
Hi Corbin,
Maybe stupid question, but where can I use these commands within Domoticz? I'm not familiar with scripts ore other programming. I would like to, but till now I don’t know where to start. So if you can point me in the right direction I will give it a try.
Second question, where did you find the translation for the color: 212, 235, 255 = D4EBFF = 13954047?
Posted: Monday 14 November 2016 23:46
by corbin
Hi ErikJ,
You can run that command from the command line - Does your Synology have access to one? Or if you have Linux it should work on that too.
That translation is converting from 3 decimal numbers (RGB) to 3 Hex numbers, and then to a single decimal
On Windows there is the built in calculator, put it in programmer mode and then it will convert between decimal and hex for you. There are also heaps of web pages that will do it as well, eg http://www.subnetonline.com/pages/conve ... to-dec.php
Posted: Tuesday 15 November 2016 12:39
by deennoo
Ok, will ask one to Santa...
Mine e27 just left china...
Posted: Tuesday 15 November 2016 23:35
by ErikJ
corbin wrote:Hi ErikJ,
Hi Corbin,
The command line was no option on the Synology (no result). So I installed a copy of ubuntu and with the line you provide me I can change the color. But even than no luck with getting the right color. I also discovered that not all hex codes could be converted to decimal (for example (100W Tungsten) 255, 214, 170 = #FFD6AA = error decimal). And if I use the code #FFD6AA in Domoticz the Yeelight light turns green and the hue also.
I used these sites for the conversion http://www.rapidtables.com/convert/color/rgb-to-hex.htm and http://www.rapidtables.com/convert/numb ... =%23800080
Is there a way to read out the color of the lamp itself?
Posted: Wednesday 16 November 2016 0:20
by Westcott
Sending FFD6AA to mine (using yee) gives a sort of day white ~4000.
FFBB66 is close to 3000
The YeeLight API supports colour temperature commands
Posted: Wednesday 16 November 2016 10:37
by corbin
ErikJ wrote:
Hi Corbin,
FFD6AA = 16766634 in Decimal (converts ok using the sites you linked to)
I put this into the command line, and it results in a white coloured light.
Yes you can get the current light color - see "3.1 Search request and response" in the docs https://www.yeelight.com/download/Yeeli ... n_Spec.pdf
or try sending
{"id":1,"method":"get_prop","params":["power","rgb"]}\r\n
Posted: Wednesday 16 November 2016 10:39
by corbin
Westcott wrote:Sending FFD6AA to mine (using yee) gives a sort of day white ~4000.
Hi Westcott,
From the Yeelight forum, I saw you got developer mode working!
Awesome :)
