Page 8 of 22
Re: Controlling Toon [HACKED] from Domoticz
Posted: Thursday 04 January 2018 11:29
by michel30
Did you create under user variable UV_ToonTemperatureSensorName
The name must be correct without any space also check at the end, I had that issue.
Posted: Thursday 04 January 2018 18:47
by glsf91
michel30 wrote: Thursday 04 January 2018 11:29
I changed the name to ToonTemperature in variable, name temp device and in the script.
Still the same problem, no triggering of the script.
edit:
If I replaced the line:
commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
with:
commandArray['OpenURL'] = '192.168.1.159:8080/json.htm?type=command¶m=udevice&idx='..otherdevices_idx[ToonTemperatureSensorName]..'&nvalue=0&svalue='..currentTemperature
then the script is triggered!
Why is it not working with the UpdateDevice line?
Posted: Sunday 14 January 2018 16:53
by michel30
@glsf91
Strange what script are you using lua script?
I also notes an issue, I updated my toon to version 4.10.6 and now it does not show the analog meter in domoticz
When I check this site: http://IP_TOON/happ_pwrusage?action=GetCurrentUsage I see this:
result: "ok",
powerUsage: {
value: null,
dayCost: null,
avgValue: null
powerProduction: {
value: 0,
dayCost: 0,
avgValue: 93.67
gasUsage: {
value: null,
dayCost: null,
avgValue: null
It is complete diffrent than 4.9.26 does somebody has 4.10.6 analog meter running in domoticz?
Posted: Sunday 14 January 2018 16:59
by glsf91
michel30 wrote: Sunday 14 January 2018 16:53
@glsf91
Yes I use lua script.
script:
-- Time script runs every minute, intended to sync Domoticz with Toon in case the value is changed on the physical device.
-- Updates Toon Thermostat Sensor to value set on Toon
-- Updates Toon Temperature Sensor to value set on Toon
-- Updates Toon Scenes switch based on program set on Toon
-- Updates Toon Auto Program switch to value set on Toon
-- Updates Toon program information text to value set on Toon
ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
ToonScenesSensorName = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
ToonBurnerName = uservariables['UV_ToonBurnerName']
ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
ToonIP = uservariables['UV_ToonIP']
DomoticzIP = uservariables['UV_DomoticzIP']
json = assert(loadfile "/home/john/domoticz/scripts/lua/JSON.lua")() -- For Windows
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
jsonThermostatInfo = json:decode(ThermostatInfo)
currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende
currentProgramState = tonumber(jsonThermostatInfo.programState)
currentActiveState = tonumber(jsonThermostatInfo.activeState)
currentNextTime = jsonThermostatInfo.nextTime
currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
-- Update the thermostat sensor to current setpoint
if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
-- Update the temperature sensor to current room temperature
if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
print('Updating the temperature sensor to new value: ' ..currentTemperature)
-- JBR next line is not triggering the device script. replaced with the url.
--commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
commandArray['OpenURL'] = DomoticzIP..':8080/json.htm?type=command¶m=udevice&idx='..otherdevices_idx[ToonTemperatureSensorName]..'&nvalue=0&svalue='..currentTemperature
-- Update the toon scene selector sensor to current program state
CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
if currentActiveState == -1 then currentActiveState = '50' -- Manual
elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
elseif currentActiveState == 1 then currentActiveState = '30' -- Home
elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
elseif currentActiveState == 3 then currentActiveState = '10' -- Away
if CurrentToonScenesSensorValue ~= currentActiveState then -- Update toon selector if it has changed
print ('Updating Toon Scenes selector')
commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
-- Updates the toon auto program switch
CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
if currentProgramState == 0 then currentProgramState = '10' -- No
elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
print ('Updating Toon Auto Program selector')
commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
-- Updates the toon program information text box
CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
-- Update the toon burner selector to current program state
CurrentToonBurnerValue = otherdevices_svalues[ToonBurnerName]
if currentBurnerInfo == 0 then currentBurnerInfo = '0' -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = '10' -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = '20' -- warmwater aan
if CurrentToonBurnerValue ~= currentBurnerInfo then -- Update toon burner selector if it has changed
print ('Updating Toon burner info')
commandArray[7] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonBurnerName], currentBurnerInfo)}
Posted: Sunday 14 January 2018 17:14
by michel30
@glsf91
And you run it on a windows computer? If I see you scrip.
I used a raspberry PI and don't use LUA but dzVents
timer = {
'every minute'
execute = function(domoticz)
local ToonThermostatSensorName = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint
local ToonTemperatureSensorName = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
local ToonScenesSensorName = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
local ToonAutoProgramSensorName = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
local ToonProgramInformationSensorName = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
local ToonIP = domoticz.variables('UV_ToonIP').value
local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
-- Handle json
--local json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
-- local json = assert(loadfile "/home/maes/domoticz/scripts/lua/JSON.lua")() -- For Linux
json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Raspberry
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
if currentActiveState == -1 then currentActiveState = 50 -- Manual
elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 then currentActiveState = 30 -- Home
elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 then currentActiveState = 10 -- Away
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
local currentBoiletSetPoint = jsonThermostatInfo.currentInternalBoilerSetpoint
if domoticz.devices(ToonThermostatSensorName).setPoint*100 ~= currentSetpoint*100 then
domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
domoticz.devices(ToonThermostatSensorName).updateSetPoint(currentSetpoint).silent()
if domoticz.round(domoticz.devices(ToonTemperatureSensorName).temperature, 1) ~= domoticz.round(currentTemperature, 1) then
domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
domoticz.devices(ToonTemperatureSensorName).updateTemperature(currentTemperature)
if domoticz.devices(ToonScenesSensorName).level ~= currentActiveState then -- Update toon selector if it has changed
domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
domoticz.devices(ToonScenesSensorName).switchSelector(currentActiveState).silent()
if domoticz.devices(ToonAutoProgramSensorName).level ~= currentProgramState then -- Update toon auto program selector if it has changed
domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
domoticz.devices(ToonAutoProgramSensorName).switchSelector(currentProgramState).silent()
if domoticz.devices(ToonProgramInformationSensorName).text ~= ToonProgramInformationSensorValue then
domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformationSensorName).updateText(ToonProgramInformationSensorValue)
Posted: Sunday 14 January 2018 17:26
by glsf91
michel30 wrote: Sunday 14 January 2018 17:14
@glsf91
No, it is running on Ubuntu. Comment was old.
Posted: Sunday 14 January 2018 21:51
by michel30
This line is wrong in your scrip:
You need to change it to Ubuntu, see my scrip this one is change to raspberry pi.
Now it could not run on your ubuntu server.
Posted: Monday 15 January 2018 16:14
by glsf91
michel30 wrote: Sunday 14 January 2018 21:51
What do I have to change to this line?
john@ubuntu1:~$ ls -l /home/john/domoticz/scripts/lua/JSON.lua
-rw-rw-r-- 1 john john 50533 Nov 28 08:34 /home/john/domoticz/scripts/lua/JSON.lua
the path looks fine to me.
And the script is working. Only it don't triggers other scripts when listing for a Toon device.
Posted: Monday 15 January 2018 21:40
by michel30
Not there see your script that you post above on this site.
If you open it you see everything in "or check in domoticz"
In there you will see the path someting like this:
-- Handle json
--local json = assert(loadfile "/home/maes/domoticz/scripts/lua/JSON.lua")() -- For Linux
local json = assert(loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- For Synology
Is see in you scrip use windows local json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
You need to change it for ubuntu someting like this: local json = assert(loadfile "/home/john/domoticz/scripts/lua/JSON.lua")() -- For Linux
Otherwise it will not function.
Posted: Monday 15 January 2018 22:14
by glsf91
michel30 wrote: Monday 15 January 2018 21:40
-- Handle json
My script is in a few
posts above (Sunday 14 January 2018 16:59 ). In the script there is de line:
The comment is wrong. That was a left over.
I also already added local in front of the line.
So I use: local json = assert(loadfile "/home/john/domoticz/scripts/lua/JSON.lua")()
Posted: Saturday 20 January 2018 19:56
by gijsje
I have added the boiler temp to the lue and it works for me
-- Udates Toon Burner status in order to see in domoticz if tyou boiler is on for the hotwater or heating or off (still is a undefined number which i must hunt down)
-- Updates Toon Boiler temp (gijsje)
ToonBoilerTempSetpoint = uservariables['UV_ToonBoilerTempSetpointSensorName'] -- Sensor showing current internal boiler temp
handle:close()
-- JSON data from Toon contains a extra "," which should not be there.
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
currentBoilerSetPoint = tonumber(jsonThermostatInfo.currentInternalBoilerSetpoint)
-- Update the temperature of boiler
if otherdevices_svalues[ToonBoilerTempSetpoint]*100 ~= currentBoilerSetPoint*100 then
print('Updating the boiler temperature to new value: ' ..currentBoilerSetPoint)
commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonBoilerTempSetpoint], currentBoilerSetPoint)}
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. 'C'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. 'C'
Posted: Sunday 21 January 2018 18:43
by madpatrick
I've setup my domoticz server according the intial post, but for some reason the are still some issues.
1. When i use the LUA script "ToonGetInfo" and i change the Scene the selected scene will light up, but after a few second it dims and no scene is selected any more. The Scenes is set to "Manual" is Domoticz dashboard
2. When i want tp change "Toon Thermostat" temperature (using the LUA scripts), Domoticz hangs for a while and the temperature is not changed
3. When i use the DzVents script "ToonGetInfo", the scenes will not be update in Domoticz. The temperature setting is updated with the scene temperature.
The log file gives the following error
2018-01-21 18:38:00.375 dzVents: Info: ------ Start internal script: ToonGetInfo:, trigger: every minute
2018-01-21 18:38:00.410 dzVents: Debug: Device-adapter found for Toon Thermostat: Thermostat setpoint device adapter
2018-01-21 18:38:00.411 dzVents: Debug: Processing device-adapter for Toon Thermostat: Thermostat setpoint device adapter
2018-01-21 18:38:00.412 dzVents: Debug: Device-adapter found for Toon Temperature: Temperature device adapter
2018-01-21 18:38:00.412 dzVents: Debug: Processing device-adapter for Toon Temperature: Temperature device adapter
2018-01-21 18:38:00.412 Error: dzVents: Error: An error occured when calling event handler ToonGetInfo
2018-01-21 18:38:00.412 Error: dzVents: Error: ...moticz/scripts/dzVents/generated_scripts/ToonGetInfo.lua:57: attempt to call field 'round' (a nil value)
2018-01-21 18:38:00.412 dzVents: Info: ------ Finished ToonGetInfo
Posted: Thursday 25 January 2018 11:13
by gielie
Im using the Toon script in combination with my hacked Toon and it works great, but.
Im looking for a way to set my selector switch "Toon auto program" from temporary to yes after a fixed time.
So when i put my thermostat at 21 degrees, the "Toon auto program" goes to "temporary" and i want it to go back to "Yes" (following the program) after 30 minutes. I tried this with a lua and with blocky but i cant get it to work.
Someone here can help me with that?
Posted: Saturday 27 January 2018 12:17
by glsf91
FunFair wrote: Monday 13 November 2017 12:30
Try the script attached as a file. I've replaced dev_3.3 to dev_3.2 and removed the adding of the 2 tariffs.
If you don't have a smart meter I don't know if it's possible to differentiate between low and normal tariff. Toon does not store these values seperately to my knowledge.
The gas readout script does not have to be altered.
I used this script for analog electricity. For some reason the counter at Toon started from zero again. This will also happen when the meter adapter is plugged out and in again as far as I know. Maybe also when restarting Toon.
Then this script won't update Domoticz anymore because the value at Domoticz is higher then Toon: "Toon value incorrect, do nothing".
Does somebody have a solution for this?
Posted: Wednesday 31 January 2018 21:59
by Otelikse
Dear all,
I am a complete newby with Domoticz. I am using a raspberry pi3 with domoticz. I have set all my lightning controls. At this moment like all of you bought a rooted Toon and trying to hook it up in domoticz. I am not the best programmer and therefor I am asking if anyone can help with it. I have read all but still do not understand how to do it.
Posted: Friday 02 February 2018 21:26
by FunFair
glsf91 wrote: Saturday 27 January 2018 12:17
At the end of the script, remove the comparisment that checks if the values are different.
For a slimme meter I had to implement this because after a restart of toon the values would mess up as it wont update the low tariff during the day.
Posted: Sunday 04 February 2018 20:08
by glsf91
FunFair wrote: Friday 02 February 2018 21:26
Then indeed Domoticz is getting data again. But because the counter starts at 0 again there is a big electricity consumption in the graphics of Domoticz.
Maybe it is better to use RRD data because it is not reset to 0.
Example:
http://192.168.1.234/hcb_rrd?action=get ... 18%2014:00
"04-02-2018 15:00:00": 44476,
"04-02-2018 16:00:00": 45108,
"04-02-2018 17:00:00": 45765,
"04-02-2018 18:00:00": 46395,
"04-02-2018 19:00:00": 46988,
"04-02-2018 20:00:00": 47535,
"04-02-2018 21:00:00": 47585
I restarted between 19:00 and 20:00.
The last value is changed every x time until 21:00 is reached.
Posted: Tuesday 06 February 2018 21:14
by glsf91
I have changed/made a PHP script which reads now the analog gas counter from RRD instead of CurrentGasQuantity from getDevices.json. This last one is reset to zero after reboot of Toon (and I think also after restarting the meter adapter).
The counter in RDD is alway increasing, so no strange high measurements in Domoticz after rebooting Toon. Only the first day is showing a high value now when you start using this, because of the current high value in RRD. That cannot be avoided as far as I know (unless resetting Toon).
I'am not a php developer so probably things can be done smarter. But it looks like it is working.
It is derived from analog_electricity_data_json.php, earlier in this thread.
#!/usr/bin/php
<?php
error_reporting(E_ALL);
/* Written by Ierlandfan */
/* modified by glsf91 */
/* 5-2-2018 */
/* Version 3.0 */
/* Set IP addresses and idx*/
$IPDomoticz = '192.168.1.159:8080'; #use 'username:password@domoticz-ip:port' in case of password protection.
$IPToon = '192.168.1.234';
$idx = 77;
/* read gas value from Domoticz */
$json_string = file_get_contents("http://$IPDomoticz/json.htm?type=devices&rid=$idx");
$parsed_json = json_decode($json_string, true);
$parsed_json = $parsed_json['result'][0];
$GasCounterDomoticz = $parsed_json['Data']*1000;
echo "Gas Counter Domoticz = ";
echo $GasCounterDomoticz;
echo " liter";
echo "\n";
// Get current date
$datum = date("d-m-Y");
echo "Request for FROM date: " . $datum . "\n";
// Get Gas counter from Toon
$file_string_gas = file_get_contents("http://$IPToon/hcb_rrd?action=getRrdData&loggerName=gas_quantity&rra=5yrhours&readableTime=1&nullForNaN=1&from=$datum" );
$parsed_json = json_decode($file_string_gas, true);
//var_dump($parsed_json);
if ( empty($parsed_json)) {
echo "Array is empty. Stop executing\n";
return;
// Get last value of array
$keys = array_keys($parsed_json);
end($parsed_json);
$key = key($parsed_json);
//var_dump($key);
$GasCounterToon = $parsed_json[$key];
echo "Gas counter from Toon = " . $GasCounterToon . " liter";
echo "\n";
/* write new value to Domoticz */
if ($GasCounterDomoticz == 0){ #this is for the first run only, when the idx is still empty.
$WriteInitValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$GasCounterToon");
curl_exec($WriteInitValue);
else if ($GasCounterToon < $GasCounterDomoticz){
echo "Toon value incorrect, do nothing \n";
else if ($GasCounterToon >= $GasCounterDomoticz){
$WriteValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$GasCounterToon");
echo "\n";
echo "Write new value \n";
curl_exec($WriteValue);
else {
echo "Domoticz value incorrect, do nothing \n";
Just like the earlier one, put this in cron for running every 1 minute:
*/1 * * * * /home/<directory>/domoticz/scripts/php/gas_data_rrd_json.php
Adjust path to the script.
I don't know if it also will work for a P1 gas meter instead of analog gas meter.
I have also changed the analog electricity to using RRD:
#!/usr/bin/php
<?php
/* Version 1.0 written by Ierlandfan */
/* Version 1.0 modified by DennisD */
/* Version 2.0 rewritten by FunFair */
/* Modified by glsf91 for using RRD */
/* 5-2-2018 */
/* Version 3.0 */
$idx = 78;
/* read electricity value from Domoticz */
$ElecCounterDomoticz = $parsed_json['Data']*1000;
echo "Electricity Counter Domoticz = ";
echo $ElecCounterDomoticz;
echo " Wh";
echo "\n";
/* start of current Energy usage import */
$file_string_ElecUsage = file_get_contents("http://$IPToon/happ_pwrusage?action=GetCurrentUsage");
$parsed_json_ElecUsage = json_decode($file_string_ElecUsage, true);
/* extract the current powerusage */
$ElecUsageToon=$parsed_json_ElecUsage['powerUsage']['value'];
echo "Electricity Usage Toon = ";
echo $ElecUsageToon;
echo " Watt";
echo "\n";
// Get current date
//$datum = "07-02-2018";
//echo "Now: ". date("Y-m-d H:i:s") . "\n";
// Get Electricity LT counter from Toon
$file_string_electLT = file_get_contents("http://$IPToon/hcb_rrd?action=getRrdData&loggerName=elec_quantity_lt&rra=5yrhours&readableTime=1&nullForNaN=1&from=$datum" );
$parsed_json = json_decode($file_string_electLT, true);
return;
end($parsed_json);
//var_dump($key);
$ElecLTCounterToon = $parsed_json[$key];
echo "Electricity LT counter from Toon = " . $ElecLTCounterToon . " Wh";
echo "\n";
// Get Electricity NT counter from Toon
$file_string_electNT = file_get_contents("http://$IPToon/hcb_rrd?action=getRrdData&loggerName=elec_quantity_nt&rra=5yrhours&readableTime=1&nullForNaN=1&from=$datum" );
$parsed_json = json_decode($file_string_electNT, true);
return;
end($parsed_json);
//var_dump($key);
$ElecNTCounterToon = $parsed_json[$key];
echo "Electricity NT counter from Toon = " . $ElecNTCounterToon . " Wh";
echo "\n";
$ElecCounterToon = $ElecNTCounterToon + $ElecLTCounterToon;
echo "Electricity LT + NT counter from Toon = " . $ElecCounterToon . " Wh";
echo "\n";
if ($ElecCounterDomoticz == 0){ #this is for the first run only, when the idx is still empty.
$WriteInitValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$ElecUsageToon;$ElecCounterToon");
else if ($ElecCounterToon < $ElecCounterDomoticz){
else if ($ElecCounterToon >= $ElecCounterDomoticz){
$WriteValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$ElecUsageToon;$ElecCounterToon");
echo "\n";
else {
Add this one to the cron the same way.
Posted: Thursday 08 February 2018 20:16
by michel30
I use the analog scrip for GAS and POWER, that works super in my domoticz.
Now I want to add the price and I see under the tap setup > settings > Meters/Counters the following fields: RFXMeter/Counter Dividers:
I edit the price in here, but I don't see it in my Domoticz I only see the GAS or power use.
How can I see the price in domoticz? or will this only works if you have a P1 cable?
Posted: Monday 05 March 2018 19:04
by FunFair
glsf91 wrote: Tuesday 06 February 2018 21:14
Wow thanks! This is a much better solution than the previous one!!!!
It doesn't matter anymore if you have an analog or smart meter, as Toon writes the values in the same database.
I've used your code to clean up my versions and removed the comparisment incase Toon reported 'zero' values.
Tested these scripts with Toon version 4.9 and they work with:
- P1 Smart meter (including solar return)
- Analog/Digital Electricity meter
- Analog/Digital Gas meter
See file attached for who's interested.
