homebridge-edomoticz Plugin
mcmikev
Re: homebridge-edomoticz Plugin
Post by mcmikev »
Here still no joy.
Harmonyhub is seen and added (every version btw).
Domoticz with or without roomid does not load any accessiores.
Deleted the accessoires and persist dirs.
my config:
    "bridge": {
        "name": "HomebridgeDomoticz",
        "username": "CC:21:3E:E4:DE:33",
        "port": 51826,
        "pin": "034-65-321"
    "description": "Configuration file for (e)xtended Domoticz platform.",
    "platforms": [
            "platform": "eDomoticz",
            "name": "eDomoticz",
            "server": "127.0.0.1",
            "port": "8080",
            "ssl": 0,
            "mqtt": 1,
            "excludedDevices": []
   		"platform": "HarmonyHub",
   		"name": "Harmony Hub"
    "accessories": []
[7/21/2017, 4:27:25 PM] Loaded plugin: homebridge-edomoticz
[7/21/2017, 4:27:25 PM] Registering platform 'homebridge-edomoticz.eDomoticz'
[7/21/2017, 4:27:25 PM] ---
[7/21/2017, 4:27:25 PM] Loaded plugin: homebridge-harmonyhub
[7/21/2017, 4:27:26 PM] Registering platform 'homebridge-harmonyhub.HarmonyHub'
[7/21/2017, 4:27:26 PM] ---
[7/21/2017, 4:27:26 PM] Loaded config.json with 0 accessories and 2 platforms.
[7/21/2017, 4:27:26 PM] Loading 2 platforms...
[7/21/2017, 4:27:26 PM] [eDomoticz] Initializing eDomoticz platform...
[7/21/2017, 4:27:26 PM] [Harmony Hub] Initializing HarmonyHub platform...
[7/21/2017, 4:27:26 PM] Loading 0 accessories...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
[7/21/2017, 4:27:27 PM] Homebridge is running on port 51826.
[7/21/2017, 4:27:37 PM] [eDomoticz] Successfully connected to MQTT broker.
[7/21/2017, 4:27:38 PM] [Harmony Hub] Fetching Logitech Harmony activities...
[7/21/2017, 4:27:39 PM] [Harmony Hub] Found activities:
mcmikev
Post by mcmikev »
updated to version 2.0.8 to test. Still no accessiores loaded.
went back to old version again
Robbie
Domoticz version: 2.2980
Post by Robbie »
I to ran into trouble after updating to 2.*
As turned out, there was 'load-scenes' in my config.
I removed id, cleared the accessories dir, and started succesfully.
It was a hassle to re-add all devices to their rooms and recreate scenes and such though.
I just read about Apple opening up the Homekit protocol.
Will this be an oppertunity for Domoticz to do a full integration?
mcmikev
Post by mcmikev »
No scenes in my roomid present. Version 2.x is not loading any accessoires. Harmonyhub is working without issues.
zwaffie
Post by zwaffie »
I did a fresh restall of domoticz and homekit. Normally this worked fine for me. Today I wanted to make a domoitcz server for my friend on an raspberry pi. Domoticz is running fine and the lights are working. Now I installed homekit and get the following error in pm2 logs homebridge. Can someone help me with the mqtt problem. Like I said. Fresh install of both.
followed these pages.
https://www.domoticz.com/wiki/Installin ... spberry_PI
https://www.domoticz.com/wiki/Homekit_Siri
15 days ago it worked fine for me.
0|homebrid | [7/25/2017, 6:04:17 PM] Loading 0 accessories...
0|homebrid | Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
0|homebrid |
0|homebrid |     ┌────────────┐
0|homebrid |     │ 031-45-154 │
0|homebrid |     └────────────┘
0|homebrid |
0|homebrid | [7/25/2017, 6:04:18 PM] Homebridge is running on port 51826.
0|homebrid | [7/25/2017, 6:04:18 PM] [eDomoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
0|homebrid | Please verify that you have added the MQTT Hardware Device and that the hardware device is enabled.
0|homebrid | [7/25/2017, 6:04:20 PM] [Harmony Hub] Fetching Logitech Harmony activities...
0|homebrid | [7/25/2017, 6:04:21 PM] [Harmony Hub] Found activities:
0|homebrid |    Slapen
0|homebrid |    Kodi
0|homebrid |    PowerOff
0|homebrid |    Playstation4
0|homebrid |    Tv kijken
0|homebrid |    Naar muziek luisteren
0|homebrid |    Netflix Kijken
0|homebrid |     Xbox 360
mcmikev
Post by mcmikev »
mcmikev wrote:No scenes in my roomid present. Version 2.x is not loading any accessoires. Harmonyhub is working without issues.
Just discovered that although when starting homebridge from commandline with homebridge shows no accessiores loaded in home app on the phone I can see the items when creating new home.
So the logs shows no accessoires loaded but they are there!
gutaker
Post by gutaker »
mcmikev wrote:Just upgraded to 2.0.4 and still no domoticz accesoires are loaded.
[7/21/2017, 1:21:40 PM] Loaded plugin: homebridge-edomoticz
[7/21/2017, 1:21:40 PM] Registering platform 'homebridge-edomoticz.eDomoticz'
[7/21/2017, 1:21:40 PM] ---
[7/21/2017, 1:21:40 PM] Loaded plugin: homebridge-harmonyhub
[7/21/2017, 1:21:42 PM] Registering platform 'homebridge-harmonyhub.HarmonyHub'
[7/21/2017, 1:21:42 PM] ---
[7/21/2017, 1:21:42 PM] Loaded config.json with 0 accessories and 2 platforms.
[7/21/2017, 1:21:42 PM] Loading 2 platforms...
[7/21/2017, 1:21:42 PM] [eDomoticz] Initializing eDomoticz platform...
[7/21/2017, 1:21:42 PM] [Harmony Hub] Initializing HarmonyHub platform...
[7/21/2017, 1:21:42 PM] Loading 0 accessories...
I've been trying lots of software includig z-way and finally got back here for Domoticz.
After proper installation i was smashed with big question mark an 3-letter abbreviation "WTF", and have to complain that i got the same behavior here on Raspberry Pi 2 Model B.
  • Fresh Domoticz,
  • fresh homebridge 0.4.2,
  • fresh homebridge-edomoticz 2.0.8
The only difference is i don't use real device, dummy hardware with virtual sensors/actuators only.
On the other hand, after downgrading homebridge-edomoticz to 1.0.15, it manages to find accessories but with following messages:
Failed to find plugin to handle accessory Livingroom heater switch
Failed to find plugin to handle accessory Livingroom temperature
Failed to find plugin to handle accessory Internal Temperature
Failed to find plugin to handle accessory Memory Usage
The config.json:
    "bridge": {
        "name": "Homebridge",
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "port": "8080",
            "ssl": 0,
            "roomid": 2,
            "mqtt": 0
    "accessories": []
Any clues?
bdormael
Post by bdormael »
Just installed version 2.x, I noticed an old issue has returned:
I’m using Apple’s Home app. When changing a value via the Domoticz website from example a switch, Apple Home is not updated until twice closing and opening the Home app again.
I know this has been fixed earlier with an older version, is it broken again or am I doing something wrong?
I’m using MQTT as well
Verzonden vanaf mijn iPad met Tapatalk
gutaker
Post by gutaker »
Thanks @mcmikev !
It's confirmed! Confirmed but strange anyway.
Updated to latest 2.0.8 version and checked ~/.homebridge/accessories folder - it has file cachedAccessories with all neccesary contents!
bdormael
Post by bdormael »
bdormael wrote:Just installed version 2.x, I noticed an old issue has returned:
Never mind, noticed I still had an old config file, therefore mqtt was not used, changed to 2.x confie file, all working fine now.
Boest
Domoticz version: 3.8202
Post by Boest »
Is it possible to add an ip camera to the homebridge? And how do I get to work?
Thnx!!
Nautilus
Post by Nautilus »
Boest wrote:Is it possible to add an ip camera to the homebridge? And how do I get to work?
Thnx!!
To my knowledge this is not implemented to eDomoticz plugin and as such I don't see it as a core functionality either. But there are several other plugins developed for just this purpose: https://www.google.com/search?q=homebri ... era+plugin :)
Boest
Post by Boest »
Thnx!!
To my knowledge this is not implemented to eDomoticz plugin and as such I don't see it as a core functionality either. But there are several other plugins developed for just this purpose: https://www.google.fi/search?q=homebridge+camera+plugin :)
Thank you, I found this, but I'm just a starter. I do not dare everything yet.
anasazi
Post by anasazi »
Thnx!!
I'm using this plugin with success:
https://github.com/KhaosT/homebridge-camera-ffmpeg
simon_rb
Post by simon_rb »
bdormael wrote: Wednesday 26 July 2017 16:30
Thanks for this! I noticed the same behaviour! Working lightning fast now, thought I'd been running MQTT since updating to version 2 about a week ago lol. Forgotten how much quicker MQTT is!
italoc
Post by italoc »
there is a way to control a SELECTOR SWITCH in Home.app ? i have the latest version of domoticz stable and latatest version of homebridge-edomoticz and homebridge
Homekit always say me that it's unsupported device.
thanks
islandman
Post by islandman »
Just two questions:
I use wall sockets via domoticz, they are shows in domoticz with wall socket, however within homebridge they are switches?
Second, i us buttons with three options (klick, double klick, long klick) these type is supported in homKit as well but via this plugin the show not supported?
fennec62
Post by fennec62 »
Hi since last update i can't open and closed my garage with siri
button is ok in Home app
With Siri command is reverse
The garage is closed
With button command is
MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":498,"switchcmd":"Off"} and it's ok garage open
but with siri the command is
MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":498,"switchcmd":"On"}
Thanks for help
Bikey
Domoticz version: 2020.x
Post by Bikey »
My homebridge installation on the RPI2 worked fine until recently. Now it won't start anymore.
I played around with Node-Red and had to upgrade Node, so I think something this may have broke something.
This is what I get in the log:
/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:35
    throw ex;
Error: Module version mismatch. Expected 48, got 57.
    at Error (native)
    at Object.Module._extensions..node (module.js:597:18)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.require (module.js:497:17)
    at require (internal/module.js:20:19)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:24:20)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions..js (module.js:579:10)
Tried an upgrade:
sudo npm install -g homebridge --unsafe-perm
sudo npm install -g homebridge-edomoticz --unsafe-perm
but that doesn't help.
I'm on Node v6.11.2 and NPM 3.10.10
Anybody some clues what I can do next?
** EDIT **
I did a full uninstall and then install again and now it works again.
sudo npm uninstall -g homebridge --unsafe-perm
sudo npm uninstall -g homebridge-edomoticz --unsafe-perm
solidum90
Domoticz version: Debian
Post by solidum90 »
Hello to everyone :)
I use this amazing plugin, congratulations to the creators!
I only have one question (which actually concerns Siri), how can I activate "Hey Siri" command with bluetooth speaker??
Because "Hey Siri" it works only if the iPhone microphone feels the phrase "Hey Siri", then it use the bluetooth speaker to hear the command.
There's no way to use bluetooth speaker? Would be a nice voice assistant.
Thanks to everyone! ;)
