galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
bueno79 wrote:I just get a Hub harmony from logitech (not support in the current stable domoticz...logitech problem but fix in the next release). So I've use the harmony apps. I see thay put shortcut ON the lock screen. Is it possible to do the same ? Get a button to open a gate or garage directly...don t have to unlock the phone...it could be great.
Good suggestion, i'll look into lockscreen shortcuts
bueno79 wrote:PS : oh and sometime I'm watching you playing battlefield :p
:lol: :lol:
galadril
Post by galadril »
FYI
I've made a iOS topic on how I progress on making the app multi platform (iOS and Universal Windows):
https://www.domoticz.com/forum/viewtopi ... 36&t=17025
bueno79
Domoticz version: 4.9700
Post by bueno79 »
galadril wrote:FYI
very happy that you develop the same app for Apple. Ipilot is not good at all.
Pixal
Domoticz version: 4.10199
Post by Pixal »
bueno79 wrote:
galadril wrote:FYI
Curious what you didn't think was good about pilot as it performed very well for me the last 1.5 years. Widgets, locations and all.
Locations on android beta seem to work fine for me now this week. No complaints anymore, well one then, still getting a lot of events that it's changing my current location from home... to home. When I open the app or charge my phone for example. A bit silly. Can't it check if the event is pointless or that the location really changed?
bueno79
Post by bueno79 »
yes and when It change home to home...action!...and my gate is open. Not very secure.
bueno79
Post by bueno79 »
just get a strange bug this morning. My phone (nexus5) was on wifi...all good. I cut the wifi, and go outside :
- widget in Loading state
- I can go and list dashboard in apps but switch not respond (no effect on hardware)
so,
kill apps
restart apps...nothing
I've reboot phone : all good.
pretty sure domoticz 2.0 was still trying to use wifi to send order but wifi was off.
bueno79
Post by bueno79 »
always me. Just add Qubino to manage the radiator for towel in the bathroom. So it has a pilot cable. This radiator is able to receive 6 order (ON, Off, temp, winter, temp -1, temp -2, temp -3.5 degree celcius). Si I use a virtual switch, with the type selector :
this type of switch is not manage very well on the apps. It could be great to have the button always display. Currently I need to go in setting, activate option to see ON/Off button (whyyyy?); then I type ON, a combo box appear and I have to choose the mode...not very cool.
If you can do something better...I will be your biggest fan in France :)
Bueno
olskar
Post by olskar »
Every time i open the app the geofence triggers, anyone else see this?
galadril
Post by galadril »
olskar wrote:Every time i open the app the geofence triggers, anyone else see this?
I recreate all geofences on app restart.
But the latest beta has a change that it doesn't set the switch again if it's not needed..
galadril
Post by galadril »
Im still progressing on the multiplatform app that runs iOS, Android and Universal Windows, here some screenshots:
https://github.com/domoticz/domoticz-android/issues/414
and on iOS:
Milenko
Post by Milenko »
After I reinstalled my domoticz app on my android phone about a week ago,I am unable to add a geofence.
I can enable geofencing in the app and click add a geofence.
When the map shows, it finds my current location on the map, but the field above does not contain the address. I Can click on the map as much as I want but I cant select anything.
I have tried resetting permissions and clearing the app cache and data, reinstalling the app alltoghether and nothing works.
I other apps (maps), everything works correctly.
On my wifes lg g5 i can add geofences all day long if I want.
I run an zte axon 7 with android 7.1.1. When I was still on android 6 geofencing worked perfectly for me on this phone. The lg g5 is also on android 7 and had no problems.
I already entered beta, hoping for some miracle fix, but no.
Is there anything I can try or do to solve this?
galadril
Post by galadril »
Milenko wrote:I already entered beta, hoping for some miracle fix, but no.
Can you see in the settings / apps / permissions what permissions where enabled for the app?
and send some screenshots of the app / issue?
Milenko
Re: RE: Re: Domoticz app 2.0
Post by Milenko »
As you can see, permissions are correct, but in the map screen the address is not filled in on the search bar, which means I can't select a location. Typing in the search bar gives a short error message (Something went wrong). The only option I have is to press back without adding a geofence.ImageImageImage
Sent from my ZTE A2017G using Tapatalk
galadril
Post by galadril »
Milenko wrote: As you can see, permissions are correct, but in the map screen the address is not filled in on the search bar, which means I can't select a location. Typing in the search bar gives a short error message (Something went wrong).
do you have the latest play services?
Milenko
Post by Milenko »
I think so.
I have 10.2.98.
Seems to be pretty recent (from february 2017).
I have no problem in other apps with play services and things like google assistant (which as far as I know requires a recent version of google play services) work perfectly.
galadril
Post by galadril »
I think so.
I have 10.2.98.
ill look into the possibilty to use the long/lat as failback when no address is found..
Gerwin
Post by Gerwin »
Here works geofencing great ,
Location of the phone must be switched on else find he no address
galadril
Post by galadril »
bueno79 wrote:Hi,
Bueno
I've reworked the selector switches in the latest beta
Gerwin
Post by Gerwin »
Thanks a lot the smartwares valve works great
galadril
Post by galadril »
Gerwin wrote:Thanks a lot the smartwares valve works great
Good to know :)
