Re: Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
Posted: Monday 13 March 2017 13:57
You could search information about your plants and set limits when to notify user?
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
physiker123 wrote:Just a quick idea: apparently I do not get any sensor values.
Is this a raspberry pi error or an error with Bluetooth?
Do I have to install the app to initiate the sensors? Above was written, that the sensors would work without the app..
Best regards
physiker123 wrote:Hello,
I have problems including my flower sensor into domoticz.
I followed the wiki article (with no result of this part, because it did not find the folder:
I found my flower sensor, and tried the demo.py, with the following result:If all goes well, one last thing is to copy the Gatt tool to the directory where your linux version keeps its programs. It's location is different for different Linux flavours. Try:
sudo cp attrib/gatttool /usr/local/bin/ or sudo cp attrib/gatttool /usr/bin/
Does anybody have a clue?Code: Select all
Traceback (most recent call last): File "demo.py", line 6, in <module> print("Temperature: {}°C".format(poller.parameter_value("temperature"))) File "/home/pi/domoticz/scripts/miflora/miflora/miflora_poller.py", line 256, in parameter_value self._mac) OSError: [Errno Could not read data from Mi Flora sensor %s] C4:7C:8D:62:7C:CE
Thank you in advance and thanks for the work!
pi@raspberrypi ~/miflora $ sudo python3 demo.py
File "demo.py", line 4, in <module>
from miflora.miflora_poller import MiFloraPoller, \
File "/home/pi/miflora/miflora/miflora_poller.py", line 12, in <module>
from subprocess import PIPE, Popen, TimeoutExpired
ImportError: cannot import name TimeoutExpired
Have you compiled everything according to the wiki?Gargy wrote:Hi!
So my MiFloras are working flawlesly on my RPi3. So today I wanted to move the sensor polling on my RPi2, where is also Domoticz. I instlled the BlueZ and I can find the sensor with BT LE scan, but when I tried to run the demo script, I got this:
I tried everything, followed several tutorialsa and installed all mentioned dependencies etc.Code: Select all
pi@raspberrypi ~/miflora $ sudo python3 demo.py Traceback (most recent call last): File "demo.py", line 4, in <module> from miflora.miflora_poller import MiFloraPoller, \ File "/home/pi/miflora/miflora/miflora_poller.py", line 12, in <module> from subprocess import PIPE, Popen, TimeoutExpired ImportError: cannot import name TimeoutExpired
Still can't figure out what is going on...
Any idea?
For me, it looks like you havent copied miflora folder to home/pi/domoticz/scripts ? I dont know does it make any difference, but in wiki it says to copy so ..LouiS22 wrote:Have you compiled everything according to the wiki?Gargy wrote:Hi!
Any idea?
Attleast if you gonna use them with android app, latest update makes them unusable outside china ... They still will work with domoticz tho.Africagrower wrote:Dears,
We are working at an project in Africa, to use the Xiaomi Mi Flora sensors, to save water and to have the optimal production.
To keep at as Simple As Possible (KISS), we like to use an Android tablet or an small laptop.
Goal is to have the data on those, and to store the historical data.
Who like to help us?
By myself, based in the Netherlands, and visit every two months Zambia, and regular Tanzania/Ethiopia etc.
Ewout Schurink
# m h dom mon dow command
* * * * * /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py
(root) CMD (/usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py)
Mar 14 21:51:01 raspberrypi CRON[9583]: (CRON) info (No MTA installed, discarding output)Code: Select all
MAILTO=""Code: Select all
Mar 14 22:08:01 raspberrypi CRON[11346]: (root) CMD (/usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py)
*/1 * * * * /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.pyThank you for your answer, but it still does not work.tontze wrote:Try:
env -i /bin/bash --noprofile --norcCode: Select all
1: Test
Mi Flora: C4:7C:8D:63:18:14
Firmware: 2.7.0
File "domoticz.py", line 97, in <module>
update("C4:7C:8D:63:18:14","3","1","2","4")
File "domoticz.py", line 69, in update
print("Temperature: {}\xb0C".format(poller.parameter_value("temperature")))
UnicodeEncodeError: 'ascii' codec can't encode character '\xb0' in position 17: ordinal not in range(128)krizzz wrote:Same type of problems here. Got everything installed and I see the Miflora when using the HCItool for scanning.
But when running the domesticz.py script, I have the following errors:
Somebody knows what this means?Code: Select all
1: Test Mi Flora: C4:7C:8D:63:18:14 Firmware: 2.7.0 Name: Flower care Traceback (most recent call last): File "domoticz.py", line 97, in <module> update("C4:7C:8D:63:18:14","3","1","2","4") File "domoticz.py", line 69, in update print("Temperature: {}\xb0C".format(poller.parameter_value("temperature"))) UnicodeEncodeError: 'ascii' codec can't encode character '\xb0' in position 17: ordinal not in range(128)
Thanks! I will give that a try. And try figure out why the crontab wont work...physiker123 wrote:Yes. That means, that there is an Ascii incompatible character. I deleted the °C and so on from the print section in the script, and then at least the script runs. But still, crontab does not work for me.
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
MAILTO=""
*/1 * * * * /usr/bin/python3 /home/pi/domoticz/scripts/miflora/domoticz.pyNice, it runs every minute, i thought u asked for it to run every minutephysiker123 wrote:I solved my problem. Your answer, @tontze , now works, but the path was wrong, there was a /python/ to much. So here is my crontab configuration working on my raspberry pi 3:
This runs the script every minute, you may want to change that.Code: Select all
# Edit this file to introduce tasks to be run by cron. # # Each task to run has to be defined through a single line # indicating with different fields when the task will be run # and what command to run for the task # # To define the time you can provide concrete values for # minute (m), hour (h), day of month (dom), month (mon), # and day of week (dow) or use '*' in these fields (for 'any').# # Notice that tasks will be started based on the cron's system # daemon's notion of time and timezones. # # Output of the crontab jobs (including errors) is sent through # email to the user the crontab file belongs to (unless redirected). # # For example, you can run a backup of all your user accounts # at 5 a.m every week with: # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/ # # For more information see the manual pages of crontab(5) and cron(8) # # m h dom mon dow command MAILTO="" */1 * * * * /usr/bin/python3 /home/pi/domoticz/scripts/miflora/domoticz.py
Great
tontze wrote:Nice, it runs every minute, i thought u asked for it to run every minutephysiker123 wrote:I solved my problem. Your answer, @tontze , now works, but the path was wrong, there was a /python/ to much. So here is my crontab configuration working on my raspberry pi 3:
Greatjust change */1 to */10 and it runs every 10minute
physiker123 wrote:Yes I asked to run it every minute, but your path to my script included a /python/, which was to much and prevended it from working
Now I changed it to run every 6 hours, that should be enough.
so this is my new script:
Thanks anywayCode: Select all
# Edit this file to introduce tasks to be run by cron. # # Each task to run has to be defined through a single line # indicating with different fields when the task will be run # and what command to run for the task # # To define the time you can provide concrete values for # minute (m), hour (h), day of month (dom), month (mon), # and day of week (dow) or use '*' in these fields (for 'any').# # Notice that tasks will be started based on the cron's system # daemon's notion of time and timezones. # # Output of the crontab jobs (including errors) is sent through # email to the user the crontab file belongs to (unless redirected). # # For example, you can run a backup of all your user accounts # at 5 a.m every week with: # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/ # # For more information see the manual pages of crontab(5) and cron(8) # # m h dom mon dow command MAILTO="" 0 0,6,12,18 * * * /usr/bin/python3 /home/pi/domoticz/scripts/miflora/domoticz.py
And then add this line:
0 0,12 * * * python3 /pi/domoticz/scripts/python/miflora/domoticz.py
