Page 8 of 13
Re: RE: Re: RE: Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Monday 05 December 2016 13:58
by Justintime
tuspam wrote:Justintime wrote:tuspam wrote:
So, You find one.
So i just need a rm2 than?
YES rm2 or black bean.
So to summarize..... i can use a Black Bean to learn commands which i can control switches in Domoticz.
I want to use my Harmony Remote to activate scenes and switches.
Posted: Monday 05 December 2016 15:19
by tuspam
1 i can use a Black Bean to learn commands - YES
2 use my Harmony Remote to activate scenes and switches - NO (Alexa or Google Home can do that or anything which can control domoticz switches)
RM2 and RM mini only transmitting IR or RF signal (they receive signals only in learn mode) - so you can't press button on remote control to activate something (You need extra separately IR receiver to do that)
Posted: Thursday 08 December 2016 13:10
by tekmars
I would like to buy this BROADLINK but is there any difference between BROADLINK RM2 PRO and BROADLINK PRO ?
Thanks.
Re: RE: Re: RE: Re: RE: Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Thursday 08 December 2016 13:24
by Justintime
Thanks.. I will stick to mysensors and the IR Send and receive node. I need to toggle switches in Domoticz.
My Arduino sketch is lost so thought it would be an easy replacement to get more ir commands.
Alexa and Google home... Wish dutch language was available.
Posted: Friday 09 December 2016 17:14
by tuspam
tekmars wrote:Hi
Thanks.
I think is the same device
Posted: Saturday 10 December 2016 19:25
by tekmars
tuspam wrote:tekmars wrote:Hi
Thanks.
Well, I'll buy this gateway.
thank you.
Posted: Sunday 11 December 2016 12:44
by tuspam
del
Posted: Sunday 11 December 2016 13:01
by tuspam
After some time my domoticz (latest beta) got some problems with execute scripts, for example my virtual switch for turn on light looks like that:
On Action:
script:///home/pi/domoticz/scripts/python/playcode2.py /home/pi/domoticz/scripts/python/lightOffice.txt
When i press virtul switch in domoticz log i see:
2016-12-11 12:56:15.310 User: Admin initiated a switch command (327/Light Office/On)
But nothing happen
When i give command in console:
root@raspberrypi:/# home/pi/domoticz/scripts/python/playcode2.py /home/pi/domoticz/scripts/python/lightOffice.txt
Connecting to Broadlink device....
Connected....
Code Sent....
Everything works - what's going on?
PS. After the restart, everything works a few hours.
PS2. I have playcode.py to control RM2 and playcode2.py to control RM mini.
Posted: Sunday 11 December 2016 16:31
by djassa1
Just to be clear, the broadlink python libraryby mjg59 is able to control the RM2 (pro) and the RM3 blackbean.
I suspect that this library also works for some other wifi broadlink devices like the SP and SP2 sockets.
For the installation of the library I just copied it in a PATH reachable python directory:
/usr/local/lib/python2.7/dist-packages/broadlink
No need to do any setup and works like a charm.
Posted: Monday 12 December 2016 12:08
by tuspam
djassa1 wrote:Just to be clear, the broadlink python libraryby mjg59 is able to control the RM2 (pro) and the RM3 blackbean.
Ok, I make:
HOW TO (broadlink python library by mjg59)
Download:
git clone https://github.com/mjg59/python-broadlink
Go to new folder python-broadlink
If You got any errors check Dependency file:
/usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg/EGG-INFO/dependency_links.txt
Download learn.py and playcode.py
http://www.domoticz.com/forum/viewtopic ... 00#p103517
Make "Static Lease" Your RM on Your router.
Edit in learn.py this line:
device = broadlink.device(host=("<your RM3 IP address>",80), mac=bytearray.fromhex("<your RM3 mac>"))
My example:
device = broadlink.
rm(host=("
192.168.1.110",80), mac=bytearray.fromhex("
B4430DEEE880"))
Copy learn.py and playcode.py to:
Type "python learn.py" to learn IR and RF codes
Make dummy switch in domoticz
On action example:
script:///home/pi/domoticz/scripts/python/playcode.py /home/pi/domoticz/scripts/python/tvOn.txt
Or add to HA-Bridge script and control via Alexa or Google Home directly without domoticz:
[{"item":"python /home/pi/domoticz/scripts/python/playcode.py /home/pi/domoticz/scripts/python/tvOn.txt"}]
Somehow like that if I everything well remember
Good luck
Ps sorry for my language.
Posted: Sunday 18 December 2016 15:35
by djassa1
Hello @tuspam,
Seems that yours usefull scripts do not work with the new version 0.2 of the library.
setting static host device is not handled correctly.
Edit: found it, device definition does not exist anymore in the library. For rm1, rm2, rm3, it will need to use a definition like this
for rm remotes it uses
device = broadlink.rm(host=("IP address",80), mac=bytearray.fromhex("mac address"))
So just replace broadlink.device by broadlink.rm in the scripts and everything will be back and working !
Posted: Sunday 18 December 2016 16:37
by tuspam
djassa1 wrote:Hello @tuspam,
Check exactly my post before
"My example:
device =
broadlink.rm(host=("192.168.1.110",80), mac=bytearray.fromhex("B4430DEEE880"))"
Posted: Monday 19 December 2016 13:15
by djassa1
Oups, did not saw it, went directly to your last post where you referenced your original scripts
Posted: Friday 23 December 2016 20:11
by noddy119
To advise I have updated my original post:
viewtopic.php?f=17&t=6929&p=103517#p103517
I was using an older version of the library which did not allow me to use 'broadlink.rm' for my blackbean mini 3, which was creating confusion
I have also added a script to locate Broadlink devices and reveal their Host and MAC addresses so they can be copied and pasted into the learn and play scripts.
Posted: Saturday 24 December 2016 23:40
by inzimam
Has anyone got in touch with the with the RM bridge developers about the character limit? Or has anyone figured out a way to get around this? I don't want to use the RM Tasker plugin as I believe it has a 16 device limit
Posted: Sunday 25 December 2016 0:36
by noddy119
Hi @inzimam
The scripts using the python library (RM Tasker not required) that this topic latterly refers to store the codes in individual text files, so I am fairly sure the character/device limit does not apply. Effectively the Broadlink device is only used to record codes to a text file and then play back those codes via the named text file. Nothing is stored on the Broadlink device.
Posted: Monday 26 December 2016 20:49
by forumfab
Hi All,
For the moment, in my point of view there is too much librairies versions, methods to use them, and scripts to go ehead in term of simple usage !
Without a full installer, that will included all the python librairies, and broadlink's librairies, scripts and so on, this project will may be stay in a no man's land
This installer must be able to prepare every think without any human intervention , execpt for the IP BROADLINK's adress, MAC BROADLINK,s adress, and PORT BRAOEDLINK,s adress ( 80) in the general case )
Posted: Monday 26 December 2016 21:37
by inzimam
Anyone working on an easy installer?
I'm planning on running this on my O2 Joggler which is running Windows XP - is this a possibility?
Posted: Tuesday 27 December 2016 0:03
by tuspam
Guys, you got every thing you need, stop bla bla bla and be happy.
viewtopic.php?p=110715&sid=6d5e3b993fde ... 98#p108350
Posted: Wednesday 28 December 2016 0:19
by inzimam
Guys
I'm sorry I'm too much of a newbie here. I don't even know where to start to get this to work
I have an XP machine, a Broadlink RM Pro.
Looks like I need Domoticz for Windows and RM Controller?
Does anyone have some very simple starting steps please?
