Page 70 of 120
Re: RE: Re: Domoticz app 2.0
Posted: Friday 13 January 2017 17:02
by roiz
galadril wrote:roiz wrote:
I don't know if I did something wrong... I installed the application to my phone and all working beside blinds...
It is not available at the Android app. Is that ok???
blinds should work....
I'm using light version .. is that might be the issue?
System image:
app image:
Sent from my ASUS_Z00AD using Tapatalk
Posted: Friday 13 January 2017 17:04
by galadril
Testing the widgets
- Transparent background for dark wallpapers
- Transparent background for light wallpapers
- Security panel widget
- Blind widget
Next:
thinking of 1x1 small widget with only icon, for toggling lights??
What do you guys think?
Posted: Friday 13 January 2017 17:05
by galadril
roiz wrote:I installed the application to my phone and all working beside blinds...
[/quote]
Maybe your device name? can you name the blind something simplr like 'blind' just to test?
Else please create a viewer account for me so I could test
Re: RE: Re: RE: Re: Domoticz app 2.0
Posted: Friday 13 January 2017 17:38
by roiz
galadril wrote:roiz wrote:I installed the application to my phone and all working beside blinds...
Else please create a viewer account for me so I could test[/quote]
I changed the name to simple name and no change - still only one device at the switch.
When I created plans it shows two devices but only one device is available.
Re: RE: Re: RE: Re: RE: Re: Domoticz app 2.0
Posted: Friday 13 January 2017 17:40
by roiz
roiz wrote:galadril wrote:roiz wrote:I installed the application to my phone and all working beside blinds...
Sent from my ASUS_Z00AD using Tapatalk[/quote]
I found the problem... it can not show Venetian blinds only on/off. There is any option to add it?
Posted: Friday 13 January 2017 20:54
by galadril
Ill test the Ventian blind!
Posted: Saturday 14 January 2017 15:59
by webpatrick
I have a smart meter, with an P1 cable connected to my Synology NAS.
I also have two different usage rates (day 'Verbruik 1' and night 'Verbruik 2') and on my domoticz page I see both.
On the Android App I only see one usage rate (only day 'Verbruik 1'). And the scale is percentage ??? While in Domoticz it's Kwh which it shoud be.
Posted: Saturday 14 January 2017 20:17
by Jordyboytjuh
Hi guys, what's the reason that I can't stop my blinds anymore (also on the dashboard). Before updating everything was right. I'M using the latest beta. Thanks in advance.
Posted: Sunday 15 January 2017 0:26
by BazsoDombiAndras
Hi!
I wish to inform you about an important geo-fencing bug that I have found in the Domoticz app. I've tested it a lot and I can consistently reproduce the following bug:
Steps:
1. I set up one or more geo-fences.
2. I walk in and out of the geo-fence perimeters and the geo-fences are porperly triggered and the associated switches are properly switched.
3. If I kill the Domoticz app the geo-fences still work properly (thank God!)
4. If I reboot my phone, the geo-fences are lost and they won't trigger anymore when I walk in and out of the geo-fence perimeters.
5. If I open the Domoticz app after the reboot of the phone, the geo-fences still won't work.
6. If I go to Settings -> Configure Geofencing in the Domoticz app, the geo-fences are restored automatically (without actually changing anything in the geo-fence settings) and start working properly again (until the next reboot).
Can you please take a look and try to fix this? I read on some Andoird development forums that the apps need to subscribe to notifications about reboot and restore their geo-fences when they receive such a notification. Propbably this is the case. Here are some resources that might help you understand the bug:
http://stackoverflow.com/questions/1704 ... g-a-reboot
http://stackoverflow.com/questions/2007 ... ice-reboot
I use Android 6.0 on an AllView X3 Soul Pro device. My location accuracy is set to High and the Domoticz app is set not to be battery-optimized. I use version 0.1.343 of the Domoticz app.
Some other suggestions to improve the Domoticz app:
a) The UI to define the geo-fences is confusing (Get button + Manual button) and really needs a map-based interface, like IFTTT's location service.
b) The widgets are way too bulky, they use immense fonts and take up way too much screen space. I would like smaller widghets, which can fit into 1x1 or 1x2 blocks on the screen, so that I can have many widgets on one screen.
c) Add the ability to change the states of switches based on connected WiFi network. I would like to disarm the security panel and turn on the lights whenever I arrive home and my phone connects to my home WiFi network. Geo-fencing is innacurate and not very reliable, but this network-based approach would be both accurate and reliable. Please consider it.
Thank you!
PS: Congratulations for an overall very nice Domoticz app!
Posted: Sunday 15 January 2017 11:51
by deejc
tequila wrote:Hey guys,
is there a way to setup the app to login to the server using the my.domoticz.com remote access?
is there any advance on this ?
i am using the lite version right now, but if i know it will work with my.domoticz i will purchase premium, and then i can use local notifications from the app and not NMA or setup a reverse proxy
Posted: Sunday 15 January 2017 21:09
by piokuc
I found a bug in app. On widget for dimmer still show button OFF. Button should be show ON if switch is off and OFF when switch is on. But now still show button OFF.
And is any chance to add for widget dimmer option to setup level dimmer ?
Posted: Tuesday 17 January 2017 9:42
by galadril
BazsoDombiAndras wrote:I wish to inform you about an important geo-fencing bug that I have found in the Domoticz app. I've tested it a lot and I can consistently reproduce the following bug
Thanks for the feedback..
Ill add your points to the list.
Next beta already contains nice 1x1 small widgets which you can toggle by pressing the icon
Posted: Tuesday 17 January 2017 9:44
by galadril
No not yet.. I've asked the developer of my.domoticz to assist on this...
But he didn't got the time yet
Posted: Tuesday 17 January 2017 9:46
by galadril
webpatrick wrote:I have a smart meter, with an P1 cable connected to my Synology NAS.
Hi patrick,
can you send me the url that domoticz uses to get the log, for example:
http://ip:port/json.htm?type=graph&sensor=counter&idx=58&range=week
and how the json looks like, for example:
"ValueQuantity" : "",
"ValueUnits" : "",
"result" : [
"d" : "2017-01-10",
"v" : "2.000"
"d" : "2017-01-11",
"v" : "4.000"
"d" : "2017-01-12",
"v" : "1.000"
Posted: Tuesday 17 January 2017 13:48
by piokuc
piokuc wrote:I found a bug in app. On widget for dimmer still show button OFF. Button should be show ON if switch is off and OFF when switch is on. But now still show button OFF.
@galadril what with my issue ?
Posted: Tuesday 17 January 2017 16:41
by galadril
piokuc wrote:piokuc wrote:I found a bug in app. On widget for dimmer still show button OFF. Button should be show ON if switch is off and OFF when switch is on. But now still show button OFF.
Im going to look at the bug.
The dimmer is going on a future list for now..
Posted: Tuesday 17 January 2017 18:33
by deejc
I seem to be getting notifications in the app on mobile data with no connection to my server, how is this possible ? I also have NMA installed is it something to do with this ?
Sent from my UMI_SUPER using Tapatalk
Posted: Tuesday 17 January 2017 18:45
by MarcelMAH
deejc wrote:I seem to be getting notifications in the app on mobile data with no connection to my server, how is this possible ? I also have NMA installed is it something to do with this ?
Works via Google
Posted: Tuesday 17 January 2017 18:54
by deejc
Amazing !!!! I'm going to purchase the premium right now.
Posted: Tuesday 17 January 2017 19:58
by ggt156
No remote connection over WAN possible - android app Domoticz Lite
I can't set up a working remote connection with the Ándroid Domoticz Lite app, it works in the LAN but no access over the WAN.
I set up port forwarding in the modem and set it up in the Domoticz application on the raspberry pi 3 and did the setting in the Android Domoticz Lite app. I have a static ip adres from the provider.
What's happen?
Who have an solution for this issue?
thanks in advance
The hardware : raspberry pi 3, z-wave gen 5 usb stick, fibaro smoke sensor
regards Gerrit
