homebridge-edomoticz Plugin
GCB2016
Domoticz version: V3.9208
Re: homebridge-edomoticz Plugin
Post by GCB2016 »
Thanks for your quick response. Unfortunately I am not really familiar with scripting. Is it supereasy to do (in this case)? If so, can you point me into a direction?
A quick Google pointed me here (https://www.linuxquestions.org/question ... ng-329962/), but I am have no idea if this is somewhat correct. And even then: what to do next? Where to place the script? I guess I need a CRON-job to check it every 10minutes or so? Thanks for helping me out!
#! /bin/bash/
if [ "$(pidof homebridge)" ]
then
  # running
  # not running
fi
Marci
Domoticz version: 3.8153
Post by Marci »
poudenes wrote: Friday 26 January 2018 16:58
GCB2016 wrote: Friday 26 January 2018 14:22 Hi everyone (marci?), is it possible to have a switch in Domoticz that tells you if Homebridge is running or not?
You can create a bash script that check status of Homebridge and then update a TEXT Device
Or use Monit service
See https://makandracards.com/makandra/1145 ... using-curl & https://www.domoticz.com/wiki/Domoticz_ ... Fswitch_on
Marci
Post by Marci »
Have just resynced the git repo to NPM, nudging version to 2.1.0
This gives you wallsocket / light / fan / switch icons depending on Switch Icon specified within Domoticz.
Marci
Post by Marci »
rjblake wrote: Thursday 04 January 2018 23:11 Nobody else having this issue? I have tried on both a RPi3 and Linux installation and the problem is the same on both. Node 8.9.3 (on Linux), Node 7.10.1 (on RPi3). MQTT.js is version 2.14.0 and Mosquitto is version 1.4.10
If I change MQTT to 0, problem stops. Given all the constant restarts, the Homekit functionality becomes unusable.
Choose an MQTT Client, install it on your desktop, subscribe to the domoticz mqtt stream, find the message causing the error & post it. https://www.hivemq.com/blog/seven-best- ... ient-tools
Can’t begin to diagnose without knowing what the specific MQTT message is that’s causing it or what’s sending it.
Nautilus
Post by Nautilus »
Marci wrote: Friday 26 January 2018 22:27 Have just resynced the git repo to NPM, nudging version to 2.1.0
Thanks for the update! One problem though, now getting this error:
/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:1260
					if (this.image.indexOf("Fan") > -1)
TypeError: Cannot read property 'indexOf' of undefined
    at eDomoticzAccessory.getServices (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:1260:21)
    at eDomoticzAccessory.publishServices (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:79:23)
    at new eDomoticzAccessory (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:71:7)
    at eDomoticzPlatform.configureAccessory (/usr/lib/node_modules/homebridge-edomoticz/index.js:244:21)
    at Server._configCachedPlatformAccessories (/usr/lib/node_modules/homebridge/lib/server.js:352:24)
    at Server.run (/usr/lib/node_modules/homebridge/lib/server.js:88:8)
    at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:40:10)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:635:30)
    at Object.Module._extensions..js (module.js:646:10)
edit: reverted back to 2.0.11 and working ok again
Marci
Post by Marci »
Should be fixed now...
Nautilus
Post by Nautilus »
Thanks, working now! :)
Marci
Post by Marci »
Update v2.1.2 pushed out to NPM - fixes Eve custom sensor recognition - Eve Weather now discontinued - devices using the old Eve Weather UUIDs blocked. Characteristics remade to align to current Eve recognised types: Visibility, WindSpeed, WindDirection, Pressure/Temp/Humidity, Rainfall.
As UUIDs have changed for device characteristics, if changes aren’t reflected within a few minutes after restarting homebridge, remove your ~/.homebridge/accessories folder and restart (to empty the cachedAccessories). This shouldn’t affect roomings etc.
Marci
Post by Marci »
Update 2.1.4 pushed out to NPM - excludeDevices now works on the device’s IDX value rather than ID value. Reason? ID value is not unique. Go take a look at settings > devices, sort by the ID column and see for yourselves (may not be the case for everyone, but I certainly have a PILE of devices all with identical IDs). Not sure why original author of this portion of code chose to use ID, so I’ve changed it over to use IDX. Refactor your config.json excludedDevices array as appropriate, grab the latest ver via npm.
I’m still waiting to hear back from those with the issue where excludedDevices continued to appear to see whether this change resolves their problem.
islandman
Post by islandman »
Thanks for the great Service, now hopping for button support :D
Marci
Post by Marci »
S'next on the list...
islandman
Post by islandman »
Marci wrote: Tuesday 30 January 2018 20:28 S'next on the list...
C O O L
Nautilus
Post by Nautilus »
Marci wrote: Saturday 27 January 2018 14:25 Should be fixed now...
Nautilus wrote: Sunday 28 January 2018 22:29 Thanks, working now! :)
I guess I spoke too soon, now I'm getting this (almost the same as last time):
/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:1263
    at eDomoticzAccessory.getServices (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:1263:21)
    at eDomoticzPlatform.configureAccessory (/usr/lib/node_modules/homebridge-edomoticz/index.js:245:21)
Could it be something in my setup as no one else has reported this? 2.0.11 is the last version I can confirm working.
Marci
Post by Marci »
Nope - my fault. I’d added a check one place when I needed to add it in two... gizza mo... (but yes, you do have an obscure device being detected as a switch that doesn’t have an image set in it’s JSON output, which I haven’t come across before).
Marci
Post by Marci »
npm update to 2.1.5 - should be fixed again!
Nautilus
Post by Nautilus »
Now confirmed to be working, thanks!
Marci
Post by Marci »
Those waiting for Push buttons (single tap / dbl tap / long tap): see viewtopic.php?f=36&t=22015&p=169677#p169677 and comment there.
Marci
Post by Marci »
Folks having issues with blinds showing incorrect current position on wake: Found something that may have been causing an issue to not retrieve the status into the correct characteristic. So (as well as ensuring you have MQTT correctly set up and activated so that changes are pushed in realtime from Domoticz to Homebridge, as it appears many of you don’t) update to the latest version (2.1.7) via npm, see if things are working better, and report back here.
sudo npm update -g homebridge-edomoticz
Then restart homebridge.
Marci
Post by Marci »
Update 2.1.9 pushed out to NPM - Maps UV Index sensors (eg: DarkSkies) with subtype of UVN128,UV138 to the Eve-recognised characteristic 05ba0fe0-b848-4226-906d-5b64272e05ce. Fixes missing break cases.
Then restart Homebridge.
lsp242
Domoticz version: 16960
Post by lsp242 »
I installed the edomitcz plugin, on mij domoticz only P1-usb is connected.
When I start homebridge, the gas and electra meter are not detected, and i get this message after start:
events.js:183
      throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
    at Object._errnoException (util.js:1022:11)
    at _exceptionWithHostPort (util.js:1044:20)
    at Server.setupListenHandle [as _listen2] (net.js:1351:14)
    at listenInCluster (net.js:1392:12)
    at Server.listen (net.js:1476:7)
    at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
    at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
    at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:607:16)
    at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:126:16)
    at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:96:10)
In my config.json is the mqtt set on 1, but i didnt install any mqtt, do i have to?
When try to edit the config.json with nano i get the message: permission denied..
can anyone put me on the right track.. The installation on de raspberry is done on a edomoticz image.
Gadget freak - Domoticz beginner - ios and android user
