Pass2PHP
ropske
Domoticz version: V3_8394
Re: Pass2PHP
Post by ropske »
but still a shitload of gas is being used.
like in the morning, i see i'm using around 3m³ already
and i'm setting the temperature of living to 22°C from 4:30 till 6:00
kitchen to 22°C from 4:30 till 6:50
and bathroom to 23°C from 5:00 till 6:40
for me temperatures can be a lot lower, but the wife is complaining its too cold :oops:
ropske
Re: Pass2PHP
Post by ropske »
i also need to mention that the house were we live now is a 'koppelbouw' in Dutch :p
and the other house they are renovating it now, but it's completely open now, no doors, no windows. So i also think/hope, when the renovation from the house beside us is done, we also will have a warmer feeling from that house?
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
OMG 10m³ per day? :o
For the last 30 days I have an average of 2,4m³ per day.
The 'biggest' day was 4,37m³.
Don't think the other house has much to do about it. There should be isolation between the two.
@sinze: damn all that logging and graphs :mrgreen:
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
My GAS usage ;-)
Egregius - GAS.PNG (124.03 KiB) Viewed 8099 times
And yes GRAPHING gives insight also with help of SPLUNK (free).
I discovered using that monitoring my network was having issues with DNS ;-) so definitely logging does help finding issues.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
ropske
Re: Pass2PHP
Post by ropske »
@sincze, so it seems you got an average of +-7m³/day now
You also control it with zwave radiator valves?
sincze
Re: Pass2PHP
Post by sincze »
Ha no, I've floor heating that was manually adjusted per room.
-> By manually adjusting the flowrate (waterzijdig inregelen).
So if the temp in the livingroom is like 20 degrees the bathroom is 21-22 and the other rooms 18/19 or 20.
Floor heating takes a lot of time so I keep the temp 20 during the day / 19 during night time... but if it freezes outside it stays at 20. All done via Opentherm.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ropske
Re: Pass2PHP
Post by ropske »
i'm reading a lot times you guys are using influxdb and grafana also?
you guys got an installation tutorial where i can't mess up with? :D
and how do you work with it? insert data ,...
thanks!
sincze
Re: Pass2PHP
Post by sincze »
Yes Grafana and Influx / telegraf are my friends.
Are you open for dockers ?? ;-)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ropske
Re: Pass2PHP
Post by ropske »
what do you mean with dockers?
I'm running now domoticz on an intel nuc with proxmox
sincze
Re: Pass2PHP
Post by sincze »
ropske wrote: Tuesday 08 December 2020 17:53 what do you mean with dockers?
VM's sometimes are a bit too heavy. So dockers to the rescue.
https://docs.docker.com/get-docker/
https://runnable.com/docker/install-doc ... windows-10
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
A good addition thanks to @Waaren at viewtopic.php?p=264686#p264686
With that lua script a lot less calls are made to the webserver and the pass2php script doens't need to check for them anymore.
ropske
Re: Pass2PHP
Post by ropske »
First of all, a Happy newyear to everyone and may everyone have a good health,... yeah same shit like every year :D
A question regarding how you guys store data to influxDB, you do it in the php script?
Or you let Domoticz handle it? (with https://www.domoticz.com/wiki/HttpLink)
kispalsz
Re: Pass2PHP
Post by kispalsz »
I have a little problem.
I use several Ikea Tradfri remote controls, 5 buttons, 9 functions. https://www.ikea.com/hu/hu/p/tradfri-ta ... -30443124/
All of its buttons work with PASS2PHP, only the up (+) and long up (L +) buttons do not.
When the LUA script runs, it still has a "+" sign, but if I call the PHP file using curl or wget, it will already be there, with an empty character going through. " " character instead of "+" and "L" character instead of "L +".
They lose the + character.
Does anyone use such a remote control?
Egregius
Re: Pass2PHP
Post by Egregius »
@ropske: I don't use influxdb, think you need to be with Sincze for that/
@kispalsz: can you post the code that you're using for the Tradfri? And how do you get that signal in Domoticz?
kispalsz
Re: Pass2PHP
Post by kispalsz »
Egregius wrote: Monday 04 January 2021 7:09 @ropske: I don't use influxdb, think you need to be with Sincze for that/
If I put this it in the LUA file before calling pass2php.php it will work properly. I haven't looked at how many ms slowdowns this operation will result :)
if s=="+" then s="%2B" end
if s=="L +" then s="L %2B" end
for d,s in pairs(devicechanged)
do
os.execute('wget -O /dev/null -o /dev/null "http://127.0.0.1/secure/pass2php.php?d='..d..'&s='..s..'" &')
commandArray={}
Egregius
Re: Pass2PHP
Post by Egregius »
I would say you need to search either 'url encode' or 'html entities'.
But I doubt that any function or framework will be faster than your solution.
One tiny thing that you can change:
do
elseif s=="L +" then s="L %2B" end
commandArray={}
Re: Pass2PHP
Egregius wrote: Monday 04 January 2021 17:24 I would say you need to search either 'url encode' or 'html entities'.
do
commandArray={}
There is one end too many in that code
If it is a urlEncode type of issue I would expect the space also to be a problem (and some other chars) but normally this will be handled by wget when using double quotes around your url string.
Below mod might prevent some calls to os.execute
local function isRealSensor(name)
   return otherdevices_idx[name]
for d, s in pairs(devicechanged) do
	if isRealSensor(d) then
		if s == '+' then s = '%2B' elseif s == 'L +' then s = 'L %2B' end
Re: Pass2PHP
ropske wrote: Sunday 03 January 2021 17:25 First of all, a Happy newyear to everyone and may everyone have a good health,... yeah same shit like every year :D
See the Wiki: https://www.domoticz.com/wiki/Influxdb
For influxdb to grafana there are a lot of tutorials online.
ropske
Re: Pass2PHP
Post by ropske »
ok, thanks for all the information about InfluxDB.
Now i'm just wondering, Sincze,told about installing InfluxDB into a "docker".
This docker software is something i need to install on my VM?
But why can't i just install InfluxDB then directly in my linux VM where domoticz is running and all other scripts (pass2php ,...)
I have another VM running with windows10 beside it, should i need to install docker then on Windows10 and influx and grafana on there?
Thank you
Egregius
Re: Pass2PHP
Post by Egregius »
If you should decide to update proxmox to version 7 you'll probably need to make an adjustment in the config file:
in /etc/pve/nodes/proxmox/lxc/100.conf
Change:
lxc.cgroup.devices.allow: c 166:* rwm
lxc.cgroup.devices.allow: c 188:* rwm
lxc.cgroup.devices.allow: c 189:* rwm
To:
lxc.cgroup2.devices.allow: c 166:* rwm
lxc.cgroup2.devices.allow: c 188:* rwm
lxc.cgroup2.devices.allow: c 189:* rwm
