Page 71 of 120
Re: Domoticz app 2.0
Posted: Tuesday 17 January 2017 20:53
by ultratoto14
galadril wrote:
ultratoto14 wrote: Do not know if it was asked before but i have some problem with the axes on the graphs.
I added a screenshot of my wind graph (i'm french so Wind = Vent) and the axes labels are not readable.
Ill at it to the list
Thanks a lot Galadril,
Just updated the app and found readable labels. Big thank you.
Just a quick question about the implementation. I modified my domoticz sources to be able to send specific notifications through json API on domoticz.
It seems that domoticz is using some kind of subsystems to classify the notification.
Do you know what is the used notification subsystem to send notification to your andoird app ?
I want to send notifications only to your app to see it only on my smartwatch.
Thanks again.
U.
Posted: Tuesday 17 January 2017 21:13
by Jordyboytjuh
Hi Galadril, After updating the domoticz app with latest beta, my blinds have no option to "stop". Only up and down, before (two weeks ago or something) I could stop them as well. Is it a bug? Thanks a lot! Love the app!
Verstuurd vanaf mijn SM-G930F met Tapatalk
Posted: Tuesday 17 January 2017 21:54
by piokuc
In latest beta widget 1x not working. I can only add 3x1 widget.
Today i install again new latest beta and still widget 1x1 is not available. Only 3x1 and security.
Edit
Now on latest beta widget 1x1 works ok. But...
- text under widget icon should be center
- widget should have dark, light, trasparent dark, transparent light background. Now has only dark and light.
Posted: Thursday 19 January 2017 10:30
by webpatrick
Hi galadril,
My system is behind a username / password, so an url will result in an error, but I have attached the json results for day and week.
galadril wrote:
webpatrick wrote:I have a smart meter, with an P1 cable connected to my Synology NAS.
Hi patrick,
can you send me the url that domoticz uses to get the log, for example:
http://ip:port/json.htm?type=graph&sensor=counter&idx=58&range=week
and how the json looks like, for example:
   "ValueQuantity" : "",
   "ValueUnits" : "",
   "result" : [
         "d" : "2017-01-10",
         "v" : "2.000"
         "d" : "2017-01-11",
         "v" : "4.000"
         "d" : "2017-01-12",
         "v" : "1.000"
Posted: Thursday 19 January 2017 16:58
by galadril
piokuc wrote: - text under widget icon should be center
Should be in the next release
by galadril
webpatrick wrote:""
Thanks for the json, i've tried to add v2 to the graph in the next release
Posted: Thursday 19 January 2017 16:59
by NiklasO
Updated just now and can't add widgets again. Exactly the same problem as before.... :?: :?:
Re: RE: Re: Domoticz app 2.0
by galadril
roiz wrote: I'm using light version .. is that might be the issue?
Please check if it's still in the next version
Posted: Thursday 19 January 2017 17:02
by galadril
NiklasO wrote:Updated just now and can't add widgets again. Exactly the same problem as before.... :?: :?:
One of the previous beta's had the check disabled fully.. I've reenabled this check.
It verified 2 point
1) In the app installed from the play store
2) Does the apk has my signature/key
to test, please fully remove the app cache/data.. then remove the app.. and install from the play store.
Don't import previous created settings but reconfigure from the start.
I've tested that piracy check and it worked on 5 different devices
Posted: Thursday 19 January 2017 17:18
by NiklasO
It verified 2 point
I'll try.
1. Yes, installed from Play Store (beta) and shows up as bought as it should. I have the transaction and everything in my history of course.
2. Sorry, what? ;)
Edit: It worked! Not nice to reconfigure everything but I can live with it. ;) Last time I tried the same I imported settings from the old install.
Posted: Thursday 19 January 2017 18:17
by freddeolss
Why no 1x1 widget for temp devices ? Looks possible to resize bigger if needed but not smaller than the added size on widget when added.
Skickat från min GT-I9505 via Tapatalk
Posted: Thursday 19 January 2017 19:57
by piokuc
Now background widget is ok. But text is still not center under icon. And now widget 1x1 and 3x1 not working. When i clickit no reaction. I add zwave light and try turn on and when i click it is not turn on.
Posted: Friday 20 January 2017 13:12
by webpatrick
if 'Added 2th Percentage to Graphs' in releasenotes means you have added the v2 to the graph, it still doesn't work. I still only have one value, and it looks like it's the other one (night)
Could you also set 24 hours style to the x-axis labels or use the device default settings for time?
Posted: Friday 20 January 2017 13:23
by Luigi87
Hi galadril,
Short question. i have the paid app and running the normal version (not Beta). Now i have 1 camera coupled in my domoticz system, working well in Domoticz i get snapshots and see the small feed picture. but in the app under the Camera tab it is not showing.
Am i doing something wrong? am i missing something?
Posted: Friday 20 January 2017 17:24
by piokuc
Widget now working ok but text under icon is still not center. Is left aligment. This no looks good. Should be center.
Posted: Friday 20 January 2017 18:19
by zait83
Having trouble adding widgets to desktop. Complains about buying the app. Already have done that and installer that version. Updated to latest market app.
Sent from my Nexus 6P using Tapatalk
Should have read last page. Will try that
Posted: Friday 20 January 2017 21:11
by piokuc
Refresh status on widget 3x1 dimmer is very long. When i turn on it show status now ok but when i turn off , status was refreshed after long time.
Posted: Friday 20 January 2017 21:22
by tjabas
is it possible to get a dimmer widget?
Posted: Saturday 21 January 2017 20:04
by galadril
zait83 wrote:Having trouble adding widgets to desktop. Complains about buying the app. Already have done that and installer that version. Updated to latest market app.
Did you export the lite settings and imported it into the premium version?
Please clear data/cache and manually reconfigure the app
Posted: Saturday 21 January 2017 20:46
by zait83
Updated my phone and restored previous backup. Had to install without restore
