deennoo
Post by deennoo »
chatainsim wrote:
langoo wrote:
deennoo wrote:
They will never ship them even if they are on sale...
I bought mine from them...
Same for me have the new door sensor.
Button in on it's way too.
Ok your the best guys ! And are you sure they will works ?
http://domo-attitude.fr
Revers59
Post by Revers59 »
New Design Xiaomi AQara Smart Body Sensor ZigBee Wireless Connection Built In Light Intensity Sensors Work On Phone APP
upgrade with light support.
deennoo
Post by deennoo »
Revers59 wrote:New Design Xiaomi AQara Smart Body Sensor ZigBee Wireless Connection Built In Light Intensity Sensors Work On Phone APP
Thx as usual wait to be sure that the gateway broadcast data from this device before spending money.
Those new device looks to be the same as another HA solution who will arrive at the end of year
quack3d
Post by quack3d »
What do you use the pressure measurement in the new temperature sensors for?
deennoo
Post by deennoo »
Pressure : baromètre need to be convert on mbar ... Glad to know that you have it on Domoticz
mikeoo
Post by mikeoo »
deennoo wrote:
langoo wrote:
What do you mean with gearbest can't have them?
http://www.gearbest.com/access-control/pp_626702.html
Bought them with a per-sales and they deliver just fine. Took about 3 weeks.
deennoo
Post by deennoo »
mikeoo wrote:]
Was talking about actual sales...
mikeoo
Post by mikeoo »
deennoo wrote:
mikeoo wrote:]
It was also a actual sale but 3 weeks ago :mrgreen:
langoo
Post by langoo »
mikeoo wrote:
deennoo wrote:
mikeoo wrote:]
Same as me..
Diab
Post by Diab »
Hi.
Since three days I'm not able to perform a new installation of the Xiaomy Gateway running on a Raspberry Pi.
It was running previously (before the two last updates) but since I downloaded V3.8003 and 8005, no way to reinstall the gateway.
The browser has been cleaned but I definitly don't have access to the gateway parameters (name, IP @, port...), only what is below.
Capture du 2017-06-22 10-54-09.png (187.67 KiB) Viewed 4018 times
Did anyone already face this situation?
Thanks for support ;)
corbin
Post by corbin »
I've just updated my dev copy, had issues at first after trying to clear the browser cache. Clearing it again resulted in this:
So it could be your cache hasn't fully cleared
Diab
Post by Diab »
Hi Corbin.
Thanks for your support.
Sometime I really do not understand how it works :( .
I cleaned again by the same way the browser cache and performed Ctrl+F5 to be sure.
Now it works perfectly, gateway added. :P :P :P .
Have a nice WE.
Onkytonk
Post by Onkytonk »
So I went ahead and ordered one of these. It was only $10au more than the old body sensor so I thought I'd give it a go. Hopefully it works with the xiaomi plugin, at least the movement sensor for now, until the light sensor is implemented.
Has anyone got one of these and tested it yet?
theo69
Domoticz version: la. beta
Post by theo69 »
Hi I bought this Single Button Zero Line Aqara Switch http://www.gearbest.com/access-control/ ... d=10893221 however it gives me this error while using with Domoticz:
2017-06-24 07:36:26.142 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:27.088 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:28.197 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:31.957 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:34.857 XiaomiGateway: unhandled model: ctrl_ln1
Any update if it will be added soon, anything else I can do to help adding it?
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
warmaniac
Post by warmaniac »
theo69 wrote:Hi I bought this Single Button Zero Line Aqara Switch http://www.gearbest.com/access-control/ ... d=10893221 however it gives me this error while using with Domoticz:
As we wrote before, we need to wait and pray if xiaomi fix it on gateway because this is problem of Aqara series sensors/switches.
theo69
Post by theo69 »
I think its because its not integrated in Domotics, because the Switches without Zero Line are fine. The Zero Line Switch is working with homebridge plugin https://github.com/YinHangCode/homebridge-mi-aqara
theo69
Post by theo69 »
Also I am always getting loads of Error are these normal?:
2017-06-24 07:39:00.168 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.172 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.176 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.181 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.185 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.190 Error: EventSystem: in Wohnzimmer Stehlampen alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.207 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.211 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.215 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.220 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.224 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.229 Error: EventSystem: in Wohnzimmer Stehlampen alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.245 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.249 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.254 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.258 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.263 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.267 Error: EventSystem: in Wohnzimmer Stehlampen alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.284 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.289 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.293 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.300 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.304 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
xxLeoxx93
Post by xxLeoxx93 »
What is the easiest way to tell domoticz that when i doubleclick my switch it should turn of my xiaomi wallplug? I can only see to run a script when interacting with my switch?
theo69
Post by theo69 »
xxLeoxx93 wrote:What is the easiest way to tell domoticz that when i doubleclick my switch it should turn of my xiaomi wallplug? I can only see to run a script when interacting with my switch?
Try Lua or Blocky ;)
this is example with Lua, really powerfull!
   if devicechanged['buttonswitch'] == 'Double Click' then
      if otherdevices['wallplug'] == 'Off' then
         commandArray['wallplug'] = 'On'
         commandArray['wallplug'] = 'Off'
Swifty
Post by Swifty »
Anyone compiled corbins github version of domoticz recently? - I tried to update last night and after compiling I get 'Segmentation Fault' when trying to run domoticz.
I've re-cloned to a fresh folder and re-compiled, but same issue.. (rPi 2)
