Page 74 of 120
Re: Domoticz app 2.0
Posted: Wednesday 15 February 2017 22:45
by Skef
Exactly the same here... No geofencing options in the app available...
Posted: Thursday 16 February 2017 10:03
by pro2call
Here also
Posted: Thursday 16 February 2017 11:43
by galadril
Skef wrote:Exactly the same here... No geofencing options in the app available...
Hmm i need to look into the geofence switch issue.. (can't reproduce it at this moment..)
Changelog for latest release:
- Improved notifications (subject/body/prio)
- Clear notifications setting
- Enable/Disable Events
- Enable/Disable Geofences
- Rebuild Geofence services
- New location screen for adding Geofences
- Change dimmer layouts
- Fixed favorite like button
- Improve Temperature rows
- Improve settings import/export
- Updated libraries
- Various fixes
Posted: Thursday 16 February 2017 13:12
by Skef
I also have a problem when I go to the server settings. I use the advanced settings to have a different server-address when connected to the home wifi network.
I do see the toggle there that I use another server-address, but for some reason the panel with the config is not displayed. This is also the case with the geofencing: the toggle button is there, but when you enable it the panel with the settings doesn't show up.
So it might be a more general bug, that toggles aren't working anymore?
Posted: Thursday 16 February 2017 13:39
by NiklasO
So, the background on all my Domoticz widgets goes back to white almost every time I update the beta app. Why? I have to remove them and place them again to get my dark background back and I have like 15 widgets I need to change every time. Could you set the default background in the settings for the main app or something?
Posted: Thursday 16 February 2017 13:51
by galadril
pro2call wrote:Here also
Found the bug.. new version on tha way
Posted: Thursday 16 February 2017 14:23
by Skef
galadril wrote:pro2call wrote:Here also
Great work! Thank you!
Posted: Thursday 16 February 2017 17:36
by pvl01
Same over here on my galaxy Xcover 3. Even after today's update, no Geofencing. I can toggle the switch, but nothing happens. On my galaxy TAB S it works ok and see the "add" button to enter a location. Perhaps someting to do with the screen resolution. ( on my xcover 3 800 x 480)
Posted: Thursday 16 February 2017 17:45
by sbaloo
Posted: Thursday 16 February 2017 19:41
by PSYCHOTIC
Please fix the widgets i keep having problems with them.
All the below widgets are switches now they have the alarm status..
Thx
After a reboot they look different...
SSL problem after latest update
Posted: Thursday 16 February 2017 20:38
by pvklink
I have two payed premium versions running on two android devices. One is working well with HTTPS/SSL, the other is only working with HTTP and did work before the latest upgrade with HTTPS. I tried everything, clear cache, deleted the entire app.....
The only thing that was different when upgrading, was that the device that is working with HTTPS asked for a new certificate when installing the upgrade...The other device didnt ask for an update of the certificate...
The error with HTTPS is: connection time out
Posted: Thursday 16 February 2017 23:17
by Brutus
Its working again. Nice update on the google maps for geofencing.
Re: RE: Re: Domoticz app 2.0
Posted: Friday 17 February 2017 2:35
by Skippiemanz
Brutus wrote:galadril wrote:pro2call wrote:Here also
Anyone else experiencing that you can't select virtuele switches etc on the New geofancing setup?
Posted: Friday 17 February 2017 11:18
by pvl01
Still no "add" button in geofencing after the update off today.
Posted: Friday 17 February 2017 11:23
by galadril
pvl01 wrote:Still no "add" button in geofencing after the update off today.
Anyone else??
Because it's definitly working at my side now... ?
Re: RE: Re: RE: Re: Domoticz app 2.0
Posted: Friday 17 February 2017 12:16
by Skippiemanz
galadril wrote:pvl01 wrote:Still no "add" button in geofencing after the update off today.
Anyone else??
It's working here! But like mentioned before i can't choose from al my switches. Just a few and definetly no virtual switches
*EDIT* solved after restart of phone/app!
Posted: Friday 17 February 2017 13:57
by pvl01
Skippiemanz wrote:galadril wrote:pvl01 wrote:Still no "add" button in geofencing after the update off today.
Anyone else??
I'am sorry, but still no "add" button after enable geofences. Installed new version Version 0.1.374 (2439) and restarted phone.
Posted: Friday 17 February 2017 21:48
by Wobbles
Anyone else??
I have the same issue after the last update (now version 0.1.374). When I try to enable Geofencing no add button (I still see the fences I added before) and geofencing is disabled again.
I have cleared the cache, reinstalled the app, rebooted the phone after each step but still not working.
It was working until I disabled and enabled geofencing, from that point on it was not possible to add a new geofence or have it enabled again. I did this because after the update it was draining my battery for starting to request the GPS position every 10 seconds...
hofst01
Posted: Saturday 18 February 2017 13:42
by hofst01
I have the same issue too on version 0.1.374 (2439). Android on Samsung S5 mini. After activating the switch for Geofencing nothing appears. On my Samsung tablet in the right corner a button "Toevoegen" appears and I can add a geofence. On my smartphone there is no button "Toevoegen". I think this is the issue. Can this be solved?
Posted: Wednesday 22 February 2017 13:23
by PSYCHOTIC
PSYCHOTIC wrote:Please fix the widgets i keep having problems with them.
Thx
Guys any update on how to fix this ?
