domoticz in synology as package! Available now.
DomoArigato
Re: domoticz in synology as package! Available now.
Post by DomoArigato »
I think that is for new stable versions. :)
I looked into my package center and tried an update but it only shows the version (3.8153) which I already use. The beta from jadahls website (beta 3.9390) is not shown.
Therefore I guess I have to manually download and install this package (beta for DSM 6.1 with python).
So the question (unfortunately) still remains ;)
manutremo
Post by manutremo »
Yes, you need to download the file and do a manual install. Beta versions do not update automatically.
DomoArigato
So I just install after download like I did with the first package?
And then all systems settings and configurations remain from previous version?
Ernstl
Domoticz version: 2020.2 b
Post by Ernstl »
1. Do a backup from the domoticz-setting page.
2. Install the beta you want to use manually.
3. If the settings get lost, reload the backup in domoticz from the setting page.
4. It might be necessary to restart domoticz after that, you will see if the configs are right on.
More did I never need.
Ernstl
DomoArigato
Thanks a lot for your detailed list.
It works great.
I just had to manually copy the dzVents folder into the domoticz folder and after that all works great so far.
Another question to @jumbotroll:
Does this beta (3.9390 with python for DS 214) also already contain the z-wave Central Scene Command Class patch?
Trying to work with that but failed so far and so i just want to make sure the patch is there :)
So many thanks for all your effort building those packages for us!!
Regards to all
jumbotroll
Post by jumbotroll »
DomoArigato wrote: Friday 18 May 2018 22:40 Another question to @jumbotroll:
Yes.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
PieterS
Domoticz version: 2024.7
Post by PieterS »
jumbotroll wrote: Sunday 01 October 2017 0:03
PieterS wrote: Saturday 30 September 2017 23:42 Dear Sir,
What about other packages you made in the past? I think you served me a package for Netcat V 0.7.1 for DSM 5.2-5967 in the Synocommunity by adding an entry in Packagecenter, Settings, Packagesources. (http://www.jadahl.com/synology/)
It's too bad that I can't get that spk-file any more after an fresh install of my Syno. I need Netcat to send TCP-commands from Domoticz to a relayboard.
The backup I made by copying the files from the directory in @appstore and restoring didn't work. :cry:
Is it still possible to get it elsewhere?
Thanks in advance.
I have stop build these packages, but have not deleted the Netcat packages.
What Nas do you have and what DSM version do you looking for 5.2 or 6.1?
Maybe there is a Netcat on my server 8-)
@jumbotroll:
Bought an new NAS: Synology 718+ (Apollo Lake) with DSM 6.1.7-15284. Hopefully there is still a version of Netcat on your server? :P
Can you send me a link to download? Thanks in advance.
Pieter
Synology with Domoticz build (V2024.7) in Docker
jumbotroll
PieterS wrote: Sunday 27 May 2018 15:00
@jumbotroll:
Pieter
There was never build any Netcat packages for DSM 6.1 (Apollolake).
I have build a package for you to test..
BTW I have no time to do testing or support on these packages ;)
Download from here:
http://www.jadahl.com/synospk/
Jumbotroll
PieterS
Post by PieterS »
Thanks for fast reply.
Choosed to install the package with version 7.70 but that installed nmap. No errors during installation.
My scripts uses nc-command and that is not found when I run that in putty.
I am not very fimiliar with Linux so I give it a try later on this week.
Or try a workaround in the virtual Windows machine that I can run on the new DS718. :D :D
jumbotroll
PieterS wrote: Sunday 27 May 2018 19:52 Thanks for fast reply.
The nmap package does not support nc command.
The Netcat package does, so why don't you install both packages :D
Jumbotroll
sylar
Domoticz version: 4.10311
Post by sylar »
Hi there!
Synology has just released the final version of DSM 6.2.
I'm using jadahl stable package with DSM 6.1 for now. How to proceed with this major DSM update? Will I have to upgrade to a beta version of Domoticz after updating DSM? Of course, I do not want to loose all my setting, scripts, zwave association, etc.
Thanks for your help.
jumbotroll
sylar wrote: Tuesday 29 May 2018 9:57 Hi there!
If everything working ok with domoticz for DSM6.1, there is no need for update to domoticz DSM6.2 beta.
If you have problems with USB drivers after updating to DSM6.2, you need the domoticz DSM6.2 because synology have updated linux kernel and drivers on some models and USB drivers need to be updated.
Jumbotroll
sylar
Post by sylar »
Thanks for your answer. So basically, I will have to:
0/ backup my Domoticz setup
1/ update DSM 6.1 to DSM 6.2,
2/ test if Domoticz stable version for DSM 6.1 is still working (the only USB device I'm using is a Aeotec Z-Stick Gen5 dongle)
3/ if not, update it to Domoticz beta version for DSM 6.2
OK, I'll try that... in a few weeks, when DSM 6.2 will be tested and approved by most users.
jumbotroll
sylar wrote: Tuesday 29 May 2018 10:41 Thanks for your answer. So basically, I will have to:
Yes, you have to test. I have not yet compiled domoticz DSM 6.2 for all models yet, but I will get there soon ;)
If you give me your NAS model, maybe I can tell you if you need to update.
BTW.. If you update from stable version to beta DSM6.2, the best solution is to take backup of domoticz.db and reinstall domoticz.
Jumbotroll
sylar
Post by sylar »
I have a DS415+. Thank you!
jumbotroll
sylar wrote: Tuesday 29 May 2018 10:46 I have a DS415+. Thank you!
DS415+ arch-avoton, and I think you have to update.
Jumbotroll
sylar
Post by sylar »
Reinstall=remove the "old" stable package and install the beta afterwards?
jumbotroll
sylar wrote: Tuesday 29 May 2018 10:50 Reinstall=remove the "old" stable package and install the beta afterwards?
Yes, because the beta version have some new folders.
Take backup of database and script you use and uninstall the stable version, then install beta DSM 6.2 version.
Jumbotroll
sylar
Post by sylar »
OK, thank you very much for your messages. I'll try this once DSM6.2 will be considered stable enough (but this version seems already well-tested after a 6 months beta test).
startfish
Post by startfish »
Hello Jumbotroll ! I'm very interested in use Domoticz in my Synology. I'm using V 6.2 (last one) and I have a DS215j model (it's a MARVELL Armada 375 88F6720). Please could you compile for this version?
