Locked
robgeerts
Domoticz version: 3.7067
Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
Well, I submitted a POSSIBLE fix half an hour ago (or something)...
I dont know if it helps in your case but worth a try...
EdwinK
Post by EdwinK »
Here too.
b00n
Post by b00n »
Same result :(
To be sure do you have a link to get the api key ?
mvveelen
Post by mvveelen »
Downloaded the latest 2 minutes ago, overwritten all files, except the config: same problem on multiple devices.
sonar
Domoticz version: 3.8153
Post by sonar »
traffic map is working fine here.
It is important to not place the long, lat and zoomlevel between ticks ' in the config file.
var _MAPS_LATITUDE = 52.090737;
var _MAPS_LONGITUDE = 5.121420;
var _MAPS_ZOOMLEVEL = 11;
robgeerts
Post by robgeerts »
Edit(never mind)
b00n
Post by b00n »
sonar wrote:traffic map is working fine here.
HERO !!! :D :D :D :D
Works like a charm now THNX
robgeerts
Post by robgeerts »
Why did I not think about that!!
b00n
Post by b00n »
Easy to forget i think :?
mvveelen
Post by mvveelen »
Not the solution for me. I'm not using 'ticks', so still the same problem.
Rob, I've sent you the Teamviewer credentials.....
EdwinK
Post by EdwinK »
Works, thanks :)
b00n
Post by b00n »
Is it possible to set last update for specified blocks like:
blocks[21]['lastupdate'] = true
htilburgs
Post by htilburgs »
sonar wrote:After todays pull the up and down arrow of my blinds are positioned on top of eachother.
+1... Already been looking in the CSS, looks like has someting to do with position: but can't find the exact reason or solution
Hardware:
robgeerts
Post by robgeerts »
Together with @mvveelen I did fix a little bug that caused the map wasnt loading for some people!
Download the latest version!
mvveelen
Post by mvveelen »
Thanks Rob, much appreciated !
robgeerts
Post by robgeerts »
Its because the <li>-tags have position absolute and zindex 9999 (needed because otherwise a small part of the top button wasnt clickable because of the rotated stop button...) But, at my tablet, it shows the buttons correctly.... could it be cache problem?
htilburgs
Post by htilburgs »
Nope, no chache....
Can it be, it's missing class .btn.btn-number.min in css?
Hardware:
sonar
Post by sonar »
robgeerts wrote:Could it be cache problem?
No, I don't think so. Same problem in Edge, Firefox, Incognito mode, etc.
robgeerts
Post by robgeerts »
It turned out the trafficmap was also not working on a second screen.... just pushed a fix for this...now going to bed ;)
HansieNL
Post by HansieNL »
robgeerts wrote:It turned out the trafficmap was also not working on a second screen.... just pushed a fix for this...now going to bed ;)
Working on 2nd screen here.
Blah blah blah
Locked
