Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Thursday 27 April 2017 9:19
Is it save to use the moon script again?
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Ofc. Will post it later to Day.htilburgs wrote:Like to share?
You're completely right! Will fix it. Thanks! Still some minor issues. I'm checking it...bierlaagh wrote: partly conformed
Only
should beCode: Select all
n='00'Although my moon.50.png is New Moon and moon.00.png is a full moonCode: Select all
n='50'
Greatwizjos wrote:You're completely right! Will fix it. Thanks! Still some minor issues. I'm checking it...bierlaagh wrote: partly conformed
Only
n='50'
2017-04-27 09:57:40.874 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:122: attempt to call field 'round' (a nil value)Code: Select all
-- Variables to customize ------------------------------------------------
local moonpicture = "MoonPicture" -- name of the uservar to write the name of the moonphase picture to
local checkvar = "MoonphaseCheck" -- name of the uservar to check if update is allowed
local checktime = 3600 -- check allowed every x seconds 3600 = 60 min. Check the wundergroud API limitation before changing this
local city = "<your town>" -- Your city for Wunderground API
local countryCode = "<YOUR COUNTRY CODE>" -- Your country code for Wunderground API
local idxmoonpercentage ='125' -- Your virtual moon percentage illuminated Device ID
local idxmoonage ='131' -- Your virtual moon age Device ID
local idxmoonphase ='132' -- Your virtual moon phase Device ID
local idxmoonrise='124' -- Your virtual moon rise variable ID
local idxmoonset='127' -- Your virtual moon set variable ID
local wuAPIkey = "<your key>" -- Your Weather Underground API Key
local DOMO_IP = "<your domo ip>" -- Domoticz ip address
local DOMO_PORT = "<your domo port>" -- Domoticz port
local tempfilename = '/var/tmp/phase.tmp' -- can be anywhere writeable
local debug=false -- false, true for domoticz log
function file_exists(path)
-- function to check if a file exists
local file = io.open(path, "rb")
if file then file:close() end
return file ~= nil
function timedifference(s)
-- function to determine the difference in seconds between the current time and a given one
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
function may_update(device, timeelapsed)
-- function to check whether an update is allowed
return uservariables_lastupdate[device] == nil or timedifference(uservariables_lastupdate[device]) >= timeelapsed
time = os.date("*t")
url='http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json'
if (may_update(checkvar,checktime)==true) or (file_exists(tempfilename)==false) then
-- read API Wunderground
if debug then print("Moonphase - Collecting data from: "..url) end
os.execute('curl -s '..url..' > '..tempfilename)
-- NOTE: if the command above doens't work in your situation try
-- read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
-- instead! Thanks to EdKo66
file = io.open(tempfilename, "r")
s= file:read("*a")
s = (string.gsub(s, "%c+", ""))
file:close()
-- moonrise
moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
-- moonset
moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
-- percentage of moon illuminated
percentIlluminated = string.match(s, [["percentIlluminated":"(%d+)"]])
if debug then print("Percent:\t"..percentIlluminated.."%") end
-- age of moon since last new moon
age = string.match(s, [["ageOfMoon":"(%d+)"]])
if debug then print("Age:\t\t"..age) end
-- Phase of the moon
-- set the moonPhaseIcon to your appropriate icon number (8 x)
moonPhase = string.match(s, [["phaseofMoon":"(.-)"]])
if moonPhase=="New Moon" then
moonPhase = "Nieuwe maan"
is_waxing = true
if moonPhase=="Waxing Crescent" then
moonPhase = "Wassende halve maan"
is_waxing = true
if moonPhase=="First Quarter" then
moonPhase = "Eerste kwartier"
is_waxing = true
if moonPhase=="Waxing Gibbous" then
moonPhase = "Wassende maan"
is_waxing = true
if moonPhase=="Full" then
moonPhase = "Volle maan"
is_waxing = false
if moonPhase=="Waning Gibbous" then
moonPhase = "Afnemende maan"
is_waxing = false
if moonPhase=="Last Quarter" then
moonPhase = "Laatste kwartier"
is_waxing = false
if moonPhase=="Waning Crescent" then
moonPhase = "Afnemende halve maan"
is_waxing = false
-- calculate moonphase picture
if percentIlluminated == '0' then
n='50'
if waardecheck==false then
picnumber=math.floor(math.abs(percentIlluminated-100)/2)
n=tostring(picnumber)
if n.length==1 then
n='0'+n
picnumber=math.floor(50+(percentIlluminated/2))
if picnumber == 100 then
picnumber=99
picture='moon.'..n..'.png'
if debug then print('Picture number: '..n..' '..'Picture name: '..picture) end
commandArray['Variable:'..checkvar]=moonPhase
commandArray['Variable:'..moonpicture]=picture
commandArray[1] = {['UpdateDevice'] = idxmoonphase.."|0|"..moonPhase}
commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..":"..moonriseMinute}
commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..":"..moonsetMinute}
commandArray[4] = {['UpdateDevice'] = idxmoonage.."|0|"..age}
commandArray[5] = {['UpdateDevice'] = idxmoonpercentage.."|0|"..percentIlluminated}
if debug then print("MoonPhase - Update not allowed: Difference is "..timedifference(uservariables_lastupdate[checkvar]).." seconds") end
No errors so farwizjos wrote:OK I think I've got the moonphase lua script working again. I made the mistake to assume lua has a function 'round' when porting it from js to lua.
But now I think I've 'floored' the problem![]()
New Moonphase LUA script:Please confirm...Code: Select all
-- Variables to customize ------------------------------------------------ local moonpicture = "MoonPicture" -- name of the uservar to write the name of the moonphase picture to local checkvar = "MoonphaseCheck" -- name of the uservar to check if update is allowed local checktime = 3600 -- check allowed every x seconds 3600 = 60 min. Check the wundergroud API limitation before changing this local city = "<your town>" -- Your city for Wunderground API local countryCode = "<YOUR COUNTRY CODE>" -- Your country code for Wunderground API local idxmoonpercentage ='125' -- Your virtual moon percentage illuminated Device ID local idxmoonage ='131' -- Your virtual moon age Device ID local idxmoonphase ='132' -- Your virtual moon phase Device ID local idxmoonrise='124' -- Your virtual moon rise variable ID local idxmoonset='127' -- Your virtual moon set variable ID local wuAPIkey = "<your key>" -- Your Weather Underground API Key local DOMO_IP = "<your domo ip>" -- Domoticz ip address local DOMO_PORT = "<your domo port>" -- Domoticz port local tempfilename = '/var/tmp/phase.tmp' -- can be anywhere writeable local debug=false -- false, true for domoticz log ------------------------------------------------------------------------- function file_exists(path) -- function to check if a file exists local file = io.open(path, "rb") if file then file:close() end return file ~= nil end function timedifference(s) -- function to determine the difference in seconds between the current time and a given one year = string.sub(s, 1, 4) month = string.sub(s, 6, 7) day = string.sub(s, 9, 10) hour = string.sub(s, 12, 13) minutes = string.sub(s, 15, 16) seconds = string.sub(s, 18, 19) t1 = os.time() t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds} difference = os.difftime (t1, t2) return difference end function may_update(device, timeelapsed) -- function to check whether an update is allowed return uservariables_lastupdate[device] == nil or timedifference(uservariables_lastupdate[device]) >= timeelapsed end commandArray = {} time = os.date("*t") url='http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json' if (may_update(checkvar,checktime)==true) or (file_exists(tempfilename)==false) then -- read API Wunderground if debug then print("Moonphase - Collecting data from: "..url) end os.execute('curl -s '..url..' > '..tempfilename) -- NOTE: if the command above doens't work in your situation try -- read = os.execute('curl -s -o '..tempfilename..' "'..url..'"') -- instead! Thanks to EdKo66 file = io.open(tempfilename, "r") s= file:read("*a") s = (string.gsub(s, "%c+", "")) file:close() -- moonrise moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]]) if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end -- moonset moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]]) if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end -- percentage of moon illuminated percentIlluminated = string.match(s, [["percentIlluminated":"(%d+)"]]) if debug then print("Percent:\t"..percentIlluminated.."%") end -- age of moon since last new moon age = string.match(s, [["ageOfMoon":"(%d+)"]]) if debug then print("Age:\t\t"..age) end -- Phase of the moon -- set the moonPhaseIcon to your appropriate icon number (8 x) moonPhase = string.match(s, [["phaseofMoon":"(.-)"]]) if moonPhase=="New Moon" then moonPhase = "Nieuwe maan" is_waxing = true end if moonPhase=="Waxing Crescent" then moonPhase = "Wassende halve maan" is_waxing = true end if moonPhase=="First Quarter" then moonPhase = "Eerste kwartier" is_waxing = true end if moonPhase=="Waxing Gibbous" then moonPhase = "Wassende maan" is_waxing = true end if moonPhase=="Full" then moonPhase = "Volle maan" is_waxing = false end if moonPhase=="Waning Gibbous" then moonPhase = "Afnemende maan" is_waxing = false end if moonPhase=="Last Quarter" then moonPhase = "Laatste kwartier" is_waxing = false end if moonPhase=="Waning Crescent" then moonPhase = "Afnemende halve maan" is_waxing = false end -- calculate moonphase picture if percentIlluminated == '0' then n='50' else if waardecheck==false then picnumber=math.floor(math.abs(percentIlluminated-100)/2) n=tostring(picnumber) if n.length==1 then n='0'+n end else picnumber=math.floor(50+(percentIlluminated/2)) if picnumber == 100 then picnumber=99 end end n=tostring(picnumber) end picture='moon.'..n..'.png' if debug then print('Picture number: '..n..' '..'Picture name: '..picture) end commandArray['Variable:'..checkvar]=moonPhase commandArray['Variable:'..moonpicture]=picture commandArray[1] = {['UpdateDevice'] = idxmoonphase.."|0|"..moonPhase} commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..":"..moonriseMinute} commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..":"..moonsetMinute} commandArray[4] = {['UpdateDevice'] = idxmoonage.."|0|"..age} commandArray[5] = {['UpdateDevice'] = idxmoonpercentage.."|0|"..percentIlluminated} else if debug then print("MoonPhase - Update not allowed: Difference is "..timedifference(uservariables_lastupdate[checkvar]).." seconds") end end return commandArray
Wizjos
Should be gone now... LUA doesn't know of a function 'round'. Used 'floor' instead.SwordFish wrote: couldn't wait some i copied the last version of the script a few page back, turned the script on a get this error;Code: Select all
SwordFish wrote:No errors so far
And what if you want to put it in the root of the server?htilburgs wrote:
When u use the following command, you can still install in the map 'dashboard' if you like:
git clone https://github.com/robgeerts/dashticz_v2.git dashboard
And another question: I'd like to display the CV pressure (general, pressure), but all I see is: "Nefit - CV druk : AAN", where it should read 1.6 BAR. Is it possible to change that too ?mvveelen wrote:I was wondering: Is it possible to get the "var _SHOW_LASTUPDATE" per device?
For instance: I couldn't care less when the last time it was when I switch off a light, but it would be nice to see when a door sensor has been opened/closed.
No images of the moon anymoreSwordFish wrote:No errors so farwizjos wrote:OK I think I've got the moonphase lua script working again. I made the mistake to assume lua has a function 'round' when porting it from js to lua.
Please confirm...
Wizjos
This is 'my' moon atmDvD wrote:No error messages anymore but the moon is showing a full moon ...
When you perform the git clone command from the root of the server, then it wil create a directory in the root.EdKo66 wrote:And what if you want to put it in the root of the server?htilburgs wrote:
i tried now the following changes in custom.jsmkscity wrote:is it somehow possible to show more infos for moon phase?
Actually i have the following visible:
And this code in custom.js:But whatever i try to add for showing correct values for "Mondaufgang" and "Monduntergang" i see only switches.Code: Select all
function getExtendedBlockTypes(blocktypes){ blocktypes.Name['Download'] = { icon: 'fa fa-download', title: '<Name>', value: '<Data>' } blocktypes.Name['Mondphase'] = { icon: 'fa fa-moon-o', title: '<Name>', value: '<Data>' } blocktypes.Name['Mondaufgang'] = { icon: 'fa fa-moon-o', title: '<Data>', value: '<Name>' } return blocktypes; }
Same Problem is actually that order is not changed, it shows always first <Data> then <Name>
Switch is set to true in config.js.Code: Select all
//Mondphase blocks[192] = {} blocks[192]['width'] = 6; blocks[192]['switch'] = true;
HansieNL wrote:I had same problem with Dutch texts. Can you try these settings? Don't forget to change the idx to yours.mkscity wrote:is it somehow possible to show more infos for moon phase?
blocks[idx] = {} //Mondaufgang
blocks[idx]['switch'] = true;
blocks[idx]['icon'] = 'fa-moon-o';
blocks[idx] = {} //Monduntergang
blocktypes.Name['Mondaufgang'] = { icon: 'fa-moon-o', title: '<Name>', value: '<Data>' }
blocktypes.Name['Monduntergang'] = { icon: 'fa-moon-o', title: '<Name>', value: '<Data>' }
return blocktypes;
}Code: Select all
<iframe src="https://calendar.google.com/calendar/embed?mode=AGENDA&height=600&wkst=1&bgcolor=%23ffffff&src=your_email_address&color=%23125A12&ctz=Europe%2FAmsterdam" style="border-width:0" width="250" height="600" frameborder="0" scrolling="no"></iframe>Code: Select all
<iframe src=Code: Select all
frames.calendar = {height:250,frameurl:"https://calendar.google.com/calendar/embed?mode=AGENDA&height=600&wkst=1&bgcolor=%23ffffff&src=your_email_address&color=%23125A12&ctz=Europe%2FAmsterdam"
