Python plugin: Sony Bravia TV
schulpr
Re: Python plugin: Sony Bravia TV
I have the same issue. A restart kills the buienradar plugin.
Verzonden vanaf mijn iPad met Tapatalk
- G3rard
- Target OS: -
- Domoticz version: No
Good you have found this. But where you using dzVents with some active scripts? Because on my Pi3 dzVents is not disabled, but also not in use and I don't have errors when restarting Domoticz.markcame wrote: Friday 11 August 2017 15:18 Finally i find the root cause because also the buienradar plugin does not survive @ domoticz restart.
I have disabled dzVents from domoticz setting and now all is up running and survive to reboot/restart, i don't know why it happens.
Not using Domoticz anymore
schulpr
I use dzVents scripts and the domoticz-buienradar plugin.
markcame
I use dzVents 1.1.2 with some scripts but on the embedded version in domoticz 2.2.0 i have no scripts running but if enable it and you use also plugins on restart crash for segmentation fault.
simon_rb
- Target OS: -
G3rard,
Great plugin and been working great when watching normal TV. I export the volume switch to Homebridge so I can say "Hey Siri, set the Living Room TV to 30% and it does it. Then I'd like to turn the tv on and off using the same switch rather than mute. Don't mind changing the code within the plugin.py as I am probably then only one who would want to do this.
I have changed the code to turn the tv off however the on won't work as it never sends the On command as the TV is off. How do I go about changing that.. So far this is what I have done (Android TV)
Thanks in advance
if Unit == 2: # TV volume
if action == 'Set':
self.tvVolume = str(Level)
_tv.set_volume_level(self.tvVolume)
elif action == "Off":
_tv.turn_off()
UpdateDevice(2, 0, str(self.tvVolume))
elif action == "On":
_tv.turn_on_command()
UpdateDevice(2, 1, str(self.tvVolume))
- G3rard
- Target OS: -
@simon_rb, the code checks if the TV is off and in that case only respons to unit 1 which is the TV power switch.
So your on command for unit 2 is never found.
If you add the following code after 'if self.powerOn == False:' and before 'else:' in the onCommand function then it should work.
And I would change the code from your post to:
if Unit == 2: # Use TV volume for switching on
if action == "On":
self.tvPlaying = "TV starting" # Show that the TV is starting, as booting the TV takes some time
self.SyncDevices()
if Unit == 2: # TV volume and switching off
if action == 'Set':
_tv.turn_off()
self.tvPlaying = "Off"
self.SyncDevices()
simon_rb
- Target OS: -
Thats amazing, thanks!G3rard wrote: Tuesday 15 August 2017 23:57 @simon_rb, the code checks if the TV is off and in that case only respons to unit 1 which is the TV power switch.
If you add the following code after 'if self.powerOn == False:' and before 'else:' in the onCommand function then it should work.And I would change the code from your post to:Code: Select all
if Unit == 2: # Use TV volume for switching on if action == "On": _tv.turn_on_command() self.tvPlaying = "TV starting" # Show that the TV is starting, as booting the TV takes some time self.SyncDevices()Code: Select all
if Unit == 2: # TV volume and switching off if action == 'Set': self.tvVolume = str(Level) _tv.set_volume_level(self.tvVolume) elif action == "Off": _tv.turn_off() self.tvPlaying = "Off" self.SyncDevices()
I added the code above and I am getting various different errors and plugin won't load. It is 99.9% I am putting them in wrong. Being cheeky could I ask for a plugin.py file with the changes in? If not I shall continue to try and figure out where I have gone wrong!
- G3rard
- Target OS: -
No problem, will have a look at it.
Your errors are probably caused by using tabs as indents? Or were there other errors in the log?
simon_rb
- Target OS: -
I pasted the above in. Most probably the indents. It was error on line errors.G3rard wrote: Wednesday 16 August 2017 19:49 No problem, will have a look at it.
simon_rb
- Target OS: -
I have this working now, if anyone wants the amended .py file I'll post it here
Thanks for your help G3rard
farhanito
hi,
has crashing issues on RPi resolved yet?
simon_rb
- Target OS: -
Mine hasn't crashed at all since using it. There was an issue with one of the example .py's in the example folder under plugins (think it's the PIR one). I deleted that anyways and it's been fine and not experienced a single crash. I'm on a raspberry pi 3 which is running Domoticz, an Open VPN, Logitech Media Server, SQL library for all the kodi's around the house, FTP server for IP Camera motion detection in domoticz, homebridge including nest for the thermostat. There are loads more I have the Rapsberry pi doing and not a single crash
- G3rard
- Target OS: -
It's the file script_device_PIRsmarter.py in the scripts/python folder. That file is causing crashes. So if't is in your folder you can delete it.simon_rb wrote: Saturday 19 August 2017 21:20Mine hasn't crashed at all since using it. There was an issue with one of the example .py's in the example folder under plugins (think it's the PIR one). I deleted that anyways and it's been fine and not experienced a single crash. I'm on a raspberry pi 3 which is running Domoticz, an Open VPN, Logitech Media Server, SQL library for all the kodi's around the house, FTP server for IP Camera motion detection in domoticz, homebridge including nest for the thermostat. There are loads more I have the Rapsberry pi doing and not a single crash![]()
In the latest beta version this file is removed by the system, check this https://github.com/domoticz/domoticz/co ... 3681f73ab3 for more information.
For me also no crashed on my Pi3 after I have removed that file.
- lmet
- Domoticz version: v4.9700
For me no crash since removing "script_device_PIRsmarter.py" but many many errors in log :
2017-08-20 19:02:17.231 Error: (Bravia) No data received from TV, probably it has just been turned off (time data '' does not match format '%Y-Success-0T%H:%M:- G3rard
- Target OS: -
Can you install the latest version from Github and try that?lmet wrote: Monday 21 August 2017 1:54 Hi,
For me no crash since removing "script_device_PIRsmarter.py" but many many errors in log :Code: Select all
If it still gives errors please set Debug to True and send me the log output so I can have a look.
simon_rb
- Target OS: -
G3rard, buy yourself a new Sony TV (Android one).You deserve it
- G3rard
- Target OS: -
@simon_rb, will tell it to the wife
But I am quite happy with my non-Android TV combined with a nVidia Shield
hekm77
v1.2 works fine with KDL-60W605B
Thanks.
Thanks.
Could not find Hardware Type "Sony Bravia TV" on last beta V3.8367
- G3rard
- Target OS: -
The Python plugins are disabled in the latest Domoticz beta versions.
Use the stable version if you want to have Python plugins working.
