Page 8 of 11
Re: Support for Somfy Connexoon and Tahoma
Posted: Tuesday 04 June 2024 18:54
by madpatrick
2024-06-04 18_54_19-Support for Somfy Connexoon and Tahoma - Page 7 - Domoticz.png
2024-06-04 18_54_19-Support for Somfy Connexoon and Tahoma - Page 7 - Domoticz.png (7.81 KiB) Viewed 4000 times
Posted: Tuesday 04 June 2024 19:02
by nene82
madpatrick wrote: Tuesday 04 June 2024 18:54 2024-06-04 18_54_19-Support for Somfy Connexoon and Tahoma - Page 7 - Domoticz.png
attached the logs
 2024-06-04 19:00:37.702 Error: Tahoma_Switch: (tahomaIO) failed to load 'plugin.py', Python Path used was '/home/user/domoticz/plugins/somfy/:/usr/local/lib/python310.zip:/usr/local/lib/python3.10:/usr/local/lib/python3.10/lib-dynload:/usr/local/lib/python3.10/site-packages'.
2024-06-04 19:00:37.704 Error: Tahoma_Switch: Traceback (most recent call last):
2024-06-04 19:00:37.704 Error: Tahoma_Switch: File "/home/user/domoticz/plugins/somfy/plugin.py", line 91, in <module>
2024-06-04 19:00:37.704 Error: Tahoma_Switch: import tahoma
2024-06-04 19:00:37.704 Error: Tahoma_Switch: File "/home/user/domoticz/plugins/somfy/tahoma.py", line 1, in <module>
2024-06-04 19:00:37.704 Error: Tahoma_Switch: import requests
2024-06-04 19:00:37.704 Error: Tahoma_Switch: ModuleNotFoundError: No module named 'requests
Posted: Tuesday 04 June 2024 19:04
by madpatrick
can you please try
apt install python3 libpython3-dev libpython3.10-dev
Starting the plugin makes no sense.
You need to install the request module
Posted: Tuesday 04 June 2024 19:13
by nene82
madpatrick wrote: Tuesday 04 June 2024 19:04 can you please try
user@Domoticz:~$ cd Python-3.10.13
user@Domoticz:~/Python-3.10.13$ apt install python3 libpython3-dev libpython3.10-dev
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
user@Domoticz:~/Python-3.10.13$ sudo apt install python3 libpython3-dev libpython3.10-dev
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package libpython3.10-dev
E: Couldn't find any package by glob 'libpython3.10-dev'
user@Domoticz:~/Python-3.10.13$ ^C
Posted: Tuesday 04 June 2024 21:57
by JanJaap
ok, so you python libs are installed in a place where domoticz isn't looking for them.
Please try the below:
Check the version:
python3 -V
Make sure that you have libpython installed, it needs to match the version you have. You have Python 3.10.x then you make sure you have libpython3.10. Use this command to check:
 dpkg --get-selections | grep libpython
If it is not there then use :
sudo apt install libpython3.10
If you still do not see the python version in Domoticz menu Setup - About Domoticz please install python3-dev:
sudo apt-get install python3-dev
then try to import the library:
sudo pip3 python3-requests
if no pip3:
sudo apt-get install python3-pip
Posted: Tuesday 04 June 2024 22:49
by nene82
JanJaap wrote: Tuesday 04 June 2024 21:57 ok, so you python libs are installed in a place where domoticz isn't looking for them.
Check the version:
python3 -V
if no pip3:
This is what all the requested actions give
user@Domoticz:~$ python3 -V
Python 3.9.2
user@Domoticz:~$  dpkg --get-selections | grep libpython
libpython2-stdlib:arm64                         install
libpython2.7-minimal:arm64                      install
libpython2.7-stdlib:arm64                       install
libpython3-dev:arm64                            install
libpython3-stdlib:arm64                         install
libpython3.9:arm64                              install
libpython3.9-dev:arm64                          install
libpython3.9-minimal:arm64                      install
libpython3.9-stdlib:arm64                       install
user@Domoticz:~$ sudo apt install libpython3.10
E: Couldn't find any package by glob 'libpython3.10'
user@Domoticz:~$ sudo apt-get install python3-dev
python3-dev is already the newest version (3.9.2-3).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
user@Domoticz:~$
And this is what I see in the logs at startup
2024-06-05 11:48:46.280 Status: PluginSystem: Started, Python version '3.10.13', 4 plugin definitions loaded.
Posted: Wednesday 05 June 2024 19:39
by Thorgal789
Pip have nothing to see with your deconz version, and you can have 4 versions on the same host if you want.
But pip is needed to add/remove python package/library, so it's something for me mandatory.
Posted: Tuesday 02 July 2024 8:57
by nene82
Good morning,
Problem solved, topic can be closed!
Thank you all for your participation, good luck.
J.P.
Posted: Wednesday 03 July 2024 9:52
by Filnet
I use Tahoma Switch
I install plugin.
Here are the messages:
 2024-07-03 09:12:35.324 Status: Somfy Tahoma IO: Stop directive received.
2024-07-03 09:12:35.412 Status: Somfy Tahoma IO: Exiting work loop.
2024-07-03 09:12:35.425 Status: Somfy Tahoma IO: Stopping threads.
2024-07-03 09:12:35.425 Status: Somfy Tahoma IO: Stopped.
2024-07-03 09:12:35.426 Status: Somfy Tahoma IO: Entering work loop.
2024-07-03 09:12:35.426 Somfy Tahoma IO: Worker thread started.
2024-07-03 09:12:35.427 Status: Somfy Tahoma IO: Started.
2024-07-03 09:12:35.814 Status: Somfy Tahoma IO: Initialized version 4.2.16, author 'MadPatrick'
2024-07-03 09:12:35.816 Status: Somfy Tahoma IO: Location does not exist, logging to default location
2024-07-03 09:12:35.816 Status: Somfy Tahoma IO: Starting Tahoma blind plugin, logging to file somfy.log
2024-07-03 09:12:35.816 Somfy Tahoma IO: Debug logging mask set to: PYTHON
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameters count: 25
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'HardwareID':'35'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'HomeFolder':'/home/pi/domoticz/plugins/somfy/'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'StartupFolder':'/home/pi/domoticz/'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'UserDataFolder':'/home/pi/domoticz/'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Database':'/home/pi/domoticz/domoticz.db'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Language':'en'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Version':'4.2.16'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Author':'MadPatrick'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Name':'Somfy Tahoma IO'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Port':'8443'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Username':'xxxxxxx@xxxxxxx'
2024-07-03 09:12:35.816 Somfy Tahoma IO: Parameter: 'Password':'xxxxxxxx'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'Key':'tahomaIO'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'Mode1':'False'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'Mode2':'20'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'Mode3':'2xxx-xxxx-xxx7'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'Mode4':'Local'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'Mode6':'Debug'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'DomoticzVersion':'2024.4 (build 16110)'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'DomoticzHash':'252859365'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Parameter: 'DomoticzBuildTime':'2024-07-02 08:10:24'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Configuration count: 5
2024-07-03 09:12:35.817 Somfy Tahoma IO: Configuration 'MajorVersion':'4'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Configuration 'MinorVersion':'2'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Configuration 'patchVersion':'16'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Configuration 'plugin version':'4.2.16'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Configuration 'token':'6xxxxxxxxxxxxxxxx2'
2024-07-03 09:12:35.817 Somfy Tahoma IO: Device count: 3
2024-07-03 09:12:35.817 Somfy Tahoma IO: Device: internal://2xxx-xxxx-xxx7/pod/0 - DeviceID: 'internal://2xxx-xxxx-xxx7/pod/0', Units: 1
2024-07-03 09:12:35.817 Somfy Tahoma IO: Device: io://2xxx-xxxx-xxx7/14845326 - DeviceID: 'io://2xxx-xxxx-xxx7/14845326', Units: 1
2024-07-03 09:12:35.817 Somfy Tahoma IO: Device: io://2xxx-xxxx-xxx7/285159 - DeviceID: 'io://2xxx-xxxx-xxx7/285159', Units: 1
2024-07-03 09:12:35.818 Somfy Tahoma IO: os.path.exists(Parameters['Mode5']) = False
2024-07-03 09:12:35.818 Somfy Tahoma IO: Starting version: 4.2.16
All seems to be perfect.
Switches are well created. But when I initiate a command, nothing happens.
No error message, just this:
 2024-07-03 09:40:30.109 Status: User: Phil (IP: 192.168.1.106) initiated a switch command (1335/Store-banne/Close)
Could you tell me where is my mistake?
Thanks for your help.
Posted: Wednesday 03 July 2024 10:17
by Filnet
I solved my problem!
The switch on the Somfy remote (Situo 5) must be in "Auto".
Posted: Wednesday 11 September 2024 12:45
by Carthman
My next house is being built and I'm looking for my next home automation system.
I'm actually on Domoticz, and I would really want to keep it.
I will have Somfy io devices, such has motorised garage doors and portal.
They are natively supported on the Tahoma Switch.
Is this pluggin fully works with Tahoma Switch ?
Could it work fine with the Rail-Din version ? (I think it's the same OS)
I will also have other io devices, such as an Atlantic Water Heater and Ventilation System.
It has been implemented in a HA Somfy pluggin.
Could it be possible to do it in this Domoticz pluggin ?
Posted: Wednesday 11 September 2024 14:34
by gizmocuz
I control my Somfy blinds with:
- RFXCom 433Mhz transceiver (viewtopic.php?t=38740)
- ESPSomfy-RTS (https://github.com/rstrouse/ESPSomfy-RTS)
Posted: Thursday 12 September 2024 14:58
by Rik60
I am controlling the Somfy devices with the Tahoma Switch. Works fine with the plugin. I am controlling 2 roller shutters, 3 screens and 1 awning. Because of the awning i use the beta version of the plugin.
Posted: Saturday 19 October 2024 11:25
by Morek86
Hey All,
I need your support as I am struggling with adding my Tahoma Switch devices (blinds and garage doors) to my Domoticzi devices.
Tried already couple of times with installing fresh Pi, Domoticz and all plugins as per Git Hub but still no luck. Tahoma account active with Developer Mode switched on. Although account is created via Somfy.pl site.
What I am doing wrong or what I am missing?
Below log from Domoticz:
2024-10-19 11:18:27.504 Status: Somfy: Initialized version 4.2.16, author 'MadPatrick'
2024-10-19 11:18:27.505 Status: Somfy: Location /var/log/somfy does not exist, logging to default location
2024-10-19 11:18:27.505 Status: Somfy: Starting Tahoma blind plugin, logging to file somfy.log
2024-10-19 11:18:27.506 Somfy: Starting version: 4.2.16
2024-10-19 11:18:33.292 Error: Somfy: Call to function 'onStart' failed, exception details:
2024-10-19 11:18:33.332 Error: Somfy: Traceback (most recent call last):
2024-10-19 11:18:33.332 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 174, in _new_conn
2024-10-19 11:18:33.332 Error: Somfy: conn = connection.create_connection(
2024-10-19 11:18:33.332 Error: Somfy: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-10-19 11:18:33.332 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 73, in create_connection
2024-10-19 11:18:33.332 Error: Somfy: for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
2024-10-19 11:18:33.332 Error: Somfy: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-10-19 11:18:33.332 Error: Somfy: File "/usr/lib/python3.11/socket.py", line 962, in getaddrinfo
2024-10-19 11:18:33.332 Error: Somfy: for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
2024-10-19 11:18:33.332 Error: Somfy: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-10-19 11:18:33.332 Error: Somfy: socket.gaierror: [Errno -2] Name or service not known
2024-10-19 11:18:33.333 Error: Somfy: During handling of the above exception, another exception occurred:
2024-10-19 11:18:33.333 Error: Somfy: Traceback (most recent call last):
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 704, in urlopen
2024-10-19 11:18:33.333 Error: Somfy: httplib_response = self._make_request(
2024-10-19 11:18:33.333 Error: Somfy: ^^^^^^^^^^^^^^^^^^^
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 387, in _make_request
2024-10-19 11:18:33.333 Error: Somfy: self._validate_conn(conn)
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 1045, in _validate_conn
2024-10-19 11:18:33.333 Error: Somfy: conn.connect()
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 358, in connect
2024-10-19 11:18:33.333 Error: Somfy: self.sock = conn = self._new_conn()
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 186, in _new_conn
2024-10-19 11:18:33.333 Error: Somfy: raise NewConnectionError(
2024-10-19 11:18:33.333 Error: Somfy: urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fac49db10>: Failed to establish a new connection: [Errno -2] Name or service not known
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 489, in send
2024-10-19 11:18:33.333 Error: Somfy: resp = conn.urlopen(
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 788, in urlopen
2024-10-19 11:18:33.333 Error: Somfy: retries = retries.increment(
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 592, in increment
2024-10-19 11:18:33.333 Error: Somfy: raise MaxRetryError(_pool, url, error or ResponseError(cause))
2024-10-19 11:18:33.333 Error: Somfy: urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='2034-6295-1023.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/events/register (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fac49db10>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2024-10-19 11:18:33.333 Error: Somfy: File "/home/Morek/domoticz/plugins/somfy/plugin.py", line 576, in onStart
2024-10-19 11:18:33.333 Error: Somfy: _plugin.onStart()
2024-10-19 11:18:33.333 Error: Somfy: File "/home/Morek/domoticz/plugins/somfy/plugin.py", line 172, in onStart
2024-10-19 11:18:33.333 Error: Somfy: self.tahoma.register_listener()
2024-10-19 11:18:33.333 Error: Somfy: File "/home/Morek/domoticz/plugins/somfy/tahoma_local.py", line 254, in register_listener
2024-10-19 11:18:33.333 Error: Somfy: response = self.listener.register_listener(self.base_url_local + "/events/register", headers=self.headers_with_token, verify=False)
2024-10-19 11:18:33.333 Error: Somfy: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-10-19 11:18:33.333 Error: Somfy: File "/home/Morek/domoticz/plugins/somfy/listener.py", line 42, in register_listener
2024-10-19 11:18:33.333 Error: Somfy: response = requests.post(url, headers=headers, verify=verify, timeout=timeout)
2024-10-19 11:18:33.333 Error: Somfy: File "/usr/lib/python3/dist-packages/requests/api.py", line 115, in post
2024-10-19 11:18:33.334 Error: Somfy: return request("post", url, data=data, json=json, **kwargs)
2024-10-19 11:18:33.334 Error: Somfy: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-10-19 11:18:33.334 Error: Somfy: File "/usr/lib/python3/dist-packages/requests/api.py", line 59, in request
2024-10-19 11:18:33.334 Error: Somfy: return session.request(method=method, url=url, **kwargs)
2024-10-19 11:18:33.334 Error: Somfy: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 587, in request
2024-10-19 11:18:33.334 Error: Somfy: resp = self.send(prep, **send_kwargs)
2024-10-19 11:18:33.334 Error: Somfy: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 701, in send
2024-10-19 11:18:33.334 Error: Somfy: r = adapter.send(request, **kwargs)
2024-10-19 11:18:33.334 Error: Somfy: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 565, in send
2024-10-19 11:18:33.334 Error: Somfy: raise ConnectionError(e, request=request)
2024-10-19 11:18:33.334 Error: Somfy: requests.exceptions.ConnectionError: HTTPSConnectionPool(host='2034-6295-1023.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/events/register (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fac49db10>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2024-10-19 11:18:57.090 Error: Somfy: Failed to request data: HTTPSConnectionPool(host='2034-6295-1023.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f74f96b90>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2024-10-19 11:19:02.484 RF868: Temp + Humidity (Strych)
2024-10-19 11:19:21.099 Error: Somfy: Failed to request data: HTTPSConnectionPool(host='2034-6295-1023.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f74f97590>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2024-10-19 11:19:34.153 RF868: Temp + Humidity (Lenka)
2024-10-19 11:19:44.285 RF868: Temp + Humidity (Łazienka)
2024-10-19 11:19:45.107 Error: Somfy: Failed to request data: HTTPSConnectionPool(host='2034-6295-1023.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f74f97b10>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2024-10-19 11:20:09.115 Error: Somfy: Failed to request data: HTTPSConnectionPool(host='2034-6295-1023.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f74f97e10>: Failed to establish a new connection: [Errno -2] Name or service not known'))
Posted: Friday 28 February 2025 4:34
by Schim57300
Thank you for this post and for the README file which is very clear.
This post was very helpful for me and I would like to share my experience in case it would help someone else.
It seems Somfy does not sell the Connexoon anymore, they now sell the Connectivity kit which is a Tahoma Switch "light"
You will find the difference between both devices (in french) here
The connectivity kit is less expensive, very easy to configure, manage IO and RTS but there is no developper mode.
That means it won't be possible to use the local mode with this Connectivity kit.
I tried to use the Web function but it seems to be not ok
ERROR    - plugin.py          - Failed to request data: HTTPSConnectionPool(host='tahomalink.com', port=443): Max retries exceeded with url: /enduser-mobile-web/enduserAPI/login (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f84119970>, 'Connection to tahomalink.com timed out. (connect timeout=10)'))
I think I succeeded in settuping the access to the the Connectivity kit:
- In my DHCP I set a fixed IP for the device
- In the /etc/hosts of my raspberry I set the DNS
- From my raspberry I can ping the device using its PIN
ping 2115-9012-2458.local
PING 2115-9012-2458.local (192.168.0.162) 56(84) bytes of data.
64 bytes from 2115-9012-2458.local (192.168.0.162): icmp_seq=1 ttl=64 time=48.9 ms
64 bytes from 2115-9012-2458.local (192.168.0.162): icmp_seq=2 ttl=64 time=66.5 ms
64 bytes from 2115-9012-2458.local (192.168.0.162): icmp_seq=3 ttl=64 time=90.8 ms
I succeeded in creating an account on www.somfy.fr/login
I can see my device and my blinds
The github page mentions another Somfy website => www.somfy.nl/inloggen
My french Somfy account is not recognized on this version..
:?: I wonder if this is two different account? And does a french Somfy account would work with this Domoticz plugin?
More over I can not connect myself on the Tahoma website => classic.tahomalink.com
I think there is no way to connect to tahomalink with such a device.
I just asked the question on the Somfy forum, I'll keep you in touch here
forum.somfy.fr/questions/3561245-peut-acceder-tahomalink-kit-connectivite
No local mode and no access to Web function...
I think the Connectivity kit won't work with Domoticz.
I ordered a Tahoma Swith... Once I will receive it, I'll test it and I will put a feedback here.
Posted: Saturday 01 March 2025 18:51
by Schim57300
I just received my Tahoma Switch. It is possible to activate the "developper mode" on this device
Once the hardware is configured in Domoticz, it seems the plugin is able to connect with the Tahoma :D
The point is I'm not able to fetch the devices...
In cas someone could help me?
Please find below the logs
2025-03-01 18:40:43,488 - INFO     - plugin.py          - starting plugin version 4.2.16
2025-03-01 18:40:43,490 - INFO     - plugin.py          - Starting version: 4.2.16
2025-03-01 18:40:43,708 - INFO     - tahoma_local.py    - Tahoma authentication succeeded, login valid until 2025-03-07 18:40:43
2025-03-01 18:41:03,190 - ERROR    - plugin.py          - Failed to request data: HTTPSConnectionPool(host='2090-0842-4872.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fa413b9a0>: Failed to establish a new connection: [Errno 111] Connection refused'))
Thanks in advance
EDIT:
I restarted the Tahoma Switch and now I can see this in my logs
2025-03-01 19:02:59,429 - INFO     - plugin.py          - starting plugin version 4.2.16
2025-03-01 19:02:59,431 - INFO     - plugin.py          - Starting version: 4.2.16
2025-03-01 19:02:59,658 - INFO     - tahoma_local.py    - Tahoma authentication succeeded, login valid until 2025-03-07 19:02:59
2025-03-01 19:03:00,281 - INFO     - plugin.py          - New device created: Salle de bain
The blind does appear in the "devices" tab (Dispositifs in french)
Once I added the blind to the user's allowed devices, my blinds does appear in the Switches tab
Everything seems to works !
Eric
Posted: Monday 03 March 2025 10:45
by gizmocuz
Next to using a RFXCom 433 transceiver, I also can control them with this great project:
Not sure why you would buy a Tahoma switch for ~ 199€ when you can also use a RFXCom device for half of this, or build your own with ESP for ~10$
Glad it's working for you!
Posted: Monday 03 March 2025 12:29
by Schim57300
Hello Gizmocuz,
Thanks for this answer, I'm still using my RFXTrx433E in order to control my Somfy RTS blinds.
Two of them were broken and I had to change their engines for two IOs
As the two new blinds are now IO, I had to find a new way to control them.
I tried the "Connectivity Kit" (~70€) but it did not work since it has no developper mode (it's not possible to use any API)
That's why I got my money back and I bought the Tahoma (~170€)
[EDIT] I just changed my signature :lol:
Eric
Posted: Tuesday 29 April 2025 21:47
by TheoL
I just installed the plugin and after some figgling I was able to setup. However my shutters don't appear in the devices tab. I see this in the logs
2025-04-29 21:43:50.248 Somfy local: Worker thread started.
2025-04-29 21:43:50.248 Status: Somfy local: Started.
2025-04-29 21:43:50.476 Status: Somfy local: Initialized version 2.0.2, author 'nonolk'
2025-04-29 21:43:50.478 Status: Somfy local: Starting Tahoma blind plugin
2025-04-29 21:43:50.478 Somfy local: Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2025-04-29 21:43:50.478 Somfy local: Pushing 'ProtocolDirective' on to queue
2025-04-29 21:43:50.478 Somfy local: Pushing 'ConnectDirective' on to queue
2025-04-29 21:43:50.478 Somfy local: Acquiring GIL for 'onStartCallback'
2025-04-29 21:43:50.478 Somfy local: Processing 'ProtocolDirective' message
2025-04-29 21:43:50.478 Somfy local: Acquiring GIL for 'ProtocolDirective'
Did I miss something?
After 2 minutes I see this in the logging:
2025-04-29 21:57:15.709 Somfy local: Failed to connect to tahoma api
I did add the ip in the host, even rebooted the Pi and I got the pin from the Somfy site. Any help in where to start from here?
Posted: Tuesday 29 April 2025 21:52
by madpatrick
This is an very old plugin.
You can use the new updated version
