Re: Domoticz app 2.0
Hello everyone,
Great job on this app !
I have two remarks for now :
- negatives temperatures are not properly handled on my Samsung galaxy S3 on the dashboard page. It is correct on the temperature page.
- measures graphs are not display at all (the page closes directly). (when I say measure, I talks about voltage/current/power, etc...)
Does anyone have the same issues ?
In any case, other functionalities works for me. I have to add that I use the free version of the app.
regards
jeanclic
regards
jeanclic
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
- Target OS: -
Re: RE: Re: Domoticz app 2.0
I have the same issue with distance and speed graphs.jeanclic wrote:Hello everyone,
jeanclic
Wysłane z mojego LG-H815 przy użyciu Tapatalka
Is there any development on mydomoticz support?
I am currently using ssh-tunnels together with the app, but I would really like a no-hassle solution for remote control of my home.
Regarding geofencing I am experiencing the same issues (sometimes leaving, battery drain).
If possible I think you should make the use of GPS optional. A friend of mine examined android positioning in his master thesis and found that in an area with dense population wifi+cellular gave just as good, and sometimes even better results thsn GPS using only a fraction of the energy. I believe the vast majority of users have no use for GPS positioning and that it only leads to bad results and battery drain given that most of the day is spent inside where it doesn't really work..
Skickat från min SM-G930F via Tapatalk
Ive been testing for months and they dont work the way they should be.galadril wrote:I've been testing, they work good at my sidePSYCHOTIC wrote:Any update on the widgets part?
Thx
After a few days they get corrupted.
Ive bought this app for the widget feature and i could never use them descently.
Point me way I(explain) to help you getting rid of these bugs than giving me thiz half baked answer.
- galadril
- Domoticz version: latest
Can you give me a test account please?JvdW wrote:Using Domoticz v. 3.6944 (beta) and the Domoticz beta app (paid) currently, and since a couple of updates my door lock function doesn't work properly anymore. (chanced in domoticz)
When using the switch type "door contact" it doesnt show up in the domoticz app
- bueno79
- Domoticz version: 4.9700
Hi Galadril,
thx for the last update. I'm going to continue to test Geo function. I'm still testing a lot the voice part of the app. Very cool. To be better :
- could it be possible to sort voice command per alphabetic order
- to sort per switch or command attach (So cool feature! group by type of switch)
- activate a scene or an event (for the moment only switch) to open awesome possibility.
do you know where can I find the last releases notes ?
An one million thanks for your excellent job. Love your app!
best regards
Bueno
best regards
Bueno
- Domoticz version: L stab
Thx for the fix.galadril wrote:This is fixed in the next beta!galadril wrote:I don't have a evotouch, and that part of the app is not implemented by me...Lebo2d9 wrote:is there a way to change the evotouch status? (Auto, Away, Eco, Day off,...)
I can only see on witch status the evotouch is but i cannot change it.
Maybe you could provide me a test account on your system for that evotouch to look at it?
Verstuurd vanaf mijn SM-G920F met Tapatalk
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
- Target OS: -
This is a great app.
Thank you for all.
I have then a request and a bug to report.
Bug:
Latest Notifications are not sorted by date and time in descending order.
Within a day, time before and after noon are mixed together.
So a notification at 6 am appears before a notification at 3 PM.
Improvement:
Would it be possible to add the latest notifications screen as a direct option in the left panel of the app with the same layout than the logs option ?
Cheers..
Envoyé de mon thor en utilisant Tapatalk
Thank you for all.
Bug:
Improvement:
Cheers..
- Domoticz version: 2023.2
I'm using version 0.1.382 (2620) via SSL on a Samsung A5 (2017). I bought the premium version for incorporated Geofencing.
Although the fencing function is working properly (switches on when arriving and off when leaving) it keeps on sending it's status when opening the app on my phone. That's pretty annoying because there's a doorbel connected to the virtual switch.
I disabled notifications for the Geofencing messages. In debugging mode the message "task already scheduled" appears. Don't know if it has anything to do with it.
- galadril
No task already scheduled has nothing to do with it..Jonkheer wrote:I disabled notifications for the Geofencing messages. In debugging mode the message "task already scheduled" appears. Don't know if it has anything to do with it.
We need to recreate the geofences once in a while.. so we do it at startup of the app...
I could check if there was a need to flip the switch.. on is already on for example..
- galadril
Hmmm, ill look into it!fanfan7291 wrote: Latest Notifications are not sorted by date and time in descending order.
Sorry Im not in favor of that feature.fanfan7291 wrote: Would it be possible to add the latest notifications screen as a direct option in the left panel of the app with the same layout than the logs option ?
- galadril
Thanks! I've fixed your issue in the latest release.JvdW wrote:Sure, send you a pm.
- bueno79
I continue to use it everyday...really good. But I have more feedback for you
(tell me if it is not the right place).
I begin to get a lot of switch and object. So I think it good be great to group object on dashboard to be able to extend or show one item for multiple. Cause for the moment I have to scroll a lot.
And plz offer us the possibility to use scene with voice, not only switch. Plllzzzz
best regards
Bueno
best regards
Bueno
That would be nice!galadril wrote:Jonkheer wrote:I
Flipping the switch starts an event in my situation.
Thanks for the quick respond!
- galadril
Upcoming new feature in the next beta.. use satalite view on location picker for geofences (requested by a user
- galadril
Hi! Yes this is the right placebueno79 wrote:I continue to use it everyday...really good. But I have more feedback for you(tell me if it is not the right place).
Still on my list to do..! not really easy to implementbueno79 wrote:And plz offer us the possibility to use scene with voice, not only switch. Plllzzzz
- bueno79
galadril wrote:Hi! Yes this is the right placebueno79 wrote:I continue to use it everyday...really good. But I have more feedback for you(tell me if it is not the right place).
Thx for your answer. not easy?...arg...ok I'm sure you will be able to find the solution...it will just take more time
On another topic maybe ("maybe") I found a bug. I've set a witch to control a gate. this switch on domoticz have a "off delay " set to 10. So this switch of automatically turn off after 10 sec. If I use the switch in domoticz app in the switch section (not dashboard) the switch remain ON forever. I have to tap one more time to turn off.
I will do more test to confirm everything tonight.
And one more time : congratulation for this awesome Apps. Domotic is the future, you're part of it for sure !
Have you tried to refresh you screen in the app? Sometimes (at my place) a switch stay in the same state and when I refrech the screen the state has changedbueno79 wrote:galadril wrote:Hi! Yes this is the right placebueno79 wrote:I continue to use it everyday...really good. But I have more feedback for you(tell me if it is not the right place).
Thx for your answer. not easy?...arg...ok I'm sure you will be able to find the solution...it will just take more time![]()
More to come
More to come
- galadril
This is changed in the next betagaladril wrote:I could check if there was a need to flip the switch.. on is already on for example..Jonkheer wrote:I disabled notifications for the Geofencing messages. In debugging mode the message "task already scheduled" appears. Don't know if it has anything to do with it.
