Page 8 of 37
Re: ELV Max! Heating control system
Posted: Friday 26 February 2016 18:58
by DomotRikz
Hi Kevin,
I am running MaxBuddy on a Raspberry Pi, but I am having issues with the JSON interface with Domoticz. Besides that, I don't like the fact that there is no support on and documentation about MaxBuddy, as I would like to implement bidirectional communication (changing room setpoints using Domoticz).
Would be great if you could dive into this! Please keep us up to date.
Posted: Friday 26 February 2016 19:07
by blackdog65
Hi Kevin,
good question ref. Maxbuddy on the pi. I run mine headless so there is no GUI at all. The Domoticz.js picks up all the readings and sends them (I think) as json posts to Domoticz to see as devices.
Having said that, if time (and wife) allows, this weekend I'll plug my heating-pi into the tv and run the maxbuddy.sh instead of headless.sh and see what happens.
I REALLY hope you can pull some code together as a fully domoticzified heating system is my dream... well that and an Aston Martin :lol:
Posted: Friday 26 February 2016 19:32
by Meza
Delivery from elv.de today!
Got a bit of a project ahead of me now.
Sent from my PLK-L01 using Tapatalk
Posted: Friday 26 February 2016 19:38
by l0gic
OK, been thinking a bit more about this.
If I could get a web service running that throws up some pages it should allow for configuration and information display irrespective of OS.
So that is what I'll be looking at tonight.
I know I can set up bi-directional control as I have set up a dummy switch in Domoticz that is monitored by a MaxBuddy switch which sets all Radiator valves to override. This allows me to open all the rads up when I have my woodburner running.
All the best
Kevin
Posted: Saturday 27 February 2016 9:38
by blackdog65
That sounds excellent!
Bi-directional control would make you a hero to millions! (well at least two :lol: )
But in seriousness, this is the kind of functionality breakthrough that Domoticz needs. Proper, usable, practical stuff.
I can't code to save my life, but I'm the king of "copy & paste", so any testing help etc. I can offer... just say the word :D
Sean
Posted: Saturday 27 February 2016 15:28
by Skippiemanz
Image Kevin could this be of any help to you?
I have a small php script here. Don't remember it's origin but might help you!
Posted: Sunday 28 February 2016 14:04
by blackdog65
Posted: Sunday 28 February 2016 20:49
by Skippiemanz
I Also found this online: http://www.dmitry-kazakov.de/ada/max_ho ... mation.htm.
It can also act as a server witch can handel get requests etc. Looks promising.
Also here is the web package i mentioned earlier. http://we.tl/qWTH7G1hQC
Posted: Monday 29 February 2016 9:11
by blackdog65
Posted: Monday 29 February 2016 11:33
by l0gic
Guys,
I've spent the weekend looking a various C++ libraries for setting up web services.
Wow! Nightmare :)
Not sure I have a decent way forward yet, some are very elaborate and look like they may bring challenges down the line when cross compiling.
Still, leave it with me and don't expect anything too soon :)
Anyway, I've just realised that I'd coded up a bit of bi-directional code without sharing it.
The code below monitors a Domoticz dummy switch and overrides all the radiators when the switch is on.
May help someone.
I use it to drive all the radiators to ON when using my woodburner and the hot water tank is full of hot water.
Prevents overheating the water.
  V0.1.10, 14/09/2015 - MAX!Buddy Script: Check for Domoticz virtual switch being operated and force all radiators on and send a warning eMail
  The Domoticz ID for the 'Override Radiators ON' virtual switch is 168 - will be different for each system
  **** WARNING - relies on the correct Date / Time being held on the Cube (worth checking)
  **** there can be errors if you are using in a non German country due to the time difference
  **** I've added a Time Difference variable to help keep the times in sync.
  Uses a file written to disc to record the last time the On command was sent to the cube.
  Too many commands sent in an hour will prevent subsequent commands being sent.
function getInfo(info) {
info.name = 'Domoticz Radiator Override v2.0';
info.description = 'Open all radiators when the monitored Domoticz switch is ON';
info.interval = 300;     // 300 (5 mins)
//  Declare variables
  var IP = '192.168.1.14';         	 	// IP address of Domoticz
  var Port = '8080';               		// Port of Domoticz
  var domoticzID = 168; 				// ID of Domoticz switch called 'Override Radiators ON' that will be monitored for change
  var domoticzSwitch = 0;				// State of monitored Domoticz switch 0 = OFF 1 = ON
  var TimeDifference = 0; 				// Minutes time value that can be used to match cube time with local time in case they are different
  var boostDuration  = 240; 			// Boost duration in minutes
  var debuglevel = 2;					// 1 or 2 possible 1 = Send operation messages via email  2 = additionally write to file "/Users/<USER>/AppData/Roaming/MAXBuddy/logs/ScriptLogs/DomoticzRadiatorOverride.log"
  var URLReturn = "";					// holds response from the JSON call to Domoticz (long string)
  var URLChop ="";						// holds the useful data from URLReturn
  var rooms = 0;						// rooms value
// write out log information
function debug_(str){
   var file = java.io.File("/Users/Kevin/AppData/Roaming/MAXBuddy/logs/ScriptLogs/DomoticzRadiatorOverride.log");
   var datumlog = new Date;
   logDate   = datumlog.toLocaleString();
   str = logDate +" | "+ str;
   Packages.org.apache.commons.io.FileUtils.write(file, str+"\r\n",null,true);
   debug(str); }
// Manipulate the file that holds the last updated value (held as epoch time - mS since 1970 unix time)
 function timeFile(rw,timeValue){
	var file = java.io.File("/Users/Kevin/AppData/Roaming/MAXBuddy/logs/ScriptLogs/DomoticzRadiatorOverride.time");
	if (rw=="r") {  //read the file
		var fileTime = Packages.org.apache.commons.io.FileUtils.readFileToString(file, "UTF-8");
		return fileTime;
	if (rw=="w") {  //write to the file
	timeValueS = timeValue.toString();
   Packages.org.apache.commons.io.FileUtils.write(file, timeValueS,null,false);
// perform the JSON get action to interigate the Domoticz web server and return the data string
function getJSON(RID, Type) {
if (Type == 1) {
URLString = 'http://'+IP+':'+Port+ '/json.htm?type=devices&rid='+RID;
} else {
URLString = 'http://'+IP+':'+Port+ '/json.htm?type=command&param=getuservariable&idx='+RID;
var url = new URL( URLString),
outputStream,
out;
URLconnection = url.openConnection();
URLconnection.setRequestMethod('GET');
URLconnection.setReadTimeout(5000);
URLconnection.setDoOutput(true);
URLconnection.setRequestProperty('Content-type', 'application/json');
inputstream = URLconnection.getInputStream();
instream = new InputStreamReader(inputstream);
inbuffer = new BufferedReader(instream);
response = new StringBuffer();
while ((inputLine = inbuffer.readLine()) != null) {
		response.append(inputLine);
inbuffer.close();
//print result
//debug(response.toString());
RespStr=response.toString();
RespStr=RespStr.replace(' ','');
return RespStr
// Seperate the switch state information from the returned URL string
function GetField (RawData, Field) {
Datalength=Field.length
DataIndex=RawData.indexOf('"'+Field+'"')
Param=RawData.substring(DataIndex+Datalength+3,RawData.indexOf(',',DataIndex+7));
return Param
var states = new Array();
// Send email
function notify(EmailTitle, text) {
  buddy.sendEmail(
    "mail.server.com", 		// SMTP Server
    "[email protected]", 			// SMTP Account
    "password", 				// SMTP Password
    "[email protected]", 	// From address
    "[email protected]",		// To address
     EmailTitle, //"Email Title",
     text // "Email body text"
// Polls cube for all Radiators and turns them on until boostStop time
function TurnRadiatorsOn(boostStop) {
	rooms = connection.getLastState().getRooms();
			  for  (var i = 0; i < rooms.size(); i++ ) {
				var room = rooms.get(i);
				var devices = room.getDevices();
				var RoomID = room.getId();
				for ( var j = 0; j < devices.size(); j++ ) {
				   var device = devices.get(j);
				   var devicename = device.getName()
				   if( "HeatingThermostat" == device.getDeviceType() ) {
						if (debuglevel >1) {
							var devicename = device.getName();
							var DeviceTemp= device.getState().getMeasuredTemperature();
							debug_("             "+devicename+" Temp: "+DeviceTemp+" C  (RoomID:"+RoomID+") Radiator overriddden to "+boostStop);
						buddy.setRoomMode(RoomID, "TEMPORARY", new Array("EIN", boostStop.getTime()) ); // Opens the valve in Temporary mode until boostStop expiry time
					if (debuglevel >0) {
					var status= "The Domoticz Heating Override switch has been operated. Boosting all radiators On for "+boostDuration+" Minutes.";
					notify("Woodburner heating overide started", status);
					if (debuglevel >1) debug_("        Email sent");
function run() {
  // set up http requirements
	URL = java.net.URL,
	InputStreamReader = java.io.InputStreamReader,
	BufferedReader = java.io.BufferedReader,
	StringBuffer = java.lang.StringBuffer;
  var now = new Date(); // comes from PC so may not agree with cube time that seems to work in German time
  boostDuration = boostDuration + TimeDifference; // add difference between PC and German time
  var boostStop = new Date(now.getTime() + boostDuration * 60000);
// Call Domoticz and get the state of the monitored switch
 URLReturn = getJSON(domoticzID, 1);
 URLChop = GetField(URLReturn,"Status");
  if (URLChop =='"On"') domoticzSwitch = 1;
	 debug_("             Domoticz switch state is: "+URLChop);
	 debug_("             domoticzSwitch value is: "+domoticzSwitch);
  var oldTime = timeFile("r","");      // get the last Radiator on time
  var nowTime = Date.now();            // get current time (epoch)
  var checkDelay = boostDuration - 6;  // only re run the radiator process 6 minutes (script run time plus one minute) before the end of the "On" period
  checkDelay = checkDelay * 60 * 1000  // comvert to milliseconds
  //debug_("checkDelay value in Ms is: "+checkDelay);
  //debug_("nowTime value in Ms is: "+nowTime);
  //debug_("oldTime value is: "+oldTime);
 if (domoticzSwitch > 0 ) {  // Let's go, the Domoticz switch is on
	   if (debuglevel >1) { // print the header to the log file
	  debug_( "");
	  debug_( "--------------------------------------------------");
	  debug_( " Information:");
	  debug_( "             Boost stop time: "+boostStop);
	  debug_( "             Boost Duration: "+(boostDuration - TimeDifference)+" Min.");
	  //debug_( " ");
	radDifference = nowTime - parseInt(oldTime);
	if (radDifference > checkDelay){ // Have we checked within the checkDelay time?
	 // nope, we need the send an On signal to the radiators
		TurnRadiatorsOn(boostStop);
		timeFile("w",nowTime); // update the last time the radiators were switched On
	}else{  // too early to resend the Cube a command
			 debug_("             On Signal already sent to Radiators "+Math.ceil(radDifference / 60 / 1000)+ " minutes ago.");
 }  // end of domoticzSwitch
} //end of run
To further atone for my ommisions, here is a script (found on the net somewhere) I run once a day to check battery state and email issues.
// Adjust this function as necessary:
function notify(body) {
   buddy.sendEmail(
   // Adjust these values as necessary:
   "Max!Cube Error", //"TITLE OF EMAIL",
   //"room:   " + room + "\u000a" + "Device: " + device.getName() + "\u000a" + "Status: " + status // "CONTENT OF EMAIL"
   body
function getDateTime() {
    var year    = now.getFullYear();
    var month   = now.getMonth()+1;
    var day     = now.getDate();
    var hour    = now.getHours();
    var minute  = now.getMinutes();
    var second  = now.getSeconds();
    if(month.toString().length == 1) {
        var month = '0'+month;
    if(day.toString().length == 1) {
        var day = '0'+day;
    if(hour.toString().length == 1) {
        var hour = '0'+hour;
    if(minute.toString().length == 1) {
        var minute = '0'+minute;
    if(second.toString().length == 1) {
        var second = '0'+second;
    // var dateTime = year+'/'+month+'/'+day+' '+hour+':'+minute+':'+second;
	var dateTime = day+'/'+month+'/'+year+' '+hour+':'+minute+':'+second;
     return dateTime;
   var file = java.io.File("/Users/Kevin/AppData/Roaming/MAXBuddy/logs/ScriptLogs/BatteryAndRadio.log");
   str = getDateTime() +" - "+ str;
   debug(str);
   // Display Name in the MAX ! Buddy settings
   info.name = "eMail if battery is low or radio contact is lost";
   // Description of the script
   info.description = "Sends an email when the battery of an appliance ( wall thermostat , window contact or heater thermostat ) is low or radio contact is broken. - V0.1.0   Runs every 8 hours";
   // Execution interval of the script : Every 8 hours
   info.interval = 28800; //28800
function run() {
   var debuglevel = 1;   // 1 or 2 possible 1 = Send error messages via email  2 = additoinally write to file "/Users/Kevin/AppData/Roaming/MAXBuddy/logs/BatteryAndRadio.log"
   var body = "";
   var fail = 0;
   if (debuglevel > 1) debug_("--------------------------------------")
   body = body + "--------------------------------------\u000a";
   var rooms = connection.getLastState().getRooms();
      var room = room.getName();
      if (debuglevel > 1) debug_("  Room:  " + room);
      body = body + "  Room:  " + room + "\u000a";
	   if (debuglevel > 1) debug_("       " + devicename + ":");
         body = body + "       " + devicename + "\u000a";
	   //Verification of the wall thermostats
	   if( "WallMountedThermostat" == device.getDeviceType() ) {
            var batteryState = device.getState().isBatteryLow();
	  	if(batteryState == true  ) {
               if (debuglevel > 1) debug_("           Battery is low!");
               fail = 1;
               body = body + "           Battery is low!\u000a";
		} else if(batteryState == false ) {
               if (debuglevel > 1) debug_("           Battery ok");
               body = body + "           Battery ok\u000a";
            var transmitState = device.getRadioState();
            if(transmitState == "Error") {
               if (debuglevel > 1) debug_("           Lost Radio Contact!");
               fail = 1;
               body = body + "           Lost Radio Contact!\u000a";
            } else if(transmitState == "Ok") {
               if (debuglevel > 1) debug_("           Radio Contact ok");
               body = body + "           Radio Contact ok\u000a";
         //Checking the window contacts
         } else if( "ShutterContact" == device.getDeviceType() ) {
               fail = 1;
               fail = 1;
	   //Verification of heating thermostats
         } else if( "HeatingThermostat" == device.getDeviceType() ) {
               fail = 1;
               fail = 1;
            var radState = device.getRadioState();
            if(radState == "Error") {
               if (debuglevel > 1) debug_("           Disturbed radio link!");
               fail = 1;
               body = body + "           Disturbed radio link!\u000a";
            } else if(radState == "Ok") {
               if (debuglevel > 1) debug_("           Radio Link ok");
               body = body + "           Radio Link ok\u000a";
   if(fail != 0) {
      if (debuglevel > 0) debug_("At least one device failed. Sending error mail...");
      notify(body);
All the best
Kevin
Posted: Monday 29 February 2016 13:17
by blackdog65
Many thanks Kevin.
Have you seen this?
viewtopic.php?f=34&t=10786
Sean
Posted: Monday 29 February 2016 14:02
by jesperlykke
thanks Kevin.
Have you seen this?
Seante
Hi!...
I am the owner :D of that topic.
The only thing i figured out, is to send commands to my valves, i still search for a way of recieving them through netcat/curl, whatever.
Reason i use netcat/curl, is that i am not interessted in having another server running on my Pi.
I use this program, to catch the strings to send! :: http://www.dmitry-kazakov.de/ada/max_ho ... mation.htm, and when sending a command, from my laptop, i can see the string to netcat into the cube... Actually working quite well.
Example : MAN_BEDROOM_20=s:AARAAAAAEUh2AWg=
One can see, the codes when looking at Dmitry's Trace pane in his program... Very cool
Rgds; Jesper.
Posted: Wednesday 02 March 2016 11:42
by blackdog65
Hi guys,
I just had to burn a new SD card for my RasPi with Maxbuddy etc on it.
Everything was installed exactly as before (I think) and it appears to work
./headless is producing
[2016-03-02 10:01:50,217] [DEBUG]: executeScript(Domoticz.js)
[2016-03-02 10:01:50,260] [DEBUG]: Script debug (Domoticz.js): Start run()
[2016-03-02 10:02:20,227] [DEBUG]: executeScript(Domoticz.js)
[2016-03-02 10:02:20,269] [DEBUG]: Script debug (Domoticz.js): Start run()
[2016-03-02 10:02:27,191] [DEBUG]: ConnectionWatchdog:connect()
[2016-03-02 10:02:27,197] [DEBUG]: controller connect...
[2016-03-02 10:02:27,460] [DEBUG]: gateway fetchMaxCubeState()
[2016-03-02 10:02:27,729] [DEBUG]: getRawState().getHeader()
[2016-03-02 10:02:27,744] [DEBUG]: refresh()
[2016-03-02 10:02:27,828] [DEBUG]: updateRadiatorThermostatTemperatures()
[2016-03-02 10:02:27,834] [DEBUG]: updateWallThermostatTemperatures()
[2016-03-02 10:02:27,840] [DEBUG]: controller.cubeState()
[2016-03-02 10:02:27,845] [ INFO]: Connection established, serial: LEQ1281041, fw: 275
[2016-03-02 10:02:27,851] [DEBUG]: updateWallThermostatTemperatures()
[2016-03-02 10:02:27,856] [DEBUG]: updateRadiatorThermostatTemperatures()
[2016-03-02 10:02:27,862] [DEBUG]: disconnect()
which I think is ok (or is it?)
but no information is being sent to Domoticz.
Any ideas?
Sean
Posted: Wednesday 02 March 2016 11:45
by blackdog65
or... is it seeing my cube, but my cube isn't seeing any devices :shock: :o
Posted: Wednesday 02 March 2016 12:38
by blackdog65
Yes!
For some reason, while messing around, my cube had dropped all devices.
It was all working away quite happily send "zero" :lol:
Oh well... another lesson learned :roll:
Posted: Saturday 05 March 2016 19:45
by jesperlykke
Evening all :)
I'am still searching, for a way retrieving the codes, which MAX! sends from e.g. the thermostats to the cube and soo.
I can send with netcat commands into the thermostat's, which is working, but still miss the other direction.
Reason i need that, is that i really want domoticz to "writeout" the actual status of the valves, door switches etc...
Rgds; Jesper
Posted: Thursday 24 March 2016 17:57
by Rostikator
Where I can download maxbuddy files now ?
http://www.maxbuddy.de/ don't run
Bye R
Posted: Friday 25 March 2016 14:26
by blackdog65
viewtopic.php?f=34&t=841&start=60#p57149
https://www.dropbox.com/s/cph58qwcqfqiq ... ar.gz?dl=0
Should put you right.
I'd advise reading ALL this thread as some instructions rely on OTHER instructions and some have typos... but all together it's doable ;)
Sean
Posted: Friday 25 March 2016 15:09
by Rostikator
Thanks for links. I see it before. But I need a windows version. :(
R
Posted: Thursday 31 March 2016 22:15
by jorishp
