Page 72 of 120
Re: Domoticz app 2.0
Posted: Monday 23 January 2017 16:50
by webpatrick
webpatrick wrote:if 'Added 2th Percentage to Graphs' in releasenotes means you have added the v2 to the graph, it still doesn't work. I still only have one value, and it looks like it's the other one (night)
Could you also set 24 hours style to the x-axis labels or use the device default settings for time?
Nevermind... It works! Good Job. I already bought the Pro version ;)
Posted: Monday 23 January 2017 16:51
by galadril
Thanks for assisting me on this matter
Posted: Monday 23 January 2017 19:02
by dressie
Is it possible to get a widget for a switch used in Toon scenes?
Posted: Tuesday 24 January 2017 14:03
by BazsoDombiAndras
Feedback related to the new 1x1 widgets:
1. Please make it possible to add custom names (descriptions/titles) to each widget, because many times the name of the associated Domoticz switch is too long and does not fit into 1x1.
2. The Security panel widget (4x2) is gigantic. Pls make it fit into 4x1.
Posted: Tuesday 24 January 2017 14:07
by piokuc
Is any chance to add option to center name text under widget? Now is aligment to left and it no looks good.
Posted: Tuesday 24 January 2017 21:09
by jhenrikb
Hey!
Is widgets going to be expanded further?
Android seems like the perfect platform to customize a very good looking domoticz interface on.
Right now its on/off swtiches and Security panel. Is things like Temp-charts, dimmers etc planned to be integrated?
John
Posted: Thursday 26 January 2017 14:58
by piokuc
Today i install latest beta version and i found a bug for dimmers.
Before turn ON my switch look as i show on screen red frame:
When i turn it ON it looks no good. Slider is not set in one line in other slider button and text name switch is also in not the same line as other. Look on screen:
My suggestion is to modify look for dimmer as i show on screen. I use bigger slider dimmer to better use on smartphone. Look and what do you mean ?
For me it is more friendly.
Posted: Friday 27 January 2017 15:50
by piokuc
Thanks for latest beta with change layout dimmer. Looks very very good.
I think that also good change will be change layout temperature. Because when temperature is about 0 C it no looks good. I think that temp should be only show as digit number with symbol C or F.
Edit
I found a bug. When i try open temperature app is stopping.
Also when i go by plan to room switch button is in color green.
But when i go from menu to switches color button switche is black. I think about button which is ON.
Posted: Friday 27 January 2017 17:53
by jjnj
The new dimmer is way better, thank you for that.
Will it be possible to remove the colour button for RGBW devices and only have to dimmer slider + on/off
Sent from my LG-F800L using Tapatalk
Posted: Friday 27 January 2017 18:23
by piokuc
I found next bug. For some temp not show graph icon. Looks:
Posted: Saturday 28 January 2017 11:53
by Shaggie_NB
Please stop changing the widgets!! (after putting the 2x1 back)
I have four pages of widgets on my Phone. Mostly using the 2x1 size. But this one seemes to dissapear en then come back and now its gone again.
It is very nice working with the widgets but is it possible to update the widgets insted of introducing a new one and get rid of another?
Posted: Monday 30 January 2017 12:07
by bash
Since last (beta) updates the temperature tab is not working anymore and the app crashes when opening the tab.
All the other tabs are working fine.
Android 7.
Posted: Monday 30 January 2017 18:11
by piokuc
Still latest beta no open tab temperature and show crash.
Posted: Monday 30 January 2017 20:10
by RFMuser
Since the new update crashes when opening temperature page. Widgets show nothing see attachment.
Posted: Monday 30 January 2017 22:40
by NiklasO
1x1 widget for temperatures would be nice..
My widgets background changes almost every time I update the beta app. I have to remove and add them again to get them back to the background I want.
Posted: Tuesday 31 January 2017 10:48
by piokuc
For me widgets is ok. But also good will be add widget for temp 1x1.
Edit
Latest beta 0.1.364 (2229) still tabs temperature can not open. After try app crashes.
Posted: Tuesday 31 January 2017 16:25
by galadril
piokuc wrote: Latest beta 0.1.364 (2229) still tabs temperature can not open. After try app crashes.
still having issues? can you share me a viewer account on your system?
Best Regards
Posted: Tuesday 31 January 2017 16:56
by piokuc
Yes still is problem. Account viewer i can send you today evening. Send you priv msg.
Posted: Wednesday 01 February 2017 12:50
by piokuc
Today i download latest beta and now tab temperature works OK. Big THANKS
But i found next some issue. Some device temp show icon with light blue scale but some with dark blue scale. Look on my screen:
Posted: Sunday 05 February 2017 23:06
by PSYCHOTIC
NiklasO wrote:1x1 widget for temperatures would be nice..
Got tha same prob and not running beta. ;)
Its a bitch to put them back every time. :D
