Page 8 of 9
Re: SolarEdge in Latest Beta / Port Number
Posted: Tuesday 22 March 2016 13:01
by prein
Can someone provide me the V2 version of the Solaredge Configuration tool? (Please PM)
Posted: Wednesday 13 April 2016 11:42
by prein
I am using the SolarEdge API for a few months, works perfectly. But I still want to use the SolarEdge via LAN feature. updating every 5 mins sounds great!
I changed the forwarding adress from my inverter and added the hardware, but it doesn't work. Is there anything I can do to debug? Nothing happens, no devices show up when I add the hardware. Solaredge site doesn't get updated, so it seems that the hardware step in domoticz goes wrong.
I am using the newest version 3.4834
Posted: Wednesday 13 April 2016 12:25
by antwan
After an update from Solaredge, the LAN-interface no longer works (at my side).
The only option what is left is to reverse engineer the USB data. The date is updated +/- 2 times a second, but that is a lot of work/time, and there is little available.
Posted: Monday 07 November 2016 15:44
by pirpy
Hello
Does the solaredge via web api works for 3 phase solaredge inverters?
I have the correct site id,site API and serial of an inverter (solaredge 15k)
but this message apear's in the log
2016-11-07 14:33:12.192 Error: SolarEdgeAPI: Invalid data received!
2016-11-07 14:38:12.713 Error: SolarEdgeAPI: Invalid data received!
Thank you
Posted: Monday 07 November 2016 16:47
by Yobby
Just tested it with my 3 phase 5k inverter, it still works.
I'm using the latest beta though.
Posted: Tuesday 15 November 2016 12:32
by bbqkees
Here for some reason it worked for many months but it stopped working 3 weeks ago.
Posted: Tuesday 15 November 2016 13:40
by bbqkees
I did some testing, some of the API calls work like
https://monitoringapi.solaredge.com/sit ... ey=API_KEY, but the one used in
https://github.com/domoticz/domoticz/bl ... dgeAPI.cpp on line 184 gives an Error 400:"The request sent by the client was syntactically incorrect ()."
If I check the API documentation nothing has changed since August.
Posted: Sunday 12 February 2017 22:27
by GSV3Miac
Thanks for the hint about the sun .. I KNEW the worker didn't query the server when it was dark, but failed to add 2+2. 8>.
Just a suggestion - whoever owns the worker code might like to query the server anyway (to generate the new devices) whether it is dark or not when you first add the hardware?
Posted: Friday 14 April 2017 11:46
by devilkin
Can anyone explain what the devices actually are? Especially the one that's supposed to be the kWh meter, it shows both energy usage and power usage, and I'm wondering what this is supposed to be related to.
EDIT: nevermind, I just noticed that you can put the device both in 'Usage' and 'Return' type. Changed it to Return and it makes more sense
Posted: Friday 28 July 2017 21:28
by MasterCATZ
pretty excited about this
we have an 5000 and no admin access and installer was an fly-by-night so no API , and solar edge still refusing to grant us ownership *sigh* 7 years now ..
would be great if i could get the data directly from the LAN interface
how ever doing port scans i can not even find its open port and i know solaredge did a remote update a few months ago
since then my router has not even seen it but I can still ping it
Posted: Thursday 31 August 2017 17:14
by thecosmicgate
Running the latest domo beta (#3.8356), and just 3 days ago the solar edge stuff (SE3500) and panels installed i'd like to monitor this using domo.
The config tab is changed to :
And when i configure it ( the way i think it's okay) first of all domo stops immediately, sow when i restart the service i'll had to disable the SolarEdge config and everythin is running fine ;(
Is there something wrong in this beta build maybe ?
and why is the SE config different as discribed in this topic
Posted: Thursday 07 September 2017 16:57
by thecosmicgate
Nobody
Posted: Thursday 07 September 2017 17:01
by antwan
Remove the adress and port.
Posted: Thursday 07 September 2017 20:34
by thecosmicgate
antwan wrote:Remove the adress and port.
Even when I did this, domoticz crashes directly ;(
Sent from my SM-G935F using Tapatalk
Posted: Sunday 10 September 2017 22:00
by thecosmicgate
Updated to the latest beta : 3.7550 , but still there something wrong ( I think) .
You can fill : remote adres and port, and fill : user name and password
Posted: Wednesday 13 September 2017 9:39
by thecosmicgate
Tried all the options, but one way of the other Domo crashes instantly when the "update" button pressed.
When I disable this plug-in Domo runs fine / stable.
Something wrong with this ?
Posted: Thursday 14 September 2017 19:16
by thecosmicgate
again updated to the latest beta version : 3.8356 , but when i enable the SolarEdge add-on / plug-in , domoticz instantly crashes ;(
HELP
Posted: Monday 18 September 2017 21:47
by huub66
Same problem here, is anyone looking at this issue?
Posted: Tuesday 19 September 2017 15:09
by huub66
I just resolved this; by leaving all fields empty except the API key and updating the hardware device, the problem is solved. Still strange values from other hardware devices appear in the fields which are not used (like remote address, port, user, pass) but apparently this are not saved. Still needs some work to restore this though. Anything I can do to help (without programming
) let me know.
Posted: Monday 02 October 2017 20:13
by thecosmicgate
huub66 wrote:I just resolved this; by leaving all fields empty except the API key and updating the hardware device, the problem is solved. Still strange values from other hardware devices appear in the fields which are not used (like remote address, port, user, pass) but apparently this are not saved. Still needs some work to restore this though. Anything I can do to help (without programming
) let me know.
I exactly did this, but domoticz crashes instantly when a enable the solaredge via web api ;(
