Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
- Domoticz version: Beta Ch
Re: Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
You could search information about your plants and set limits when to notify user?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
now it works. I just had to wait.
Thank you for the great script!
physiker123 wrote:Just a quick idea: apparently I do not get any sensor values.
Is this a raspberry pi error or an error with Bluetooth?
Do I have to install the app to initiate the sensors? Above was written, that the sensors would work without the app..
Best regards
physiker123 wrote:Hello,
I have problems including my flower sensor into domoticz.
I followed the wiki article (with no result of this part, because it did not find the folder:
I found my flower sensor, and tried the demo.py, with the following result:If all goes well, one last thing is to copy the Gatt tool to the directory where your linux version keeps its programs. It's location is different for different Linux flavours. Try:
sudo cp attrib/gatttool /usr/local/bin/ or sudo cp attrib/gatttool /usr/bin/
Does anybody have a clue?Code: Select all
Traceback (most recent call last): File "demo.py", line 6, in <module> print("Temperature: {}°C".format(poller.parameter_value("temperature"))) File "/home/pi/domoticz/scripts/miflora/miflora/miflora_poller.py", line 256, in parameter_value self._mac) OSError: [Errno Could not read data from Mi Flora sensor %s] C4:7C:8D:62:7C:CE
Thank you in advance and thanks for the work!
Hi!
So my MiFloras are working flawlesly on my RPi3. So today I wanted to move the sensor polling on my RPi2, where is also Domoticz. I instlled the BlueZ and I can find the sensor with BT LE scan, but when I tried to run the demo script, I got this:
I tried everything, followed several tutorialsa and installed all mentioned dependencies etc.
Still can't figure out what is going on...
Any idea?
pi@raspberrypi ~/miflora $ sudo python3 demo.py
File "demo.py", line 4, in <module>
from miflora.miflora_poller import MiFloraPoller, \
File "/home/pi/miflora/miflora/miflora_poller.py", line 12, in <module>
from subprocess import PIPE, Popen, TimeoutExpired
ImportError: cannot import name TimeoutExpired
Any idea?
Dears,
We are working at an project in Africa, to use the Xiaomi Mi Flora sensors, to save water and to have the optimal production.
To keep at as Simple As Possible (KISS), we like to use an Android tablet or an small laptop.
Goal is to have the data on those, and to store the historical data.
Who like to help us?
By myself, based in the Netherlands, and visit every two months Zambia, and regular Tanzania/Ethiopia etc.
Ewout Schurink
Ewout Schurink
MiFlora has built-in logger and logs (I think) every 5 minutes. So when you check your plants with Android device and original Xiaomi software, the history is downloaded to the device.
The second option is of course Domoticz, where you can set the sensor polling time. I keep my polling rate at 15 minutes and didn't noticed any fall in battery level.
If you need only soil moisture, perhaps you could look on AliExpress - they got some dirty cheap soil sensors with WiFi or even cheaper if you go with wired device(s)...
- LouiS22
Have you compiled everything according to the wiki?Gargy wrote:Hi!
I tried everything, followed several tutorialsa and installed all mentioned dependencies etc.Code: Select all
pi@raspberrypi ~/miflora $ sudo python3 demo.py Traceback (most recent call last): File "demo.py", line 4, in <module> from miflora.miflora_poller import MiFloraPoller, \ File "/home/pi/miflora/miflora/miflora_poller.py", line 12, in <module> from subprocess import PIPE, Popen, TimeoutExpired ImportError: cannot import name TimeoutExpired
Any idea?
For me, it looks like you havent copied miflora folder to home/pi/domoticz/scripts ? I dont know does it make any difference, but in wiki it says to copy so ..LouiS22 wrote:Have you compiled everything according to the wiki?Gargy wrote:Hi!
Any idea?
Also, im executing domoticz.py, dont know what that demo.py is for ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Attleast if you gonna use them with android app, latest update makes them unusable outside china ... They still will work with domoticz tho.Africagrower wrote:Dears,
Ewout Schurink
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Hello again
Does anybody know, why cron is not working in my case? I followed the wiki and also this troubleshooting ( http://garyhall.org.uk/troubleshooting- ... ry-pi.html ), cron is up and running, and my sudo crontab -e looks like this:
I made it execute every minute to have a better look. Any ideas?
Thank you!
edit: I looked in the syslog, there it says
So i added before the task, as suggested here:
http://askubuntu.com/questions/222512/c ... the-syslog
Now there are no more errors in syslog, but it still does not run the script... The syslog says:
but the values are not updated in domoticz. If I run the script manually, it works..
# m h dom mon dow command
* * * * * /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py
Thank you!
(root) CMD (/usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py)
Mar 14 21:51:01 raspberrypi CRON[9583]: (CRON) info (No MTA installed, discarding output)
MAILTO=""
Mar 14 22:08:01 raspberrypi CRON[11346]: (root) CMD (/usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py)
Try:
*/1 * * * * /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Thank you for your answer, but it still does not work.tontze wrote:Try:
I also tried the command under the cron environment
env -i /bin/bash --noprofile --norc
I also edited the crontab as sudo crontab -e
Same type of problems here. Got everything installed and I see the Miflora when using the HCItool for scanning.
But when running the domesticz.py script, I have the following errors:
Somebody knows what this means?
1: Test
Mi Flora: C4:7C:8D:63:18:14
Firmware: 2.7.0
File "domoticz.py", line 97, in <module>
update("C4:7C:8D:63:18:14","3","1","2","4")
File "domoticz.py", line 69, in update
print("Temperature: {}\xb0C".format(poller.parameter_value("temperature")))
UnicodeEncodeError: 'ascii' codec can't encode character '\xb0' in position 17: ordinal not in range(128)
Yes. That means, that there is an Ascii incompatible character. I deleted the °C and so on from the print section in the script, and then at least the script runs. But still, crontab does not work for me.
krizzz wrote:Same type of problems here. Got everything installed and I see the Miflora when using the HCItool for scanning.
Somebody knows what this means?Code: Select all
1: Test Mi Flora: C4:7C:8D:63:18:14 Firmware: 2.7.0 Name: Flower care Traceback (most recent call last): File "domoticz.py", line 97, in <module> update("C4:7C:8D:63:18:14","3","1","2","4") File "domoticz.py", line 69, in update print("Temperature: {}\xb0C".format(poller.parameter_value("temperature"))) UnicodeEncodeError: 'ascii' codec can't encode character '\xb0' in position 17: ordinal not in range(128)
Thanks! I will give that a try. And try figure out why the crontab wont work...physiker123 wrote:Yes. That means, that there is an Ascii incompatible character. I deleted the °C and so on from the print section in the script, and then at least the script runs. But still, crontab does not work for me.
I solved my problem. Your answer, @tontze , now works, but the path was wrong, there was a /python/ to much. So here is my crontab configuration working on my raspberry pi 3:
This runs the script every minute, you may want to change that.
Great
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
MAILTO=""
*/1 * * * * /usr/bin/python3 /home/pi/domoticz/scripts/miflora/domoticz.py
Great
Nice, it runs every minute, i thought u asked for it to run every minutephysiker123 wrote:I solved my problem. Your answer, @tontze , now works, but the path was wrong, there was a /python/ to much. So here is my crontab configuration working on my raspberry pi 3:
This runs the script every minute, you may want to change that.Code: Select all
# Edit this file to introduce tasks to be run by cron. # # Each task to run has to be defined through a single line # indicating with different fields when the task will be run # and what command to run for the task # # To define the time you can provide concrete values for # minute (m), hour (h), day of month (dom), month (mon), # and day of week (dow) or use '*' in these fields (for 'any').# # Notice that tasks will be started based on the cron's system # daemon's notion of time and timezones. # # Output of the crontab jobs (including errors) is sent through # email to the user the crontab file belongs to (unless redirected). # # For example, you can run a backup of all your user accounts # at 5 a.m every week with: # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/ # # For more information see the manual pages of crontab(5) and cron(8) # # m h dom mon dow command MAILTO="" */1 * * * * /usr/bin/python3 /home/pi/domoticz/scripts/miflora/domoticz.py
Great
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Yes I asked to run it every minute, but your path to my script included a /python/, which was to much and prevended it from working
Now I changed it to run every 6 hours, that should be enough.
Thanks anyway
Thanks anyway
tontze wrote:Nice, it runs every minute, i thought u asked for it to run every minutephysiker123 wrote:I solved my problem. Your answer, @tontze , now works, but the path was wrong, there was a /python/ to much. So here is my crontab configuration working on my raspberry pi 3:
Greatjust change */1 to */10 and it runs every 10minute
physiker123 wrote:Yes I asked to run it every minute, but your path to my script included a /python/, which was to much and prevended it from working
so this is my new script:
Thanks anywayCode: Select all
# Edit this file to introduce tasks to be run by cron. # # Each task to run has to be defined through a single line # indicating with different fields when the task will be run # and what command to run for the task # # To define the time you can provide concrete values for # minute (m), hour (h), day of month (dom), month (mon), # and day of week (dow) or use '*' in these fields (for 'any').# # Notice that tasks will be started based on the cron's system # daemon's notion of time and timezones. # # Output of the crontab jobs (including errors) is sent through # email to the user the crontab file belongs to (unless redirected). # # For example, you can run a backup of all your user accounts # at 5 a.m every week with: # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/ # # For more information see the manual pages of crontab(5) and cron(8) # # m h dom mon dow command MAILTO="" 0 0,6,12,18 * * * /usr/bin/python3 /home/pi/domoticz/scripts/miflora/domoticz.py
Actually, wiki´s crontab part doesnt correspond to instructions earlier. I had same mistake as user before ..
an extra /python/ in the path, and missing /home from the path start
-T
And then add this line:
0 0,12 * * * python3 /pi/domoticz/scripts/python/miflora/domoticz.py
-T
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
since im not a scriptin/coding guru, im askinfg for help
I would need to stop certain service(BT Beaconing) before updating mi flora, because BT Beacon service dies if anything else access HCI0 .. How can this be achieved ?
Maybe first check if mentioned service running before stopping it ..
Would be nice extra to this great script
-T
-T
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
