Re: Android app
Posted: Monday 13 January 2014 18:49
Luckily I haven't updated domoticz so the old version without the compression is still working fine with your app
Open source Home Automation System
https://forum.domoticz.com/
Good to hear that it works with the older versions of Domoticz.Scoobydoo wrote:Luckily I haven't updated domoticz so the old version without the compression is still working fine with your app
Do you have a valid SSL certificate for the no-ip address as the domain? The certificate does not need to be signed by a trusted CA but the SSL certificate needs to be for the domain name that you are connecting to. Also Domoticz does not come with SSL support built in. You'll need an Nginx proxy for that. When you connect with a browser, does that work?andriej wrote:I've set 'remote' to my dyndns no-ip address, port is high value (like: 23445) and forwarded to 443 by router.
I cannot connect via 'secure' remote option.
It's not 'valid' certificate as its own-signed by RPI.sebas wrote:Do you have a valid SSL certificate for the no-ip address as the domain? The certificate does not need to be signed by a trusted CA but the SSL certificate needs to be for the domain name that you are connecting to. Also Domoticz does not come with SSL support built in. You'll need an Nginx proxy for that. When you connect with a browser, does that work?
A SSL certificate that is signed by yourself is still valid. Is just not signed by a trusted Certificate Authority. I've disabled the check for that. However the certificate does need to be for the domain you're accessing Domoticz on. So if you've not created a new certificate probably the domain name (no-ip address) is not the same domain as the ssl certificate is for. Creating a new certificate will solve that.andriej wrote:It's not 'valid' certificate as its own-signed by RPI.sebas wrote:Do you have a valid SSL certificate for the no-ip address as the domain? The certificate does not need to be signed by a trusted CA but the SSL certificate needs to be for the domain name that you are connecting to. Also Domoticz does not come with SSL support built in. You'll need an Nginx proxy for that. When you connect with a browser, does that work?
It came from default installation of Domoticz, as default, on image. It works in browser, just the 'https' is lined-out in Chrome tho.
Do you mean I need to re-do the certificate to match 'no-ip' address?
I've that problem too.wizzard72 wrote:In the switch section the dimmers are not working correctly. The are off and the app reports they are on and at full capacity.
I've re-done the certificate for specially put-up domain. Still the same (Could not connect...)sebas wrote:A SSL certificate that is signed by yourself is still valid. Is just not signed by a trusted Certificate Authority. I've disabled the check for that. However the certificate does need to be for the domain you're accessing Domoticz on. So if you've not created a new certificate probably the domain name (no-ip address) is not the same domain as the ssl certificate is for. Creating a new certificate will solve that.
As long as it's less than 65535 it should be fine however ports above 49151 are Ephemeral ports so that might break things. Try setting one below 49151.andriej wrote:I've re-done the certificate for specially put-up domain. Still the same (Could not connect...)sebas wrote:A SSL certificate that is signed by yourself is still valid. Is just not signed by a trusted Certificate Authority. I've disabled the check for that. However the certificate does need to be for the domain you're accessing Domoticz on. So if you've not created a new certificate probably the domain name (no-ip address) is not the same domain as the ssl certificate is for. Creating a new certificate will solve that.
In browser from the same phone everything works.
I hope it's not the problem that port (defined in 'port' section) is >5xxxx (high)?
+ multiple tabs for the several roomsremb0 wrote:what's next? do you have a roadmap?
what I miss:
- energie p1 cable is displayed but no values.
- the blue background earlier mentioned
- nice widgets? (maybe icons or text)
- android push notifications when a doorbell / door of something is open/on/off
- moving item order. when holding an item for x seconds
- open logs of an item (by holding for x seconds you can see historie.
- opening domoticz websites
- cam's
Well I'd like to add the weather part to it first so I got all the groups covered and I'm looking into the room support. Maybe also adding the dashboard.remb0 wrote:what's next? do you have a roadmap?
what I miss:
- cam's
