Page 69 of 120
Re: Domoticz app 2.0
Posted: Monday 09 January 2017 14:12
by fergalom
working here also now, thanks!
Posted: Monday 09 January 2017 16:46
by EddyG
Sorry for the nitpicking, but on the Wiki it states UR
L instead of UR
I.
It might confuse others.
Posted: Tuesday 10 January 2017 0:57
by NiklasO
Still can't add widgets. Any suggestions?
Re: RE: Re: Domoticz app 2.0
Posted: Tuesday 10 January 2017 6:40
by jjnj
NiklasO wrote:Still can't add widgets. Any suggestions?
Is the app installed on the SD or internal memory?
Posted: Tuesday 10 January 2017 17:02
by galadril
You'll probably need to reconfigure widgets when installing the next beta..
Also transparant!!
Posted: Tuesday 10 January 2017 17:58
by piokuc
For me one big problem is slider for dimmer. Is too small. Is not comfortable. I use Galaxy S6 with big sreen more han 5" and sometimes i can not setup correct value gor dimmer. I have big finger and it is prolem. Maybe good option will be setup slider under all text and to setup full size ?
Posted: Tuesday 10 January 2017 19:24
by tjabas
galadril wrote:You'll probably need to reconfigure widgets when installing the next beta..
Also transparant!!
oh man!! i´ve always wanted the transparent widget, where can i get the beta version?
Posted: Tuesday 10 January 2017 22:17
by roiz
I don't know if I did something wrong... I installed the application to my phone and all working beside blinds...
It is not available at the Android app. Is that ok???
Sent from my ASUS_Z00AD using Tapatalk
Posted: Wednesday 11 January 2017 21:26
by NiklasO
jjnj wrote:NiklasO wrote:Still can't add widgets. Any suggestions?
No SD card slot.
Can't say when it started to tell me that I need the premium version for widgets. It has worked before because I had widgets already in place but they dissappeared when I tried to reinstall the app of course so now I have none...
Posted: Thursday 12 January 2017 8:46
by martk
new widgets are nice, but it comes with a few bugs..
If you add a scene widget, you can only turn it on, not off. Little irritating as I use this widget to turn off my home lights
If you add a push button widget it used to have one button named On, now it has a button named Off (uit in my case, dutch), it still works though.
Posted: Thursday 12 January 2017 9:36
by tjabas
Where can i get this beta version of the app?
Posted: Thursday 12 January 2017 13:55
by micha_pr
Refresh status / values
I have found several questions about this, but no answer - maybe haven't seen it - and somebody can help?
How to configure the App that values will be refreshed after some time - like door sensor, temperature etc.
I see all the time the "old" values.
Or is this "by design" and should not be refreshed (like in other apps) ?
Michael
Posted: Thursday 12 January 2017 23:06
by NiklasO
Updated a couple of minutes ago, I can now add widgets again!
Posted: Friday 13 January 2017 9:27
by galadril
At this moment you can refresh a screen by pulling the list down.
by galadril
NiklasO wrote:Updated a couple of minutes ago, I can now add widgets again!
Good to know!
Posted: Friday 13 January 2017 9:28
by galadril
tjabas wrote:Where can i get this beta version of the app?
You can find a link to the play store to become beta tester here:
http://hnogames.nl/domoticz.html
(at the bottom)
Posted: Friday 13 January 2017 9:29
by galadril
martk wrote:If you add a scene widget, you can only turn it on, not off. Little irritating as I use this widget to turn off my home lights
ill test them!
Posted: Friday 13 January 2017 9:32
by galadril
blinds should work....
Posted: Friday 13 January 2017 13:50
by ultratoto14
Hi Galadril,
Do not know if it was asked before but i have some problem with the axes on the graphs.
I added a screenshot of my wind graph (i'm french so Wind = Vent) and the axes labels are not readable.
Is it something you are aware of ?
Best regards,
U.
Posted: Friday 13 January 2017 17:01
by galadril
Ill at it to the list
