Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Xenomes
Domoticz version: 2026.4
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Post by Xenomes »
jpvaneijk wrote: Saturday 02 December 2023 15:52 Hi Xenomes,
I'm on a RPi 5 running on Bookworm. Bullseye is no longer supported for this hardware. see:
https://www.raspberrypi.com/documentati ... spberry-pi
Due to changes in the way pip should be handled now, I seem to be running into a problem with getting Tuya working.
2023-12-02 15:04:27.517 Error: Smart Life: (tuya) failed to load 'plugin.py', Python Path used was '/home/MYUSERNAME/domoticz/plugins/Domoticz-TUYA-Plugin/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/usr/local/lib/python3.11/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.11/dist-packages'.
2023-12-02 15:04:27.544 Error: Smart Life: Traceback (most recent call last):
2023-12-02 15:04:27.544 Error: Smart Life: File "/home/MYUSERNAME/domoticz/plugins/Domoticz-TUYA-Plugin/plugin.py", line 65, in <module>
2023-12-02 15:04:27.544 Error: Smart Life: import tuyaha
2023-12-02 15:04:27.544 Error: Smart Life: ModuleNotFoundError: No module named 'tuyaha'
In accordance with the descriptions in the link above, I have created a virtual environment in which pip installations like this can be processed. In doing so, I no longer get the annoying error message that prevents you from continuing the installation process.
It seems to me that from the Plugins folder in Domoticz, in the Plugin.py file is being searched for components that can no longer be found in the default location.
Can you help me get this sorted out?
I see the tuyaha module this question chould be in: viewtopic.php?p=303250
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
willemd
Post by willemd »
I have read through the Tuya plugin thread and this TinyTuya plugin thread.
Just to confirm, for a power plug with energy measurements (LSC Smart Connect from Action), I understand the TinyTuya is the way to go?
Update: in the meantime I have done the setup:
1) first paired the device in the tuya smart app
2) then followed the pdf guide for the IoT developer account setup and connecting the app
Only issue encountered was that I chose western europe datacenter instead of central europe (for Netherlands) so I had to go back and correct
3) then did the installation on the Raspberry
4) then choose the hardware in Domoticz and entered the identifiers
all as per instructions.
Result? Perfect, one switch and four utility device created, values correctly shown. All perfect in one go. Thanks.
nl2rma
Post by nl2rma »
First of all: Thank you Xenomes for this plugin, it works great.
Question: I use it to have a Weau Heatpump in Domoticz and it works.
The plugin created 4 devices Power, Setpoint, Mode and Temperature.
In the Tuya App, and also in the Tuya Iot webpage where I had to link the Heatpump there is an other entity available that seem to be named "Fault".
It displays numbered fault codes (example 4=no flow(E03), 8=Antifreeze protection(E04))
Is there a way to also get the "fault" entity visible as a device/entity in Domoticz?
tnx Royco
Xenomes
Post by Xenomes »
It could be possible, but I need to see the JSON code. You can create an issue on GitHub and post the 'dump.json' from the 'debug_discovery.py'.
Tinytuya
EdwinK
Post by EdwinK »
Varazir wrote: Thursday 04 May 2023 15:53 Hi I keep getting this
2023-05-04 15:29:18.605 TinyTUYA: Update devices in Domoticz
2023-05-04 15:29:18.608 Error: TinyTUYA: Device read failed: bfd6bda7f3a84e2064d97h
Keep seeing this error now. The domoticz log doesn't show anything else.
Varazir
Post by Varazir »
EdwinK wrote: Thursday 18 January 2024 21:13
You checked that the free period for IOT on TUYA hasn't expired ?
//Daniel
Xenomes
Post by Xenomes »
EdwinK wrote: Thursday 18 January 2024 21:13 Keep seeing this error now. The domoticz log doesn't show anything else.
If the 'free period' hasn't expired yet, kindly enable debugging in the hardware tab. You will find a line number indicating the location of the error. Additionally, please provide the version number of the plugin for accurate identification of the correct line. For further assistance, it would be helpful to receive the dump.json file from the debug_discovery.py via private message, allowing me to conduct additional tests.
Tinytuya
EdwinK
Post by EdwinK »
When running the debug_discovery.py script both devices return an empty dump.json. Don't know if the free period has expired. Created connection on
Creation Time : 2023-03-08 16:31:24
Plugin is at version 1.7.0
This is what I could grab from the log.
2024-01-18 23:13:33.045 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:13:33.095 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:13:33.095 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:13:33.096 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:13:33.096 TinyTuya: onHeartbeat called
2024-01-18 23:13:33.096 TinyTuya: onHeartbeat called last run: 60.210793018341064
2024-01-18 23:13:33.096 TinyTuya: [b]Device name=LSC Groundspots id=bfe1829726d568d498bywx category=light[/b]
2024-01-18 23:13:40.006 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:13:40.056 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:13:40.056 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:13:40.056 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:13:40.056 TinyTuya: onHeartbeat called
2024-01-18 23:13:40.056 TinyTuya: onHeartbeat called skipped
[color=#FF0000]2024-01-18 23:15:52.239 Error: TinyTuya: Device read failed: bf6b0558769ceecafdkfze[/color]
2024-01-18 23:16:02.060 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:16:02.110 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:16:02.110 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:02.110 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:16:02.110 TinyTuya: onHeartbeat called
2024-01-18 23:16:02.110 TinyTuya: onHeartbeat called skipped
2024-01-18 23:16:02.745 TinyTuya: Update devices in Domoticz
2024-01-18 23:16:02.774 TinyTuya: Update device value: bfe1829726d568d498bywx Unit: 1 sValue: On nValue: 1 TimedOut=0
2024-01-18 23:16:02.775 TinyTuya: [b]Device name=gang boven id=bf6b0558769ceecafdkfze category=light[/b]
2024-01-18 23:16:12.025 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:16:12.076 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:16:12.076 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:12.076 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:16:12.076 TinyTuya: onHeartbeat called
2024-01-18 23:16:12.076 TinyTuya: onHeartbeat called skipped
2024-01-18 23:16:14.163 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:14.213 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:16:14.263 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:16:14.263 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:14.264 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:16:14.264 TinyTuya: onHeartbeat called
2024-01-18 23:16:14.264 TinyTuya: onHeartbeat called skipped
2024-01-18 23:16:14.264 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:22.043 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:16:22.094 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:16:22.094 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:22.094 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:16:22.094 TinyTuya: onHeartbeat called
2024-01-18 23:16:22.094 TinyTuya: onHeartbeat called skipped
2024-01-18 23:16:24.031 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:16:24.081 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:16:24.081 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:24.081 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:16:24.081 TinyTuya: onHeartbeat called
2024-01-18 23:16:24.081 TinyTuya: onHeartbeat called skipped
2024-01-18 23:16:32.060 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:16:32.111 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:16:32.111 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:32.111 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:16:32.111 TinyTuya: onHeartbeat called
2024-01-18 23:16:32.111 TinyTuya: onHeartbeat called skipped
2024-01-18 23:16:34.048 TinyTuya: Pushing 'onHeartbeatCallback' on to queue
2024-01-18 23:16:34.099 TinyTuya: Processing 'onHeartbeatCallback' message
2024-01-18 23:16:34.099 TinyTuya: Acquiring GIL for 'onHeartbeatCallback'
2024-01-18 23:16:34.099 TinyTuya: Calling message handler 'onHeartbeat' on 'module' type object.
2024-01-18 23:16:34.099 TinyTuya: onHeartbeat called
2024-01-18 23:16:34.099 TinyTuya: onHeartbeat called skipped
wvries
Domoticz version: latest B
Post by wvries »
Hi Edwin,
I had a similar issue where the plugin seems to be held up in a loop requesting OnHeartbeat.
When I would restart the system, the issue would disappear but would come back randomly.
I found out that at the time of the error occurring, I had a lot of IPv6 traffic on my network (not using IPv6 at all).
With trial and error i came to the solution where if I disabled IPv6 on the RPI, the issue would disappear and since then, never came back. Now running stable again for about 1 month.
What i did was the following:
sudo nano /etc/sysctl.conf
Add the following lines:
# Disable IPv6
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
net.ipv6.conf.eth0.disable_ipv6 = 1
sudo nano /etc/rc.local
Add the following line (before exit 0)
service procps reload
reboot the system.
check if there is still IPv6 running with ifconfig (should not have any line with inet6 in it).
Hope this might help you.
Xenomes
Post by Xenomes »
EdwinK wrote: Thursday 18 January 2024 22:38 When running the debug_discovery.py script both devices return an empty dump.json. Don't know if the free period has expired. Created connection on
I don't see a debug line. Did you put the plugin in 'debug: all'?
Tinytuya
EdwinK
Post by EdwinK »
Xenomes wrote: Friday 19 January 2024 16:17
Yes, it is set.
Screen Shot 2024-01-19 at 16.23.19.png (18.81 KiB) Viewed 8632 times
Xenomes
Post by Xenomes »
EdwinK wrote: Friday 19 January 2024 16:24 Yes, it is set.
Okay, strange. Can you use the debug_discovery.py script to generate a dump.json and send it via PM? if you can't upload a json rename it to txt.
Tinytuya
EdwinK
Post by EdwinK »
~/domoticz/plugins/Domoticz-TinyTUYA-Plugin/tools $ sudo python3 debug_discovery.py
No device data returnd for Tuya. Trying again!
debug_discovery: -1 line 53
dump.json is created!
but... dump.json is empty.
Xenomes
Post by Xenomes »
EdwinK wrote: Friday 19 January 2024 20:17 but... dump.json is empty.
Ah, then you didn't edited the file to include the Tuya credentials.
Tinytuya
EdwinK
Post by EdwinK »
Xenomes wrote: Friday 19 January 2024 20:21
I have added my info from the TUYA site, but still
Xenomes
Post by Xenomes »
EdwinK wrote: Friday 19 January 2024 21:36 I have added my info from the TUYA site, but still
If the data you entered is correct, it looks like the subscription is expired. On the plugin page, there is a link to extend it.
Tinytuya
EdwinK
Post by EdwinK »
Thought this fixed it, but alas... no.
have other problems with domoticz to fix first, then i'll try again
gillesMa
Post by gillesMa »
I have a problem with notifications from switches detected through the plugin. When I configure a notification for example for "swichoff", I always receive two notifications, separated by about 2-3 seconds. It's always the case, whether it's a notification through telegram or email for example. And this doesn't happen with a switch from TP-Link. As a consequence I assume the problem is related to the plugin. Does this happen with your setup too ? Any idea how to troubleshoot the problem?
Thank you and best regards.
Xenomes
Post by Xenomes »
gillesMa wrote: Sunday 04 February 2024 19:22 Hello,
Hi gillesMa,
Can you specify the type of device you "switch off"? The plugin checks if the requested state is different from the current state and only changes it if necessary. There are a couple of devices that can override that request.
Tinytuya
gillesMa
Post by gillesMa »
Xenomes wrote: Sunday 04 February 2024 21:13
Hi gillesMa,
They're juste basic wifi Tuya plugs, with an on/off state. Some of them also have electric meters, but it doesn't makes a difference. I also receive two notifications with a Cubetouch. It seems to be the case with all my Tuya devices.
