Page 73 of 114
Posted: Wednesday 27 June 2018 14:02
by salvacalatayud
PM sent
Madgeni wrote:thats not good - had a quick check, can you access your Domoticz host over the internet? it's timing out.
Enviado desde mi Redmi 4X mediante Tapatalk
Posted: Wednesday 27 June 2018 14:22
by salvacalatayud
I can access over Internet without problems, only get an invalid ssl certificate advice
Posted: Wednesday 27 June 2018 14:49
by Madgeni
Ok, that's weird, your host is now showing as available. Try again?
Posted: Wednesday 27 June 2018 15:30
by salvacalatayud
Madgeni wrote: Wednesday 27 June 2018 14:49 Ok, that's weird, your host is now showing as available. Try again?
Still the same
Posted: Wednesday 27 June 2018 15:50
by salvacalatayud
Now it say "sorry I couldn't reach controlicz"
Posted: Wednesday 27 June 2018 15:55
by Madgeni
I'm working on something, so there will be very small outages (it's down for 2-5 seconds per release).
Posted: Wednesday 27 June 2018 16:04
by salvacalatayud
Thanks Madgeni, now it is working!!
The user i had created for Controlicz didn't have permission, only could read. Changed to regular user (not admin) and works perfect.
Posted: Wednesday 27 June 2018 22:20
by jpvaneijk
jpvaneijk wrote: Thursday 21 June 2018 18:03 Thanks for the update Madgeni. I'm trying to understand what the implications could be for the situation I'm in.
My problem you solved in this post (june 13) seems te be back: http://www.domoticz.com/forum/viewtopic ... 24#p183424
All the hubs activitys's seem to by 'Light' again in Controlicz in column Google/Alexa.
I know you can fix this, you waved your magic wand before.
Is it something I did? How to permanently solve this?
I know you'll be bellyshaking when your in my home when I say: Hey Google, turn all the lights on :mrgreen: :lol: :D
Hi Madgeni,
Had lots of trouble updating to the latetst Domoticz. Had to reinstall serveral times.
Finaly it's all up-n-running again but now I've got the same problem again as before.
Yoy promissed me that couln't happen again, now didn't ya? :lol:
Thanx for your hard work man!
Posted: Thursday 28 June 2018 10:51
by Madgeni
jpvaneijk wrote: Wednesday 27 June 2018 22:20
Hi Madgeni,
All fixed - it was an issue with one of your Selector switches :)
Posted: Thursday 28 June 2018 17:31
by jpvaneijk
Thanks verry much Madgeni. All fixed and I'm verry, verry happy again!
Posted: Thursday 28 June 2018 21:15
by annegerben
Hi Madgeni/Nick,
I think since a week a get a message on my google home that "controlicz is not available right now."
Also when I logon to the website and click test connection I have to logon again.
I've been using controlicz since december '17 and worked fine until now, can you help me to get this fixed?
thanks in advance.
Posted: Friday 29 June 2018 9:17
by Madgeni
Hi there - can you mail me from your Controlicz profile and i'll take a look for you. Can you also try unlinking/relinking in Google Home?
Posted: Friday 29 June 2018 9:26
by Madgeni
Quick update:
Blinds and sensors are coming soon! Blind coding done - sensors when i get some documentation that makes sense :S
Posted: Friday 29 June 2018 10:36
by annegerben
Madgeni wrote: Friday 29 June 2018 9:17 Hi there - can you mail me from your Controlicz profile and i'll take a look for you. Can you also try unlinking/relinking in Google Home?
mail sent.
unlinking/relinking in Google Home I will try when I'm home again.
Posted: Friday 29 June 2018 10:47
by EdwinK
Trying to set this up. Already had contact with you. Now keep getting the 'check your connection setup' message. Tried another ddns site (no-ip), but still no luck.
Posted: Friday 29 June 2018 12:26
by Madgeni
EdwinK wrote: Friday 29 June 2018 10:47 Trying to set this up. Already had contact with you. Now keep getting the 'check your connection setup' message. Tried another ddns site (no-ip), but still no luck.
Assume this is fixed now?
Posted: Friday 29 June 2018 12:27
by Madgeni
annegerben wrote: Friday 29 June 2018 10:36
mail sent.
if you're on Android, you can do it from Google Assistant
Posted: Friday 29 June 2018 12:43
by EdwinK
Madgeni wrote: Friday 29 June 2018 12:26
Nope, not yet. Still trying though.
Posted: Friday 29 June 2018 12:46
by Madgeni
mail me if you need support, i can check the logs, see what's happening
edit: try login page, rather than basic authentication - does that make any difference?
Posted: Friday 29 June 2018 12:55
by EdwinK
Going to try that :)
Edit: Nope, didn't work. One time I got 'check username and password' (or something close), but other then that nothing. Might be a problem with the DDNS-servers, but I can't imagine both NO-IP and Duckdns having problems. Port 443 is open.
Screen Shot 2018-06-29 at 10.39.22.png (21.24 KiB) Viewed 2026 times
Screen Shot 2018-06-29 at 12.54.42.png (72.38 KiB) Viewed 2026 times
