New project, a small wall display to control Domoticz using CYD (Cheap ESP32 touchscreen)
Rik60
- Domoticz version: 2026.3
Re: New project, a small wall display to control Domoticz using CYD (Cheap ESP32 touchscreen)
Thanks for asking, but no at the moment. I am going to try next week
Rik60
Tried to edit the code, but i am running into trouble.Rik60 wrote: Saturday 27 April 2024 17:58Thx,Thorgal789 wrote: Saturday 27 April 2024 12:13 Ha yes, I m reading the value, data don't contain "open" or "closed" but the level (except for 0 and 100 value, so only full closed or full open)Code: Select all
Data : "Set Level: 38 %"So you don't to change the icon but add a text for the covering ?Code: Select all
For me i like the On, Off, Open, Closed as text in a icon.
If it's just that, I can make the code today. But if you want to search yourself, you can useto have the covering level and print "open" or "closed" (it's a numeric value, from 0> 100)Code: Select all
d->level
or use
with that you will check the "full closed", and all others values will be the "Open"Code: Select all
if (d->type == TYPE_BLINDS && strcmp(d->data, "Closed") == 0)
Check the "data" value on a browser using the URLyou can have a "custom" device not managed like mines.Code: Select all
http://192.168.1.1:8080/json.htm?type=command¶m=getdevices&rid=ID
I am going to try to edit the code myself.
Thanks for the tips.
For the switch and powersockets i use:
if (d->type < TYPE_SWITCH && strcmp(d->data, "On") == 0)Code: Select all
if (d->type < TYPE_SWITCH && strcmp(d->data, "Off") == 0)For the blinds i use:
if (d->level < TYPE_BLINDS && strcmp(d->data, "Open") == 0)Code: Select all
if (d->level < TYPE_BLINDS && strcmp(d->data, "Closed") == 0)Am i doing something wrong?
I like to have 'Open', 'Closed' and, if possible the level between them.
I can see in the data the level status as:
Data : "Set Level: xx %"Code: Select all
Data : "Closed"Code: Select all
Data : "Open"Thanks
Thorgal789
- Target OS: -
d->levelCode: Select all
if (d->level > 0) But easier the code can be just
// Display a open/clode state for covering
if (d->type == TYPE_BLINDS)
lv_obj_t * label = lv_label_create(Button_icon);
lv_obj_set_style_text_color(label, color, 0);
lv_obj_align_to(label, img, LV_ALIGN_OUT_RIGHT_BOTTOM, 0, 0);
if (strcmp(d->data, "Closed") == 0)
lv_label_set_text(label, " Closed");
lv_label_set_text(label, " Open");
}To print the level can use
lv_label_set_text_fmt(label, "%d %",d->level );-
Rik60
Thanks,
Added and edited a bit:
With this as result (and some translation):
lv_label_set_text(label, " Dicht");
if (strcmp(d->data, "Open") == 0)
if ((strcmp(d->data, "Closed") != 0) && (strcmp(d->data, "Open") != 0))
lv_label_set_text_fmt(label, " %d %%",d->level );
}- Attachments
- Display_4x4_level.jpg (206.39 KiB) Viewed 3874 times
Thorgal789
- Target OS: -
Ha, so the data contain "open" or "close" or a level ? there is 3 possibles values ?
BTW I will take your capture for the project ^^.
Rik60
Yes, the data can contain 3 possible values:
Open
Closed
Level %
Open
Closed
Level %
ElMyggo
- Domoticz version: 2024.4
I get this 7" displayboard and wonder if this can work with same software, do i have to make the driver myself?
Panlee ZX7D00CE01S-V13
http://en.smartpanle.com/product-item-19.html
https://www.aliexpress.com/item/1005006156603547.html
data:
https://img01.71360.com/file/read/www2/ ... asheet.pdf
data:
Thorgal789
- Target OS: -
Have found somes usefull links
https://github.com/moononournation/Ardu ... ssions/361
https://github.com/moononournation/Ardu ... ssions/368
https://github.com/fbiego/jarvis-lvgl-esp32
So based on them have created a esp32-ZX7D00CE01S environnement to test on branch "test", need to enable your device in platformio.ini file to test it
I m not using the same code than them for the touch, but it seem you have a GT911 too and the code I m using is already tested for another device.
default_envs = esp32-ZX7D00CE01S-
ElMyggo
Super! i do some testing
ElMyggo
Have done som testing now and i get no backlight so dont know if screen is working, touchdriver seems to work, i can calibrate screen according to log.
No backlight
I tested the files from https://github.com/fbiego/jarvis-lvgl-esp32 and then i get backlight and working screen for 1 second then start flickering one line.. i have marked photo to see that the backlight is on
I try to find out how the backlight is turning on and do some more testing
No backlight
--- Terminal on COM5 | 115200 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x128
load:0x403c9700,len:0xb90
load:0x403cc700,len:0x28cc
entry 0x403c98b8
Starting application
Config version: 0
Clearing Global Config
Init 911 driver
Driver GT911 started: (800x480)
Check ACK on addr request on 0x
5D
: SUCCESS
Starting calibration
Calibration coef: 1.2 , -1.4
Calibration offset: -103.8 , 602.4
Display buffer size: 38400 bytes
Screen init done
Brightness value: 255-
Thorgal789
- Target OS: -
Try adding in esp32-ZX7D00CE01S.h file
It's the code Im using for other device, can be enought.
On his code he have disabled this one and use instead
For the second part, file to edit is screen_driver.cpp around line 524
#define GFX_BL 45On his code he have disabled this one and use instead
#define GFX_BL 45
const int freq = 1000;
const int ledChannel = 7;
const int resolution = 8;
// #ifdef GFX_BL
// pinMode(GFX_BL, OUTPUT);
// digitalWrite(GFX_BL, HIGH);
// #endif
ledcSetup(ledChannel, freq, resolution);
ledcAttachPin(GFX_BL, ledChannel);
ledcWrite(ledChannel, int(2.55 * 95));-
ElMyggo
I added #define GFX_BL 45 in driver file and i get picture
, i have to change resolution to 800x481 because a white line at bottom (read this on the other link you find)
But i cant swipe right (settings) screen get white and restart, swipe left is working.
I upload a video here:
(Havent fix the custom font)
Thorgal789
- Target OS: -
Nice, updating the code (not sure I have set the 481 at good place, in the platformio.ini file ?
Ok so you have crash on the "tool" panel (There is in order, tool/home/home_bis/group/info)
This page display hardware information, there is perhaps something bad on memory stuff ATM for your device
Can you try to catch logs using the serial monitor ?
Else I think the guilty code is here, the rest only display 2 buttons.
Can try to disable this code in tools-panel.cpp, and re-enable it line by line.
About custom font, where are you front ? (Wich one font you need)
lv_mem_monitor_t mon;
lv_mem_monitor(&mon);
uint32_t used_size = mon.total_size - mon.free_size;
char Text[151];
lv_snprintf(Text, 150, "+ HEAP Memory Usable (Kb) %d, Max %d, Total %d\n", ESP.getMaxAllocHeap()/1024, ESP.getFreeHeap()/1024, ESP.getHeapSize()/1024);
lv_snprintf(Text + strlen(Text),150, "+ PSRAM Memory Free (Kb) %d, Total %d\n", ESP.getFreePsram()/1024, ESP.getPsramSize()/1024);
lv_snprintf(Text + strlen(Text), 150, "+ LV Heap %d kB used (%d %%) %d%% frag.\n", used_size / 1024, mon.used_pct, mon.frag_pct);
//lv_snprintf(Text + strlen(Text), 150, "Spiram size (Kb) %d , himem free %d\n", esp_spiram_get_size()/1000, esp_himem_get_free_size()/1000); // Not used, CRASH
lv_snprintf(Text + strlen(Text), 150, "+ Application Version : %d", 1);
label = lv_label_create(cont2);
lv_label_set_long_mode(label, LV_LABEL_LONG_WRAP);
lv_label_set_text(label, Text);
lv_obj_set_size(label, LV_PCT(100), LV_PCT(100));
lv_obj_set_style_text_align(label, LV_TEXT_ALIGN_LEFT, 0);About custom font, where are you front ? (Wich one font you need)
ElMyggo
The crash happens when try to get Psram info
if i disable the Psram line it works, maybe some config/bug for the ESP32S3 / Psram
char Text[151];
//lv_snprintf(Text + strlen(Text), 150, "+ PSRAM Memory Free (Kb) %d, Total %d\n", ESP.getFreePsram()/1024, ESP.getPsramSize()/1024);
lv_snprintf(Text + strlen(Text), 150, "+ Application Version : %d", 1);-
ElMyggo
About custom font, im from Sweden so i use åäö but we solved this erlier on Github
and i think i can modify that now.
Thorgal789
- Target OS: -
Yep @ElMyggo have share his police on the github https://github.com/Smanar/CYD-Domoticz- ... 2100620260
About the issue, have made some search but I can't say if the issue is from the config or the hardware. But there is others users with the same issue.
According the jarvis project can try to replace in the platoformio.ini file
by
In build_flags
Perhaps your device don't have psram, but from the ALI express link it have 8M, there is different version ?
If you can't avoid the crash I will disable it for all board, but it can be usefull later ...
board = esp32-s3-devkitc-1
board_build.partitions = min_spiffs.csv ; Use partitions that allocate 512KB for SPIRAMCode: Select all
board_build.partitions = app3M_fat9M_16MB.csv
board = esp32s3boxCode: Select all
-mfix-esp32-psram-cache-issueIf you can't avoid the crash I will disable it for all board, but it can be usefull later ...
ElMyggo
Have now tested many different settings whitout any luck so i continue to have psram disabled.
I should have 8M memory but i can get a faulty board or something else.
Thorgal789
- Target OS: -
Don't worry, I will disable it by defaut for all OS.
For the moment it's just an information, the code don't use them, so not usefull.
I will re-enable it later when needed.
Code is updated (just disabled the psram debug output)
Thorgal789
- Target OS: -
For thoses one that use the "stand by" mode, or don't use intensely the device, gizmocuz have added a new feature on recent domoticz version.
It's possible now to subscribe on websocket notification only for needed devices.
To enable it, on "test" branch, just enable (For the moment only possible if you don't use "Bonus Home page panel")
On the "tool panel" I have added the Running time, and the total data received by the device by Websocket. the difference is just incredible, at start you will have a enormous JSON, but after it something like 20 time lighter without problem on hudge installation.
-DLIGHTWSOn the "tool panel" I have added the Running time, and the total data received by the device by Websocket. the difference is just incredible, at start you will have a enormous JSON, but after it something like 20 time lighter without problem on hudge installation.
- gizmocuz
Perhaps if you put all used devices in a roomplan, and use this in your initial query, you have a lot less data at startup.
(See the example www/templates/custom.example)
