FlatZ Frontpage
galadril
Domoticz version: latest
Re: FlatZ Frontpage
Post by galadril »
woods wrote:Thanks for the great work!
Is there any way I can make another page containing info? As a user of public transport, I would rather use real time status on my nearest tram/metro stop, then traffic.
The site url: http://mon.ruter.no/monitor/3010512/Sch ... imdalsgata
Thanks for any suggestions!
Should be possible..
Just create your own extra page and create a javascript method to get the data.
Info link:
http://mon.ruter.no/SisMonitor/Deviatio ... &sid=99999
Left side Data:
http://mon.ruter.no/SisMonitor/Refresh? ... &sid=99999
Right side Data:
lykke til
ropske
Domoticz version: V3_8394
Re: FlatZ Frontpage
Post by ropske »
sorry to ask, but i'm searching and searching how to set following in one box:
'Degrees' °C | 'Humidity' %
<div class="col-sm-3 col-lg-3">
                <div class="half-unit">
                    <dtitle id="desc_cell8"></dtitle>
                    <hr>
			<h2 style="float: left; width: 50%;" id="cell8"></h2>
			<h2 style="float: right; width: 50%; text-align: right;" id="cell800"></h2>
                </div>
            </div>
it's allmost what i want, but then without the °C | %
Can someone please help me?? Thank you
ropske
Re: FlatZ Frontpage
Post by ropske »
if i do for example:
<h2 id="cell8"></h2> °C | <h2 id="cell800"></h2> %
he keeps putting it under eachother instead of beside eachother
as you will noticed, im not a html coder :p
dijkdj
Re: FlatZ Frontpage
Post by dijkdj »
Hi, it works now. Very nice.
I have two question:
-Is it possible to call a hue scene? Domoticz scenes don't works as well as it does lamp by lamp
-Is it possible to put a screenshot of the webcam on the frontpage?
trollmar
Re: FlatZ Frontpage
Post by trollmar »
Hi galadril
Thx for the great work!!!
Maybe someone can help me with my question.
I would like resize the buttons on the lights Page.
The "On/Off" Buttons.
It is possible ?..where can i find the values to change the pix height?
Thx
markiemajax
Domoticz version: 3.4834
Re: FlatZ Frontpage
Post by markiemajax »
markiemajax wrote:Hello,
I am trying to add a page for my Evohome room temperatures.
I made an extra page, witch is called "Temperature". I have 6 temperatur blocks, just like in the frontpage (donut chart).
In the frontpage it is used for "woonkamer".
But i can't get any data in the blocks.
Does anyone have an idea? I made a temperature.html and i changed the settings.js.
Does someone have an answer for me??
pipari
Re: FlatZ Frontpage
Post by pipari »
Anyone having problem with displaying temperature below zero? Got -1,6 outside but it displays +0,6 ...
thanks for a great frontpage :D
best regards
Cristopher
ericjuh
Re: FlatZ Frontpage
Post by ericjuh »
trollmar wrote:Hi galadril
Thx
@galadril First off all, big thanks to the frontpage. It's looking amazing.
I also have the same question. The buttons on the left button panel are a bit to small.
Also two other question:
- in de camera tab you see 6 camera's, but i only have 2 camera's. I managed to remove 4 boxes, but how do i make the other 2 boxes bigger?
- I have renamed the tab's to a dutch name: nieuws for news, etc. But somehow the active page isnt highlighted anymore after that. Any idea why this isnt working after i translate the tabs?
trollmar
Re: FlatZ Frontpage
Post by trollmar »
hi,
have you tried a different class??
                <div class="dash-unit">
wizzard72
Re: FlatZ Frontpage
Post by wizzard72 »
Very nice frontpage!
The settings.js file is readable from a webbrowser. Because my username and password is stored in plain text, I want to hide the settingsfile. Does any one knows how to do it?
wizzard72
Re: FlatZ Frontpage
Post by wizzard72 »
With Apache you can use a .htaccess file to restrict access to files, so you can save use it on the internet. Is something like this possible with the domoticz webserver? Maybe a new feature for domoticz?
Verstuurd vanaf mijn SM-T700 met Tapatalk
wizzard72
Re: FlatZ Frontpage
Post by wizzard72 »
Thanks for explaining! Then I'm going to use the floorplans.
roblom
Re: FlatZ Frontpage
Post by roblom »
Maybe a dumb question, but when i Upload all files to the www folder, then everything got mixed up with the original Domoticz files. Is there an easy way to separate the original files from the custom theme files?
grestysr
Re: FlatZ Frontpage
Post by grestysr »
Can someone recommend what changes I need to make to frontpage.html to replace one of the donut tiles with a camera view?
I've tried moving some of the code from camera.html but I can't seem to get it to work.
Any help gratefully received.
NietGiftig
Domoticz version: V3.6224
Re: FlatZ Frontpage
Post by NietGiftig »
roblom wrote:Maybe a dumb question, but when i Upload all files to the www folder, then everything got mixed up with the original Domoticz files. Is there an easy way to separate the original files from the custom theme files?
Same question here !!
I have no html skils, so a short explanation is welcome
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
trollmar
Re: FlatZ Frontpage
Post by trollmar »
I made a sub Folder and upload everything into it.
So my browser path looks like this:
http://192.168.xxx.xxx:8080/flatz/frontpage.html
In www there is now a subfolder "flatz"
roblom
Re: FlatZ Frontpage
Post by roblom »
Ok, that works, thanks.
But I like the fact that you can switch in Domoticz to the custom frontpage from the menu. Therefore the frontpage.html needs to be in the www/ folder. But when I upload the folders everything got mixed up with other custom frontpages I'm testing. Then when i don't use one of the custom frontpages anymore it's hard to remove without removing the other frontpages too.
So in my opinion there should be a subfolder in the "www/" folder (like "www/FlatZ") but the main page of the custom frontpage should be in the root of the "www/" folder (and named "FlatZ.html".
But then all the file paths in the FlatZ.html file needs to be changed I think other wise they point to "www/" instead of "www/Flats".
Frontpages from menu in Domoticz.
EG2015
Re: FlatZ Frontpage
Post by EG2015 »
I got the dashboard running on Synology station. But I see only my log from domoticz. Nothing in the other pages from my Domoticz switches/bulbs/etc.
I filled in my IP an port number in the 'settings.js' file behind "$.domoticzurl"
What 'm I doing wrong? is there more to configure?
skalman77
Re: FlatZ Frontpage
Post by skalman77 »
How do I add dimmers to Homescreen?
Can i replace onbutton on this row to get a slider instead?
"['13', 'Data', 'cell1', 'Kitchen', 'onbutton'],//onbutton = only push on"
Secondly - on my Lights page, there is no lights. When troubleshooting it looks like the page is trying to get all devices from domoticz via json. Is that correct?
Clemen
Re: FlatZ Frontpage
Post by Clemen »
roblom wrote:Ok, that works, thanks.
How do you create that frontpage2 link?
