atlej
Domoticz version: Stable
Re: RE: Re: Domoticz app 2.0
Post by atlej »
galadril wrote:
pvl01 wrote:Still no "add" button in geofencing after the update off today. :cry:
Anyone else??
Because it's definitly working at my side now... ?
Same problem on Sony xperia Z1c , no add button. appversion 0.1.374(2439) android version 5.1.1. (14.6.A.1.236)
The previous update caused a serious battery drain. Before that the app and geofence was useful.
Atle
hofst01
Domoticz version: 2023.1
Post by hofst01 »
I just downloaded the latest version of Android (6.0.1) on my smartphone.
This solved the problem!
The button "toevoegen" was visible and I configured geofencing!
pvl01
Post by pvl01 »
atlej wrote:
Anyone else??
Atle
Updated to app version 0.1.376 (2461) today. Still no "add / toevoegen" button. (Android 5.1.1) Geofencing was one of the items I bought the premium for. It would be helpfull if the people who are experiencing this problem are updated by the developer, when or if this function will be available again.
galadril
Domoticz version: latest
Post by galadril »
pvl01 wrote: Updated to app version 0.1.376 (2461) today. Still no "add / toevoegen" button. (Android 5.1.1) Geofencing was one of the items I bought the premium for. It would be helpfull if the people who are experiencing this problem are updated by the developer, when or if this function will be available again.
I was on holiday last week.. please wait..
pvl01
Post by pvl01 »
It's working ok now. Thanks.
Wobbles
Domoticz version: 3.8153
Post by Wobbles »
It's working again yes but, now I see the battery drain again... Is this the way the new version works, starting the GPS lookup every x second?
Raspberry PI 1, Raspberry PI 2 & Raspberry PI 3, RFXCom, Z-Wave(Aeotec ZW090 Z-Stick Gen5), Philips HUE and using the premium android app
CronoS
Post by CronoS »
Got a quick question regarding NFC tags. I bought some NFC tags, my phone and also domoticz sees the NFC tag correctly, so I can configure them correctly, but it doesn't perform the corresponding action when I hold the tag to the phone? Does somebody have the same problem? Anyone knows how to fix it? I think its a bug or somesort :)
atlej
Post by atlej »
atlej wrote:
Anyone else??
Atle
Version 0.1.377(2480) and the add button is back.
The app still keeps the GPS constantly on when open and in foreground (expected?) and also when the app is open and inactive (in the background). I propose you change the behavior in this inactive state to the one you use for the background process (when the app is closed).
F.i. the "GPS Coordinates" app has this battery saving behavior.
Even better: keep GPS constantly on only when in the Geofence tab.
Atle
atlej
Post by atlej »
atlej wrote:
atlej wrote:
galadril wrote:
Anyone else??
Atle
Atle
Tried to use it by carefully closing the app when not in use, but still ended up with GPS locked on and empty battery again today.... I have to disable GeoFence for now, not useful for me until a sane use of the GPS is implementet.
Atle
nood
Post by nood »
CronoS wrote:Got a quick question regarding NFC tags. I bought some NFC tags, my phone and also domoticz sees the NFC tag correctly, so I can configure them correctly, but it doesn't perform the corresponding action when I hold the tag to the phone? Does somebody have the same problem? Anyone knows how to fix it? I think its a bug or somesort :)
Did you follow these instructions?
Maes
Post by Maes »
Since a couple of weeks I've also had some geolocation issues.
Both my girlfriend and me are using Samsung Galaxy S7 with Domoticz and we both have
1) Insane battery drain. GPS icon is constantly displayed in the top of the screen. (only when we are home..!)
2) Constant notifications that we "left the location" and "entered the location". Even though we have set the range to 300M AND on google maps we are clearly still on the exact same spot. This is quite annoying as all my blinds are going down, lights are going off and the thermostat is turned off even though we are still home ;)
sbaloo
Post by sbaloo »
I had the same behaviour as maes has for geofence.
More over i will like to suggest one feature.
When you have a big list of indicator in the main boad for example. If you are at the bottom at the list. You need to go on the top of the list to do a refresh.
Is it possible to add a refresh icon in the top tool bar in order to refresh easyly the list. Of course the list should not move to top when refresh. Just values should be updated
galadril
Post by galadril »
Im still improving the GPS.. I've pushed a new beta today..
Now the geofences should be recreated when you disable and re-enable your location sevices on your phone.
About the battery drain, it looks like it's the dwelling option that i've enabled.. Ill turn it off in the next beta :)
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
is there a way to change the evotouch status? (Auto, Away, Eco, Day off,...)
I can only see on witch status the evotouch is but i cannot change it.
Kind regards
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
PSYCHOTIC
Post by PSYCHOTIC »
Any update on the widgets part?
Thx
galadril
Post by galadril »
PSYCHOTIC wrote:Any update on the widgets part?
Thx
I've been testing, they work good at my side ;)
galadril
Post by galadril »
Lebo2d9 wrote:is there a way to change the evotouch status? (Auto, Away, Eco, Day off,...)
I don't have a evotouch, and that part of the app is not implemented by me...
Maybe you could provide me a test account on your system for that evotouch to look at it?
galadril
Post by galadril »
This is fixed in the next beta!
bueno79
Domoticz version: 4.9700
Post by bueno79 »
hi,
first thanks a lot for this apps. So usefull and very good. Really happy to pay the premium. here is some feedback to help you to improve the apps :
- geofence : yes sometime I have enter, leaving, enter leaving,...
- geofence : yes I have to charge the phone everyday...
- voice : we cannot assign to a voice command a scene. Could it be added in a next release ?
- switch : I have a switch with Off delay in Domoticz. This OFF delay is not reproduce in Android Apps. So the switch stay ON.
- plan : not possible to see the floor plan ? We spend time to get nice map for our wife...could be great.
and a last one : do you plan to do the same apps for Apple ?
best regards and Very good job. Thx a lot guyz,
Bueno
barbaar
Post by barbaar »
Since the latest beta (installed yesterday), the app always crashes when opening the settingsmenu....
Using a Nexus 5x with all available updates installed..
