[RELEASED] Python plugin to control Onkyo receivers
- jorgh
- Domoticz version: 3.8224
Re: [RELEASED] Python plugin to control Onkyo receivers
@Xavier82,
From the information at https://github.com/miracle2k/onkyo-eiscp I conclude that NRI support started for receivers produced in 2013. So that would be the TX-NR-x2x and newer.
Regards,
Jorg
Regards,
Jorg
- Domoticz version: 3.7243
Hello
Onkyo HT-S9700THX goes controlled with this plugin?
- Domoticz version: 2023.2
@Jorgh,
So I will now wait on your version to support devices without NRI
Any idea about a planning of this feature?
Regards,
Xavier
Regards,
Xavier
- jorgh
As this is a recent receiver, I would expect it to work.andi216 wrote:Hello
Regards,
Jorg
@Jorgh, do you have an open ticket somewhere to fix the problem with your plugin crashing with a normal installation (no self compile)?
I am a bit hesitant to compile myself, since I have absolutely no experience with it.
- mongoose
Thank you for all the hard work! One thing I would like to see is zone 3 support if at all possible. I have an NR 929 where I have Main for the lounge, zone 2 kitchen and zone 3 for outside.
- jorgh
@Jake,
Regards,
Jorg
I don't have a ticket for my plugin, it is a generic issue. @elgringo is able to reproduce the crash on a compiled version with debug target. So this is the most promising forum topic for now: viewtopic.php?f=6&t=17905#p137813jake wrote:@Jorgh, do you have an open ticket somewhere to fix the problem with your plugin crashing with a normal installation (no self compile)?
Regards,
Jorg
- jorgh
@mongoose,
Regards,
Jorg
The protocol has support for 4 zones. I'll add them to a version in the development branch in the near future. However, I am not able to test beyond zone 2, as my receiver only supports 2 zones. I keep you posted.mongoose wrote:Thank you for all the hard work! One thing I would like to see is zone 3 support if at all possible. I have an NR 929 where I have Main for the lounge, zone 2 kitchen and zone 3 for outside.
Regards,
Jorg
I am moving domoticz to another machine (Windows 10) and installed your plugin again, now i'm getting this:
2017-08-01 21:34:31.306 (Receiver) Calling message handler 'onHeartbeat'.
2017-08-01 21:34:31.306 (Receiver) onHeartbeat called
2017-08-01 21:34:31.306 (Receiver) Loading XML from file
2017-08-01 21:34:31.306 (Receiver) XML file does not yet exist
2017-08-01 21:34:31.306 (Receiver) Sending 4 bytes of data:.
2017-08-01 21:34:31.306 (Receiver) 49 53 43 50 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ISCP
The devices/switches are not created.
This is on a Windows 10 operating system.
I tried it on a Windows 7 machine and it creates the switches in a few seconds and do not get the above messages.
I do see this message on both operating systems:
2017-08-01 21:33:24.018 Error: (test1) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
- jorgh
@JimmyH1969,
That is due to a bug in the latest Domoticz version. See https://www.domoticz.com/forum/viewtopi ... 65&t=18588
Furthermore the latest domoticz version has changes to the framework that need an updated plugin, also discussed in that topic. I've already updated the code, but am not able to test yet.
The bug will be resolved soon, after which I will publish a new version of the plugin.
Regards,
Jorg
Regards,
Jorg
- mongoose
@Jorg thank you for that, yes I see zone 2, so that additio n for zone 3 will be great for when we hit summer again
- jorgh
@JimmyH1969, the bug introduced in the latest python framework change has been resolved in Domoticz version 3.8224. So If you update to this version, the Onkyo plugin on the development branch https://github.com/jorgh6/domoticz-onky ... evelopment should work.
@mongoose, the new version in the development branch now has support for 4 zones. Can't test myself, so hope it works.
Regards,
Jorg
Regards,
Jorg
- mongoose
Thank you Zone 3 working just like zone 2 and main! all great thank you!
Hi Jorg,
Tnx for the update, but i still get this message:
2017-08-06 15:03:18.274 (Receiver Woonkamer) Started.
2017-08-06 15:03:18.321 (Receiver Woonkamer) Initialized version 0.2.2, author 'jorgh'
2017-08-06 15:03:18.321 (Receiver Woonkamer) Entering work loop.
2017-08-06 15:03:30.364 (Receiver Woonkamer) Receiver found:
2017-08-06 15:03:30.364 (Receiver Woonkamer) Type: AV Receiver or Stereo Receiver
2017-08-06 15:03:30.364 (Receiver Woonkamer) Type: TX-NR646
2017-08-06 15:03:30.364 (Receiver Woonkamer) Region: European or Asian model
2017-08-06 15:03:30.364 (Receiver Woonkamer) IP adress: 192.168.1.5
2017-08-06 15:03:30.364 (Receiver Woonkamer) eISCP port: 60128
2017-08-06 15:03:30.364 (Receiver Woonkamer) MAC: 0009B0DABEF0
2017-08-06 15:04:22.740 Error: (Receiver Woonkamer) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
No devices are being created...
This is on a windows 7 system. Something tell's me it is a problem on my machine, but i don't know what it is..
I see this message as wel: (Receiver Woonkamer) Requesting XML configuration
Does it want to create a file somewhere maybe?
- jorgh
You should update to the latest Domoticz version, beta that is.JimmyH1969 wrote:Hi Jorg,
Verstuurd vanaf mijn HTC 10 met Tapatalk
So, it's like this:
2017-08-06 15:18:05.460 (Receiver Woonkamer) Requesting XML configuration
2017-08-06 15:18:05.616 Error: (Receiver Woonkamer) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-08-06 15:18:07.520 (Receiver Woonkamer) Requesting XML configuration
2017-08-06 15:18:07.754 Error: (Receiver Woonkamer) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-08-06 15:18:09.657 (Receiver Woonkamer) Requesting XML configuration
2017-08-06 15:18:09.860 Error: (Receiver Woonkamer) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
I am running Domoticz 3.8235. That is the latest beta as far as i can see
- jorgh
Did you take the plugin from the Github development branch?
I did. It says it's version 0.2.2
Could it be a python for windows thing?
Users browsing this forum: Amazon [Bot] and 1 guest
