Page 8 of 32
Re: Domoboard a New Dashboard using Domoticz as backend
Posted: Wednesday 04 January 2017 17:03
by lukev
I'm a little step further on my diskstation. I fixed the python2.7 installation en installed all modules.
But when i try to execute the server.py script, I get an error:
root@DiskStation:/opt/bin/domoboard# python server.py -c example.conf
  File "server.py", line 3, in <module>
    from flask import Flask, g, redirect, url_for, render_template, abort, request, session
ImportError: No module named flask
It seems the system thinks there is no flask installed.
So I try to install flask, but then I get the message it is allready installed:
root@DiskStation:/opt/bin/domoboard# sudo easy_install flask
Searching for flask
Best match: Flask 0.12
Processing Flask-0.12-py2.7.egg
Flask 0.12 is already the active version in easy-install.pth
Installing flask script to /usr/bin
Using /usr/lib/python2.7/site-packages/Flask-0.12-py2.7.egg
Processing dependencies for flask
Finished processing dependencies for flask
Some ideas??
Posted: Wednesday 04 January 2017 18:41
by Lars65
I get this when I try to start :
[codeTraceback (most recent call last):
File "server.py", line 154, in <module>
api.checkDomoticzStatus(config)
File "/home/pi/domoboard/modules/api.py", line 127, in checkDomoticzStatus
for device in resultScene["result"]:
KeyError: 'result'
][/code]
Posted: Wednesday 04 January 2017 18:48
by squandor
lukev wrote:I'm a little step further on my diskstation. I fixed the python2.7 installation en installed all modules.
Searching for flask
Some ideas??
what version do you get when you type
python
by squandor
Lars65 wrote:I get this when I try to start :
KeyError: 'result'
][/code]
thats a bug in the api. It is fixed but only on the developer branch. the master branch will be updated soon.
Posted: Wednesday 04 January 2017 19:21
by Lars65
Seems like scandinavian letters is not alod either, when I use swedish å,ä,ö, I get an error.
Posted: Wednesday 04 January 2017 20:08
by wez3
KeyError: 'result'
][/code]
This bug is now also fixed in master.
Posted: Wednesday 04 January 2017 20:36
by felix63
To have Domoboard run in the background every time you start up I use PM2. Based on the info from https://www.domoticz.com/wiki/NefitEasy the way to get this up an running is:
Install pm2 to control the service
npm install pm2 -g
pm2 startup
Create start script
touch domoboard_server.sh
Use your standard edit to add lines:
#!/bin/bash
cd /home/pi/domoboard/
python server.py -c basic.conf >/dev/null
Where /home/pi/domoboard should be the directory where you've extracted domoboard and basic.conf should be the name of you configuration file. Save your file.
chmod 755 domoboard_server.sh
Start script
pm2 start /home/pi/domoboard_server.sh
pm2 save
Getting info
If you want to check use
pm2 list
to retrieve id and use
pm2 info {id}
to retrieve info about running process.
After updates to configuration
pm2 restart {id}
or
pm2 stop {id}
pm2 start {id}
Posted: Wednesday 04 January 2017 21:05
by pepijn
You can also use the generic systemd method.
Create a file /etc/systemd/system/domoboard.service
Don't forget to modify the location of the domoboard installation and config file to your needs.
[Unit]
Description=Domoboard Domotica Dashboard
[Service]
ExecStart=/usr/bin/python /opt/domoboard/server.py -d -c /etc/domoboard/config.conf
WorkingDirectory=/opt/domoboard
User=root
Group=root
Restart=on-failure
[Install]
WantedBy=multi-user.target
Enable on boot:
systemctl enable domoboard.service
Start:
systemctl start domoboard
Stop:
systemctl stop domoboard
Get the status:
systemctl status domoboard
To view the logs:
journalctl -f -u domoboard
Posted: Wednesday 04 January 2017 21:09
by fransiefrans
squandor wrote:
fransiefrans wrote:very nice dashboard!
I have Domoboard running and was trying to alter some idx and camera's but why can't I see what I've adjusted in de example.conf file?
I've restarted the server and still the old config opens.
Could it be you're cache? to make sure that domoboard uses you're config try to run it with
sudo python server.py -c configfile.conf
and for debugging purposes you could add the parameter -d
All of a sudden it works now with the adjusted config file.
How can I quickly try out the edited config file?
Posted: Wednesday 04 January 2017 21:25
by squandor
If you mean you're own adjustments of the config you can add the parameter -d to the command. It stands for debugging mode which means that it will restart the server if a file is changed
Posted: Wednesday 04 January 2017 22:28
by wez3
Searching for flask
Some ideas??
Could you try this, change in server.py the first line:
#!/usr/bin/env python
to
#!/usr/bin/python
Hope thats help, i've read something about it on the internet.
Posted: Wednesday 04 January 2017 22:29
by fransiefrans
squandor wrote:If you mean you're own adjustments of the config you can add the parameter -d to the command. It stands for debugging mode which means that it will restart the server if a file is changed
Posted: Thursday 05 January 2017 0:40
by wizzard72
This dashboard looks very very nice. I was waiting for something like this. So I started right away and experimented a lot.
Here are some screenshots.
I have a few suggestions:
  • The dimmer slides suggests that the lamps are on. There is no difference between dimmers that are on or off.
  • In the top bar it's possible to show the time. Also it would be nice to have the date and weekday, and the status of the security panel.
  • Can we have a security panel for disarming/ arming?
  • The bar charts shows the name the device has in Domoticz. Also the name is too long, perhaps we can put the text in an angle?
  • The list in top_tiles, bar_charts, etc. is not sorted exactly like the config file.
  • Can we configure more than 2 switches windows next to each other?
Posted: Thursday 05 January 2017 12:15
by tozzke
TheRedOne09 wrote:Just started using this Dashboard, looks very promosing!
I have one suggestion / change for the device-type: "dimmer" it uses a value between 0-100. I have a KaKu dimmer, which accepts values between 0-16. Of course i can change the value that is set, but I think its better to add a another device-type and call it KaKu-dimmer or something like that. In that case you can use regular dimmers and KaKu-dimmers at the same time!
I think they listened to you but overdone it :)
I've got Philips Hue @ Domoticz with LivingWhite plugs and bulbs and when I get >16% @ slider, they are at full brightness. :D
Another issue I noticed...
What's the use of the username and password you have to configure in the .conf file?
I've made a test.conf in which I entered the login/password from a user in Domoticz who can only see, not switch and yet... @ Domoboard you can still switch devices :/
Posted: Thursday 05 January 2017 13:47
by Hilary999
I would like to say that is an amazing board as a video animator at Whiteboard Animation Services – HelloAnimations, I also say that The venture was begun in light of the fact that the default Domoticz interface is not intended to be utilized as a real dashboard, for instance on a tablet which is mounted to the divider. Domoboard depends on Bootstrap which permits the dashboard to be responsive.
Posted: Thursday 05 January 2017 16:04
by Awst6000
I'm playing with the configuration of Domoboard and I wonder where is configured to call www.buienradar.nl when I add the following to the configurationfile:
[[display_components]]
components = buienradar
[[buienradar]]
Or formulated in another way. How can I add the following URLs?
http://cdn.knmi.nl/knmi/map/page/weer/a ... ratuur.png
http://cdn.knmi.nl/knmi/map/page/weer/a ... elheid.png
http://cdn.knmi.nl/knmi/map/page/weer/a ... /zicht.png
Txs
Posted: Thursday 05 January 2017 16:36
by wez3
Awst6000 wrote:Hi,
I'm playing with the configuration of Domoboard and I wonder where is configured to call http://www.buienradar.nl when I add the following to the configurationfile:
[[buienradar]]
Txs
The buienradar HTML is located at: "templates/buienradar.html".
Posted: Thursday 05 January 2017 20:53
by woody4165
I have an Energy monitor where I can get actual and daily consumption and a counter.
I I query with JSON the data I get is:
   "ActTime" : 1483645232,
   "ServerTime" : "2017-01-05 20:40:32",
   "Sunrise" : "07:39",
   "Sunset" : "16:52",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CounterToday" : "7.373 kWh",
         "CustomImage" : 0,
         "Data" : "426.882 kWh",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : xx,
         "HardwareName" : "xxx",
         "HardwareType" : "RFLink Gateway USB",
         "HardwareTypeVal" : xx,
         "HaveTimeout" : false,
         "ID" : "0000008E",
         "LastUpdate" : "2017-01-05 20:39:34",
         "Name" : "Owl",
         "Notifications" : "false",
         "Options" : "",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "kWh",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "current",
         "Unit" : 1,
         "Usage" : "418.0 Watt",
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "xxx"
   "status" : "OK",
   "title" : "Devices"
If I use in [power_usage] I get the value in Data, which is the overall value.
Is there any possibility to get the Usage and CounterToday fileds?
Another question is regarding the line_charts. I would like to use it with more than one temp value.
Is it possible to have more than one temp charts, not in the same charts, but in different ones.
I have a [[switches]] components in the dashboard, but in the web page section title I see the word "Schakelaars" even if I don't have this word in the conf file. Probably it's a small bug.
Posted: Thursday 05 January 2017 21:22
by Awst6000
wez3 wrote: The buienradar HTML is located at: "templates/buienradar.html".
Hi Wez3,
What is wise for me to do?
Create my own template with the 6 different 'Knmi actueel' pages or shall I wait until someone is so kind to create this template within Domoboard?
Other questions:
- Is it possible to get livestreams from my own cams or do I get a snapshot? (Elro C903IP and D-Link 932L cams)
- How can I implement traffic cams like these: http://webcam.mapgear.nl/deventer_hdunantlaan/
- Is it possible to add '112-meldingen'?
Txs.
Posted: Thursday 05 January 2017 23:07
by pepijn
Awst6000 wrote: What is wise for me to do?
Feel free to build the template and share your work :D
