homebridge-edomoticz Plugin
Nederveen
Re: homebridge-edomoticz Plugin
Post by Nederveen »
Dear all,
I am new to domoticz and have been trying desperately to get my fibaro dimmer 2 to work with homekit.
Hopefully you can help me out.
I am using the following setup
Raspberry pi
Fibaro Dimmer 2
aeotec z-stick
1. I installed raspbian jessie lite
2. followed the domoticz/homekit installation steps of this tutorial: https://possible.tweakblogs.net/blog/14 ... spberry-pi
3. Included my z-stick in domoticz via this tutorial http://domotica-projecten.nl/d/2-includ ... t-domoticz
4. installed the plugin for fibaro HC2 (since it states that the dimmer should be included) with the command (sudo npm install -g homebridge-fibaro-hc2)
I can see the homebridge in the homekit app, but when I add it, it says that I still have to identify an accessory.
I'm I missing a step? Is there anything I didn't do properly?
As far as I can understand I will have to do something with the homebridge/config.json but I am not sure.
Currently it is lie this:
"bridge": {
"name": "Homebridge",
"username": "CC:21:3E:E4:DE:33",
"port": 51826,
"pin": "031-45-154"
"description": "Configuration file for (e)xtended Domoticz platform.",
"platforms": [
"platform": "eDomoticz",
"name": "eDomoticz",
"server": "127.0.0.1",
"port": "8080",
"ssl": 0,
"roomid": 0,
"mqtt": 0
"accessories": []
I am looking forward to your responses.
Best,
:ugeek:
Trigun
Domoticz version: 4.10717
Post by Trigun »
Hi Nederveen, you did add the hardware in domoticz for the z-stick? And you've added the fibaro via the stick instead of node management?
Nederveen
Post by Nederveen »
Trigun wrote:Hi Nederveen, you did add the hardware in domoticz for the z-stick? And you've added the fibaro via the stick instead of node management?
Thanks for your quick response. I added the domoticz hardware for the stick. After that I clicked the pairing button on the z-stick and held it next to the dimmer switch. After that the dimmer also showed up in domoticz hardware under the z-stick setup.
Trigun
Post by Trigun »
Remember that if you use the z-stick, you have to restart domoticz to have a correct pairing.
Nederveen
Post by Nederveen »
Thanks. Unfortunately that didn't help. Is the config.json file correct though as posted above? i'm not sure. Or do I have to change stuff in domoticz before the dimmer will show up in homekit app?
Trigun
Post by Trigun »
I'll check my config and compare it with yours. Will probably be later today
Nederveen
Post by Nederveen »
Unfortunately I still can't get it running. If I run homebrigde on my pi. This is what I see.
It states loading 0 accessories. That can't be right can it?
Nederveen
Post by Nederveen »
This is my config.json
Schermafbeelding 2017-05-01 om 22.48.36.png (76.34 KiB) Viewed 5109 times
Trigun
Post by Trigun »
Hi Nederveen, the config looks fine, did you check the stuff I sent you? According to the log it seems something goes wrong with the fibaro, do you have other devices as well?
Nederveen
Post by Nederveen »
Thanks, indeed I see that you sent me a pm.
I'll try you method from scratch.
Artic1980
Post by Artic1980 »
Nederveen wrote:PastedGraphic-1.png
I did so when it did not go
delete folder ~/.homebridge/persist
change code pair
reboot
MacJL
Target OS: OS X
Post by MacJL »
anasazi wrote:Hi,
Is there support for IP Cameras?
I understand that HAP-Nodejs has support for this but how about homebridge and eDomoticz?
If you want to have your camera in Homekit, you can use this homebridge plugin :
https://github.com/KhaosT/homebridge-camera-ffmpeg
I'm using it in parallel of homebridge-edomoticz, and it's really nice to have all my switches and cameras in home App.
anasazi
Post by anasazi »
MacJL wrote:
anasazi wrote:Hi,
Thanks for the tip!
Will check it out...
poudenes
Domoticz version: 3.8993
Post by poudenes »
Love the plugin guys !!!! any news about using Scenes/Groups into Homebridge?
Or still create a switch with a on and off action in it?
I have a Nanoleaf Aurora lights panels... You can create scenes in their app and those scenes are pushed into Homekit.
So it would be great if Domoticz can push her scenes into homebridge as well so you can have them in Homekit
bxlouis
Domoticz version: 2020.1
Post by bxlouis »
Maybe it has already been discussed but I can't find it on the forum - maybe I use the wrong keywords :?
I am wondering if it is possible to read the Homekit scenes and display/be able to trigger them from Domoticz?
That would be very useful!
Mazzokun
Post by Mazzokun »
Hi all
is there a way to use "monit watchdog" to monitor the homebridge.service?
I've tried with
check process homebridge with pidfile /var/run/homebridge.pid
start program = "/lib/systemd/system start homebridge.service"
stop program  = "/lib/systemd/system stop homebridge.service"
if failed host 127.0.0.1 port 51826 protocol http
and request "/accessories"
then restart
if 3 restarts within 5 cycles then timeout
but doesn't work, monit can't Initializing it... Any idea??
Thank you ;)
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Fantastic tip! Just installed the Foscam plugin and works beautifully https://www.npmjs.com/package/homebridge-foscamcamera
11101101 - www.machinon.com
theo69
Domoticz version: la. beta
Post by theo69 »
Hi I am using the plugin together with Xiaomi Gateway (Domoticz Beta) and all items (switches, contacts etc.) are shown in HomeKit however i Can not control them and they are not being updated. You can not see when a switch was switched!
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
theo69
Post by theo69 »
HI I am new to Domoticz and trying to get homebridge connected, however I am always getting:
[6/5/2017, 10:21:42 AM] [eDomoticz] Retrying connection to MQTT broker...
[6/5/2017, 10:21:42 AM] [eDomoticz] Could not connect to MQTT broker! (localhost:1883)
I am lost where did go wrong, added MQTT
[img]
[/img]
theo69
Post by theo69 »
The MQTT Broker was not installed properly, now i got the connection!
