Page 8 of 25
Re: Easiest way to migrate Openzwave to ZWave-JS-UI
Posted: Monday 20 February 2023 12:08
by JackD
Yesterday I went from Domoticz beta14957 to beta15082 because there were a few updates/fixes which were useful to me.
But since Open-Zwave is depreciated updating is always a bit stressful.
But I am happy to say that updating to beta15082 did not break Open-Zwave (at least for my setup/system).
Don't like tinkering with Domoticz, it just has to run and be reliable, that's why I don't want to switch to ZW-JS, lot of work...
But for now I am a happy camper with Open-Zwave still functioning
Posted: Monday 20 February 2023 15:40
Looking at Pull request 5605 the removal of OpenZwave in Beta is very, very close.
https://github.com/domoticz/domoticz/pull/5605
Posted: Monday 20 February 2023 16:32
by MikeyMan
Pff... Why remove it... Just let it in...
Posted: Monday 20 February 2023 16:42
MikeyMan wrote: Monday 20 February 2023 16:32
As OpenZwave is not compiling anymore on recent OS.....
Posted: Monday 20 February 2023 19:16
by JackD
To bad......
Hope that is will clearly be marked from which update version OpenZwave will not be implemented in Domoticz anymore.
From a programmer/developers point of view, probably a logical step to get rid of Open-Zwave in Domoticz, but keep in mind that a lot of users still use OpenZwave. And the new Domoticz Zwave-JS way adds again a extra layer of stuff. Not for everybody that easy to master.
But then it seems to be a thing of this day and age... updates, updates and more update... but sadly for me this mostly means just more work to keep things functioning with little benefits and/or buying new hardware because the old is no long supported. I am not speaking only of Domoticz here, but software/apps in general. Backward compatibility seems to be a nasty word these days.
Sorry for the somewhat negative post, but I see a lot of work coming my way in the near future, perhaps a good time to take a look at other domotica software (but don't think they will be much different
). We will wait and see what the future brings.
But still kudos for everyone who made/makes Domoticz possible, complaining like I do in this post is much easier than creating ......
Posted: Monday 20 February 2023 20:48
I also see a lot of happy zwavejsui users so yes it will have impact but it should be manageable.
Posted: Tuesday 21 February 2023 9:58
by Benneton
El Zorro,
Thank you for sharing, I will look into and let this thread know if I was able to get it working.
Bernard
Posted: Tuesday 21 February 2023 10:45
by lost
waltervl wrote: Monday 20 February 2023 16:42
As this looked to be related to openssl, so probably only linked to the OZW 1.6 addition to retrieve configs updates online at startup (that never worked on my system according to logs), issue may probably have been solved removing this update code... this time! But even if I regret the decision, I understand there is no will to maintain no-future-OZW, even in a minimal way for those that will just stop extending the zwave part of their system because that's no more an easy to use protocol due to it's built-in nature...
But IMO, the zwaveJS software pile nightmare does not attract new users and available devices confirms: Zwave is now in the 700 and 800 series on the chip side, but most devices still sold are 500 series (or zwave+)!
Posted: Tuesday 21 February 2023 11:07
by MikeyMan
andrehj wrote: Sunday 15 January 2023 12:30
andrehj wrote: Saturday 14 January 2023 13:02
Thanks! That guide looks very promising! After everything (hopefully) works, I'll write a full guide here.
Today I successfully finished my upgrade. Pi is now running Domoticz 2022.2 with ZWave-JS-UI (via SNAP) and Bullseye OS.
Since there is no complete guide for this upgrade process, I decided to make my own.
The basics steps I made were:
1. Backup Z-Wave data
2. Install Mosquitto
3. Install Snap
4. Install Z-Wave JS UI
5. Disable OpenZwave gateway
6. Configure Z-Wave JS UI
7. Install MQTT Auto Discover Client gateway in Domoticz
8. Replace old Z-Wave devices
9. Delete old Z-wave controller
10. Upgrade Domoticz to 2022.2
11. Upgrade Pi from Buster to Bullseye
According
viewtopic.php?p=296307#p296307 the upgrade to bullseye should be done after the Domoticz upgrade to 2022.2, but in step 11 I ran into some minor conflicts which made me have to redo two of the installation steps of Mosquitto (2.5) and Snap (3.3b). Maybe it is better to upgrade your Pi to Bullseye as step 1 instead of 11.
In detail, there were many, many more steps:
1. Backup Z-Wave data from Domoticz
Most imporant data is:
1. Security Network Key
2. List of NodeID's and node names
3. The USB address of your Z-Wave usb stick.
2. Install Mosquitto according https://randomnerdtutorials.com/how-to-install-mosquitto-broker-on-raspberry-pi/ (en https://www.domoticz.com/wiki/MQTT)
1. Update and upgrade system of Pi:
sudo apt update && sudo apt upgrade
2. Install Mosquitto:
sudo apt install -y mosquitto mosquitto-clients
3. Make Mosquitto auto start when the Raspberry Pi boots
sudo systemctl enable mosquitto.service
4. Start-up and version check:
mosquitto -v (Gives version 1.5.7, version 2.xx will be installed with Bullseye)
5. Enable remote access without authentication:
sudo nano /etc/mosquitto/mosquitto.conf
Add these lines at the end:
listener 1883
allow_anonymous true
Use CTRL-X to exit and save.
6. Restart Mosquitto:
sudo systemctl restart mosquitto
7. Test status of Mosquitto:
sudo systemctl status mosquitto
8. Check version:
mosquitto -h | grep version (again version 1.5.7)
3. Install Snap according https://snapcraft.io/docs/installing-snap-on-raspbian en https://community.home-assistant.io/t/install-and-setup-zwave-js-ui-with-snap-on-a-raspberry-pi/486484
1. Update system:
sudo apt update
2. Install snap
sudo apt install snapd
3. Work around a bug which seems to exist only on Raspberry Pi OS 32-bit system: https://stackoverflow.com/questions/42443273/raspberry-pi-libarmmem-so-cannot-open-shared-object-file-error/50958615#50958615 en https://github.com/zwave-js/zwave-js-ui/discussions/1216
3a
sudo nano /etc/ld.so.preload
Comment out this line:
(Change /usr/lib/arm-linux-gnueabihf/libarmmem.so to #/usr/lib/arm-linux-gnueabihf/libarmmem.so)
3b
sudo visudo
add :/snap/bin to the end of the secure_path, BUT before the closing quote ". Note the :-separator!
4. Reboot Pi
sudo reboot
5. After this, install the core snap in order to get the latest snapd.
sudo snap install --channel=stable core
6. Enable hotplug support and restart:
sudo snap set system experimental.hotplug=true
sudo systemctl restart snapd
7. To test your system, install the hello-world snap and make sure it runs correctly:
sudo snap install hello-world
hello-world
4. Install Z-Wave JS UI according https://www.domoticz.com/wiki/Zwave-JS-UI en https://zwave-js.github.io/zwave-js-ui/#/getting-started/other-methods and https://community.home-assistant.io/t/install-and-setup-zwave-js-ui-with-snap-on-a-raspberry-pi/486484
1. Install zwave-js-ui
sudo snap install --channel=stable zwave-js-ui
2. Give the package access to use USB devices and observe hardware:
sudo snap connect zwave-js-ui:raw-usb
3. Needed for the program to list available devices in the UI:
sudo snap connect zwave-js-ui:hardware-observe
4. Open help to see some info about commands:
zwave-js-ui.help
5. To access the UI from outside your Pi:
sudo snap set zwave-js-ui server.host=0.0.0.0
6. Then we need to connect the serial-port to the plug zwave-js-ui. First list available serial slots:
sudo snap interface serial-port
7. Then use this command to connect the correct serial slot to zwave-js-ui (use correct core: from list you got in previous step):
sudo snap connect zwave-js-ui:serial-port core:aeotecz-stickgen5zw0
8.Turn service on:
sudo zwave-js-ui.enable
5. Disable (not delete!) OpenZwave gateway (USB stick) in Domoticz (menu Setup - hardware)
Idea is that the old devices are not deleted.
Sadly this did not work. All my old devices disappeared. Maybe I should have upgraded Domoticz from 2022.1 to 2022.2 first. See also https://www.domoticz.com/forum/viewtopic.php?p=297183&sid=8601aab4dc1990f1d0199e8caced281b#p297183
6. Configure Z-Wave JS UI (from https://www.domoticz.com/wiki/Zwave-JS-UI)
1. Browse to http://192.168.178.41:8091
2. Menu settings → MQTT:
Retain on
3. Menu settings → Gateway:
Use nodes names on
Ignore location on
Include Node info on
4. Menu settings → Home Assistant:
MQTT Discovery on
Retained discovery on (not mentioned in text, but that's according picture)
5. Menu settings → Z-Wave
Get the key from Domoticz (mine was just "0102030405060708090A0B0C0D0E0F10") and enter as S2 Unauthenticated.
Enter the right Serial Port address. In my case: /dev/ttyUSB-ZwaveStick
I also had to enter something at S0 legacy to get rid of an error message regarding the security status of a Qubino ZMNHDD. I just pressed the button to generate a random key. Result was 643294277C1E50FAEA0C497F116F9897.
6. Menu settings
Save settings (Press "save" at the bottom)
7. Menu Control Panel:
Give all nodes a useful name based on their Node ID and the info you saved in step 1
7. Install MQTT Auto Discover Client gateway in Domoticz (see https://www.domoticz.com/wiki/MQTT#Add_hardware_.22MQTT_Auto_Discovery_Client_Gateway.22)
1. Domoticz → Menu Setup → Hardware
Name = MQTT Auto Discovery
Type = MQTT Auto Discover Client Gateway with LAN interface
Data Timeout: Disabled
Remote Address: localhost
Username: Leave empty when mqtt broker has no user accounts setup else give mqtt broker account name
Password: Leave empty when mqtt broker has no user accounts setup else give mqtt broker account password
Auto Discovery Prefix: homeassistant
2. Make sure it is enabled and press "add".
3. New devices are created in Domoticz by MQTT AutoDiscover
(After renaming the devices in Z-Wave JS UI I should have gotten nice names, but sadly that didn't work...)
4. Domoticz → Menu Setup → Devices
Manually rename all new devices to something usefull
8. Replace old Z-Wave devices with new ones
If you want to keep the history logging of the old devices then you need to replace the old device with the new one if identical devices are created. Use the replace function in Edit device, see wiki https://www.domoticz.com/wiki/Managing_Devices#Replace_device Devices that were replaced will get the old name and old IDX, no need to change scripts.
9. Delete old Z-wave controller in Domoticz.
Select old Z-wave controller (Aeotec USB stick) and press Delete.
2. Reboot pi
sudo reboot
10. Upgrade Domoticz to 2022.2 according https://www.domoticz.com/forum/viewtopic.php?t=39291
1. Backup version 2022.1
sudo service domoticz stop
sudo cp -R /home/pi/domoticz /home/pi/domoticz_2022.1 (may take while...)
sudo service domoticz start
2. Make sure you're on the Stable Release Channel
Menu Setup → Settings → Software Updates → Release Channel → Stable
3. Update to 2022.2 (called #14606 in dialogue box...)
Menu Setup → Check for updates → OK
11. Upgrade Pi to Bullseye according https://pimylifeup.com/upgrade-raspberry-pi-os-bullseye/ and https://linuxhint.com/upgrade-raspberry-pi-os-buster-to-bullseye/
1. Backup your Pi.
1. Check your current version:
lsb_release -a
2. Update Raspberry Pi Repositories List
sudo apt update
3. Upgrade Packages on Raspberry Pi
sudo apt dist-upgrade -y
4. Upgrade Firmware
sudo rpi-update
sudo reboot
5. Edit Raspberry Pi Source Lists
In /etc/apt/sources.list replace all instances of "buster" by "bullseye".
sudo nano /etc/apt/sources.list or use WinSCP
Do the same for any other sources lists in the /etc/apt/sources.list.d directory:
sudo nano /etc/apt/sources.list.d/raspi.list
sudo nano /etc/apt/sources.list.d/vscode.list
6. Update package lists
sudo apt update
7. Install missing packages:
sudo apt install -y libgcc-8-dev gcc-8-base
(enter yes if asked if services have to be automatically restarted)
8. Upgrade to Bullseye
sudo apt full-upgrade
Ran into Error:
E: Failed to fetch http://mirror.serverius.net/raspbian/raspbian/pool/main/p/protobuf-c/libprotobuf-c1_1.3.3-1+b2_armh f.deb Undetermined Error [IP: 5.255.95.70 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Decided to rerun command, second time it worked OK.
Installer reported change conflict in 3 files. Backed up all three and let installler use new versions.
/etc/default/useradd
/etc/sudoers
Decided not to do anything about useradd
Fixed /etc/sudoers with command sudo visudo (see snap configuration above)
Fixed conflict in /etc/mosquitto/mosquitto.conf by adding the two missing lines (see mosquitto configuration above)
9. Fix error in /etc/systemd/system/dhcpcd.service.d/wait.conf
Check if file exists:
sudo stat /etc/systemd/system/dhcpcd.service.d/wait.conf
Edit the file
sudo nano /etc/systemd/system/dhcpcd.service.d/wait.conf
Replace
ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -w
by
ExecStart=/usr/sbin/dhcpcd -q -w
Exit and save.
10. Modify Boot config
sudo nano /boot/config.txt
In section [pi4] comment out dtoverlay=vc4-fkms-v3d (put a # in front of the line)
In section [all] add the line dtoverlay=vc4-kms-v3d
Exit and save.
11. Reboot Pi.
sudo reboot
12. Check version to see if upgrade was successful:
lsb_release -a
13. Cleanup (if everything works)
sudo apt autoclean
14. Reinstall dev version of Python plugin to get plugins working
sudo apt install python3-dev
15. Restart Domoticz
sudo service domoticz restart
I hope this guide is useful for anyone who still has to do the same upgrade. If you like it, please let me know.
Did you ever manage to replace the devices from the dashboard pages?
Posted: Saturday 25 February 2023 15:00
by AutoUlf
3. Install Snap
According
listener 1883
8. Check version:
1. Update system:
sudo apt update
2. Install snap
3a
3b
sudo visudo
4. Reboot Pi
sudo reboot
hello-world
zwave-js-ui.help
8.Turn service on:
Retain on
Use nodes names on
Ignore location on
MQTT Discovery on
6. Menu settings
2. Reboot pi
sudo reboot
1. Backup your Pi.
lsb_release -a
sudo apt update
4. Upgrade Firmware
sudo rpi-update
sudo reboot
sudo apt update
Ran into Error:
/etc/sudoers
Edit the file
Replace
by
Exit and save.
Exit and save.
11. Reboot Pi.
sudo reboot
lsb_release -a
sudo apt autoclean
I followed your guide and everything went well. Thank you so much.
Posted: Tuesday 28 February 2023 15:02
by thomasbaetge
just a quick question, is MQTT Auto Discover Client gateway supposed to replace the (in my system) already existing MQTT Client gateway with LAN interface, or are they supposed to coexist in the system?
(I have a lot of MQTT stuff already and don't want to break it)
thanks!
Posted: Tuesday 28 February 2023 23:15
They can coexist together. You can also setup an extra separate mqtt AD gateway for each integration if you want to.
Posted: Wednesday 01 March 2023 16:59
by Ayep
elzorrovega wrote: Monday 02 January 2023 19:24
What is the best way to Start Docker Containers Automatically After a Reboot?
Hello there, did you ever figure this out?
I'm currently running in the terminal the following command, which seems to work great so far :
sudo docker run --rm -it -p 8091:8091 -p 3000:3000 -e TZ=Europe/Paris --device=/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave --mount source=zwave-js-ui,target=/usr/src/app/store zwavejs/zwave-js-ui:latest
Can I stick this in the rc.local file?
Many thanks.
Edit : I should mention I am running domoticz on a raspberry pi 4.
Posted: Saturday 04 March 2023 11:05
by Ayep
I created a docker-compose.yml file, in ~/store/.
indeed launches a new instance, with automatically resumes after reboot. However, I have lost all of my settings and configs. Before doing any damage, how I can transfer the settings that were in the initial command, into this new instance?
Initial command was :
If I reconfigure the new instance, I will get another new load of zwave devices, and will have to retransfer and reconfigure everything I assume?
Many thanks for the advice.
Posted: Saturday 04 March 2023 13:05
by JackD
Yesterday I updated to beta15109 because of a usefull RFXcom update.
But because of the depreciation of OpenZwave always a stressful moment.
But I am happy to say that beta15109 did not break my OpenZwave
OpenZwave and the other parts of my Domoticz system still work fine.......
Posted: Sunday 05 March 2023 11:36
by madpatrick
JackD wrote: Saturday 04 March 2023 13:05
I think they will make an announcement when OZW will be depreciated
(hopely not very soon.....)
Posted: Sunday 05 March 2023 11:50
by Benneton
HI
I am still reading into this change tho ZWave-JS-UI.
I noticed that in one go ZWave-JS-UI is installed on the PI directly and in another guide it is installed in a docker / as docker image.
What would the benefit be to install in Docker?
My setup has MQTT and node red running to scrape my solar panel monitoring box, which works fine.
Can I not just add/install the ZWave-JS-UI and feed that into MQTT then Domoticz?
I am not a complete noob but this is getting and taking more and more time to maintain and keep running.
When I started with Domoticz it was (my opinion) simple and straight forward to install, and add RFX, Z-Wave and Zigbee (Hue).
Now it seems to get to more and more add on's (which can be a good way to go) which require in depth knowledge of Linux, and some programming skills. My biggest fear is when I get this installed, how to maintain and keep up to date.
For me as simple user, it would be great if within Domoticz you could select the various packages and have it working, instead of installing multiple bits and pieces and then hope it will work in Domoticz.
Thank you all for letting me know on the Docker bit as I get somewhat confused.
Bernard
Posted: Sunday 05 March 2023 12:35
by JackD
For me the big positive thing about software in a docker container is that it is extremely easy to revert back to the previous version if a update has bugs in it and does not work correctly. That is why I also run Domoticz in a Docker container.
On the other subject, I think that it would help many Domoticz/Zwave users if Zwave-JS-UI could be integrated in Domoticz, and not a extra layer of "external stuff" like it is now. But do not know if this is technically possible within a resalable amount of effort. The same could be said for a MQTT broker.
Posted: Sunday 05 March 2023 13:18
by rron
Benneton wrote: Sunday 05 March 2023 11:50
HI
Bernard
I agree with you. For some users like me it is better too have only one packet to install and to maintain
Posted: Thursday 09 March 2023 10:20
by Domoberry
Reading this post with interest, multiple relevant tips while updating from OZW! After some challenges I am now at the point where zwave-js-ui runs in Docker and I’m able to see its messages using an MQTT tool.
Practical asks:
- is there a dependency on Mosquitto version? (I have 1.5.7)
- I have the MQTT gateway for some other devices (Tasmota, EMS-ESP), I understood from this thread that I can add the MQTT AD gateway next to the existing one and configure it with the Prefix of zwave-js-ui from HA settings section, no need to enter the zwave-js-ui prefix from MQTT settings section as the AD process will handle this. Correct?
Thanks in advance for any replies!
