Page 76 of 184
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Wednesday 26 April 2017 16:43
by wizjos
HansieNL wrote:I've a little different error: Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_moon_phase.lua: /home/pi/domoticz/scripts/lua/script_time_moon_phase.lua:118: attempt to call field 'round' (a nil value)
As did I
Had a look at what was wrong. Cause was a division by zero...
New version of the lua moonphase script is to be found in a later post.
EDIT: code in this post removed...
Wizjos
Posted: Wednesday 26 April 2017 17:00
by Martijn85
SwordFish wrote:I have dashticz running on a rpi and a tablet on the wall. Now i have dashticz also running on my NAS webserver. So i did some dirty custom css and now its fits on my iphone with a different layout as on my tablet
Nice! Can you please share this custom css?
Posted: Wednesday 26 April 2017 17:02
by robgeerts
WARNING: DASHTICZ HAS MOVED FROM GITLAB TO GITHUB!! BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!!
From now on, you can find the source over here:
https://github.com/robgeerts/dashticz_v2/tree/master
custom.js, custom.css and config.js has been
moved to the custom-folder!
Also, I created a beta-branch to test new features, in the future. If you like you can download this branch but be prepared of having more bugs...
AND last but not least, I have moved the mentioned bugs and features to the github issue-tracker, instead of Trello:
https://github.com/robgeerts/dashticz_v2/issues
By the way, did I mention to
BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!! ?
Posted: Wednesday 26 April 2017 17:34
by madrian
I am going to celebrate this.
Should we send merge request to the beta branch? Then after test you can move to the stable one.
What about an (automatic) upgrade and backup feature? If it is welcomed, It is possible to get from github info about latest release?
Posted: Wednesday 26 April 2017 17:36
by htilburgs
robgeerts wrote:WARNING: DASHTICZ HAS MOVED FROM GITLAB TO GITHUB!! BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!!
Mmmm... work to do! Update wiki!
Posted: Wednesday 26 April 2017 17:38
by madrian
htilburgs wrote:robgeerts wrote:WARNING: DASHTICZ HAS MOVED FROM GITLAB TO GITHUB!! BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!!
You should consider to manage Wiki on the project's GitHub page too.
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Wednesday 26 April 2017 17:39
by robgeerts
madrian wrote:I am going to celebrate this.
Yes, merge requests to beta
Will look into the upgrade functions/alerts.
Posted: Wednesday 26 April 2017 17:43
by madrian
Look for "releases" on GitHub, it is possible to make releases here. From that point it is easy as pie /there is an RSS feed for release page/.
https://help.github.com/articles/creating-releases/
Posted: Wednesday 26 April 2017 17:45
by htilburgs
madrian wrote:htilburgs wrote:robgeerts wrote:WARNING: DASHTICZ HAS MOVED FROM GITLAB TO GITHUB!! BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!!
@Robgeerts, this is an option.
I think I've to rewrite the wiki, because Github uses an other format.
And you have to create the wiki, because it's your project
(I believe I cannot create a wiki if you not started one).
Posted: Wednesday 26 April 2017 18:12
by EdwinK
robgeerts wrote:
By the way, did I mention to BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!! ?
You mean we have to backup some files?
Posted: Wednesday 26 April 2017 18:28
by EdwinK
Smallish 'error'. Your script says to get 'Moon.0.png', but it is named 'Moon.00.png' in the images map. Easy to fix by just changing the name of the file, but others might not find it.
Posted: Wednesday 26 April 2017 19:03
by robgeerts
Sort of
EdKo66 wrote:Smallish 'error'. Your script says to get 'Moon.0.png', but it is named 'Moon.00.png' in the images map. Easy to fix by just changing the name of the file, but others might not find it.
I will rename it
Posted: Wednesday 26 April 2017 20:15
by TapNL
Just updated to the new version. Works brilliant. Happy with the different maps possible.
Everything is set to get a tablet on the wall or to get a touchscreen monitor with a pi connected.
I favour the last option.
@rob: thanks again.
Posted: Wednesday 26 April 2017 20:21
by HansieNL
TapNL wrote:Just updated to the new version. Works brilliant. Happy with the different maps possible.
@rob: thanks again.
MagicMirror² The open source modular smart mirror platform.
https://magicmirror.builders/
Posted: Wednesday 26 April 2017 20:22
by mvveelen
Also updated to the latest (beta) from the new location, but I receive an error:
Domoticz error!
Please, double check the path in _HOST_DOMOTICZ-variable!
Nothing changed in the CONFIG.js and Domoticz is still running. What's wrong ??
Edit: read, read, READ !!
Moved config.js to the custom folder
Posted: Wednesday 26 April 2017 20:33
by bierlaagh
wizjos wrote:HansieNL wrote:I've a little different error: Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_moon_phase.lua: /home/pi/domoticz/scripts/lua/script_time_moon_phase.lua:118: attempt to call field 'round' (a nil value)
As did I
- Spoiler: show
-- Variables to customize ------------------------------------------------
local moonpicture = "MoonPicture" -- name of the uservar to write the name of the moonphase picture to
local checkvar = "MoonphaseCheck" -- name of the uservar to check if update is allowed
local checktime = 3600 -- check allowed every x seconds 3600 = 60 min. Check the wundergroud API limitation before changing this
local city = "<your town>" -- Your city for Wunderground API
local countryCode = "<YOUR COUNTRY CODE>" -- Your country code for Wunderground API
local idxmoonpercentage ='125' -- Your virtual moon percentage illuminated Device ID
local idxmoonage ='131' -- Your virtual moon age Device ID
local idxmoonphase ='132' -- Your virtual moon phase Device ID
local idxmoonrise='124' -- Your virtual moon rise variable ID
local idxmoonset='127' -- Your virtual moon set variable ID
local wuAPIkey = "<your key>" -- Your Weather Underground API Key
local DOMO_IP = "<your domo ip>" -- Domoticz ip address
local DOMO_PORT = "<your domo port>" -- Domoticz port
local tempfilename = '/var/tmp/phase.tmp' -- can be anywhere writeable
local debug=false -- false, true for domoticz log
function file_exists(path)
-- function to check if a file exists
local file = io.open(path, "rb")
if file then file:close() end
return file ~= nil
function timedifference(s)
-- function to determine the difference in seconds between the current time and a given one
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference
function may_update(device, timeelapsed)
-- function to check whether an update is allowed
return uservariables_lastupdate[device] == nil or timedifference(uservariables_lastupdate[device]) >= timeelapsed
time = os.date("*t")
url='http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json'
if (may_update(checkvar,checktime)==true) or (file_exists(tempfilename)==false) then
-- read API Wunderground
if debug then print("Moonphase - Collecting data from: "..url) end
os.execute('curl -s '..url..' > '..tempfilename)
-- NOTE: if the command above doens't work in your situation try
-- read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
-- instead! Thanks to EdKo66
file = io.open(tempfilename, "r")
s= file:read("*a")
s = (string.gsub(s, "%c+", ""))
file:close()
-- moonrise
moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
-- moonset
moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
-- percentage of moon illuminated
percentIlluminated = string.match(s, [["percentIlluminated":"(%d+)"]])
if debug then print("Percent:\t"..percentIlluminated.."%") end
-- age of moon since last new moon
age = string.match(s, [["ageOfMoon":"(%d+)"]])
if debug then print("Age:\t\t"..age) end
-- Phase of the moon
-- set the moonPhaseIcon to your appropriate icon number (8 x)
moonPhase = string.match(s, [["phaseofMoon":"(.-)"]])
if moonPhase=="New Moon" then
moonPhase = "Nieuwe maan"
is_waxing = true
if moonPhase=="Waxing Crescent" then
moonPhase = "Wassende halve maan"
is_waxing = true
if moonPhase=="First Quarter" then
moonPhase = "Eerste kwartier"
is_waxing = true
if moonPhase=="Waxing Gibbous" then
moonPhase = "Wassende maan"
is_waxing = true
if moonPhase=="Full" then
moonPhase = "Volle maan"
is_waxing = false
if moonPhase=="Waning Gibbous" then
moonPhase = "Afnemende maan"
is_waxing = false
if moonPhase=="Last Quarter" then
moonPhase = "Laatste kwartier"
is_waxing = false
if moonPhase=="Waning Crescent" then
moonPhase = "Afnemende halve maan"
is_waxing = false
-- calculate moonphase picture
if percentIlluminated == '0' then
n='00'
if waardecheck==false then
picnumber=math.floor(math.abs(percentIlluminated-100)/2)
n=tostring(picnumber)
if n.length==1 then
n='0'+n
picnumber=math.round(50+(percentIlluminated/2))
if picnumber == 100 then
picnumber=99
picture='moon.'..n..'.png'
if debug then print('Picture number: '..n..' '..'Picture name: '..picture) end
commandArray['Variable:'..checkvar]=moonPhase
commandArray['Variable:'..moonpicture]=picture
commandArray[1] = {['UpdateDevice'] = idxmoonphase.."|0|"..moonPhase}
commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..":"..moonriseMinute}
commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..":"..moonsetMinute}
commandArray[4] = {['UpdateDevice'] = idxmoonage.."|0|"..age}
commandArray[5] = {['UpdateDevice'] = idxmoonpercentage.."|0|"..percentIlluminated}
if debug then print("MoonPhase - Update not allowed: Difference is "..timedifference(uservariables_lastupdate[checkvar]).." seconds") end
Please confirm if this does the trick.
Sorry for the inconvenience!
Wizjos
Edit: typo in script fixed[/quote
partly conformed
Only
should be
Although my moon.50.png is New Moon and moon.00.png is a full moon
Posted: Wednesday 26 April 2017 21:10
by mvveelen
I was wondering: Is it possible to get the "var _SHOW_LASTUPDATE" per device?
For instance: I couldn't care less when the last time it was when I switch off a light, but it would be nice to see when a door sensor has been opened/closed.
Posted: Wednesday 26 April 2017 21:12
by EdwinK
bierlaagh wrote:
[qoute]Edit: typo in script fixed
partly conformed
Only
should be
Don't know about that. The moon looked good for me. Will see what Rob makes of it
Posted: Wednesday 26 April 2017 21:21
by robgeerts
We can better ask @madrian ... He created that part
Posted: Wednesday 26 April 2017 21:32
by madrian
What part? Moon part wasn't me.
