corbin
Post by corbin »
deennoo wrote:@ducseb don't you have a fw update to do on your gateway ?
Yes try firmware update, as I believe v2 of the gateway has been released for quite some time already
corbin
Post by corbin »
jjnj wrote:Just to be 100% sure:
i should buy this one: https://goo.gl/qQcoeo and not perse https://goo.gl/TZ1291 ?
I did read somewhere that v1 did not support radio, and that listing specifically states it has the radio feature, so I would guess it is ok.
deennoo
Post by deennoo »
corbin wrote:
Yes these events are reported by the gateway, but I don't know what to translate them to in Domoticz. Have you a suggestion?
Using a selector switch !
http://domo-attitude.fr
pavelbor
Domoticz version: LastBeta
Post by pavelbor »
corbin wrote:
levynger wrote: I have noticed that the Switch Does report single, double and Long press (Pressed and released events)
altough it doesnt appear in Device tab like the other XIOAMI devices.
does this exposed in one the switch type as well?
May be split them into 3 independent buttons (switches without state)?
corbin
Post by corbin »
Thanks, I just changed my source to add a selector switch, but I only see the button for "Off", not "1 Press | 2 Press | Long Press"
Is there something else to do to get those options?
deennoo
Post by deennoo »
My gateway is still not here.
My screen was an exemple for you
Hide off
1 press : selector 10%
2 press : selector 20%
Long press : selector 30%
You have to code it !
corbin
Post by corbin »
pavelbor wrote: May be split them into 3 independent buttons (switches without state)?
That would be ok, but if the switch deennoo has posted can work, it looks the goods!
corbin
Post by corbin »
deennoo wrote:Hide off
I just ticked "Hide Off level", but that doesn't work, where do i Hide Off?
corbin
Post by corbin »
deennoo wrote:My gateway is still not here.
Hide off
Oh, haha!
I'm not going to code that, but you are welcome to :)
Is this something that could be done with the new Python add on?
vetalok
Domoticz version: 3.6273
Post by vetalok »
I have a problem, when I add gateway:
XiaomiGateway: Worker started...
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::system::system_error> >'
what(): bind: Address already in use
Maybe the problem in port? I enter the following data:
type:command
param:addhardware
htype:95
address:192.168.2.193
port:777
password:oz8w8fomda1do20a
enabled:true
datatimeout:0
Mode1:undefined
deennoo
Post by deennoo »
Hide off
Oh, haha!
Will try to help when my gateway will arrive.
About coding/linking switch status to selector switch, i think first that you have to understand that selector is just a dimmer (like yeelight mono bulb) switch with predefin step.
Selector api : https://www.domoticz.com/wiki/Domoticz_ ... tor_Switch
As our switch got 3 status, we need 3 steps, 3 % values
If your able to parse switch message, it need a rules like
If recieve switch xx 1 pluse then selector = 10%
Else if If recieve switch xx 2 pluse then selector = 20%
Else if If recieve switch xx long pulse then selector = 30%
At creation instead of creating push on , select : selector and try adding rules.
Second solution :
Update a text device with switch status message on it.
And python plugin are still on beginning (need to have an installer, and finishing evaluating how it works, if we can call various lib etc etc) as this is a new feature and looks hard to develop this can take time.
corbin
Post by corbin »
I was adding the selector switch in a wrong way. Have done it through the Domoticz GUI now and see the extra options - so will be simple to hook up the code.
corbin
Post by corbin »
vetalok wrote:I have a problem, when I add gateway:
Does this still happen after a system restart?
corbin
Post by corbin »
Switches now have the extra options:
Coldman
Post by Coldman »
corbin wrote:Switches now have the extra options:
to check it is need to do it?
git pull
cmake CMakeLists.txt
make
corbin
Post by corbin »
only in my repository at this stage, so something like this:
git clone https://github.com/corbinmunce/domoticz.git domoticz
deennoo
Post by deennoo »
Great ! Very great !
vetalok
Post by vetalok »
Yes. System crashed and not restarted.
Only If I delete a domoticz.db file, the system runs.
What am I doing wrong? Why do I have this issue?
corbin
Post by corbin »
:) I hope you get you gateway soon, and then give feedback
corbin
Post by corbin »
It might be another program listening on UDP. I will try to stop the crash in my code. Are you running other programs or plugins that could be conflicting?
