Page 65 of 120
Re: Domoticz app 2.0
Posted: Monday 14 November 2016 20:11
by jake
Thanks! The previous update of the app returned the notifications to my tablet (CM 12.1). The update of 13-11-16? returned notifications on my cell phone as well (AICP 12.1 (Nougat 7.1 version)). Ehm, make it 2 cell phones (2nd = Huawei P8 lite 6.0 stock). Seems like you guys hit the spot this time!
I discovered that only the message subject is shown, not the message text itself. Also, a time stamp would be nice, especially since my tablet will show the notification after it wakes up and makes the LAN connection. Than it seems that the event just happened, although it can be hours later.
Bug report:
My OTGW adds a "Tapwater DHW Setpoint" device. At the moment it is set on the thermostat at 47'C. However, the app max. setting is only 30'C, probably based on room temperature scale. Without touching it, it will stay on 47, but I can't move it up to 60'C (something I do when the solar boiler isn't able to get the temperature above 60'C anymore on a regular base in the fall/winter)
Posted: Wednesday 16 November 2016 12:05
by galadril
Just brainstorming.. would this be handy?
https://github.com/domoticz/domoticz-android/issues/385
For people that have Android Auto in their car...
Allow to control domoticz via their car system..
Posted: Saturday 19 November 2016 2:55
by EDsteve
Hey,
Is it normal that widgets only working when the app is running?
If I want to turn on my lights via widget switch for example. The domoticz app has to be running in the background. Otherwise the switch has no function.
The domoticz app does not stay open. So the widgets are kind of useless with this behavior.
Is that only on my phone?
Posted: Saturday 19 November 2016 9:39
by strixx
jake wrote:@strixx, your feature request is an existing option in the Domoticz app notifications settings
Tanks! Found the setting and the logg.
Posted: Saturday 19 November 2016 9:53
by strixx
galadril wrote:strixx wrote:So therefor I am suggesting a new feature. And that is a log in the app for all notifications received.
Good idea, the next beta contains a screen under settings, with the last 20 received notifications.
Thank you!
Tanx to @jake I found the setting for "Overwriting notifications" which helped a lot. And also found a small log. "Last Notifications".
So at the moment I guess the only improvement for me would be a easier way to access the log of incoming notifications. IE to have it directly in the menu and not under a sub menu to setting.
The reason I would like to have a quick overview of notifications is that I control Domiticz only from the app. Only time I use the web interface is when scripting or setting up new hardware. And i have a lot of scripts checking that sensors is working for example and alarm levels of sensors. I also use Domticz as my home alarm system. And all of these scripts is sending notifications to the app. IE when a security sensor not has been seen for 60 minutes it sends a notification, and then a new when it is seen again. When the temperature in my freezer is to high i get a notification, and then a new when the temperature is within range again, and so on. By having a easy access chronological log of notifications I would be able to quickly see if some sensors are out of order.
Posted: Saturday 19 November 2016 18:14
by Pjedr
Selecting wear adjusted list is working again
, after I fixed a
negative Humidity % to a positive value.
Also I had
negative temperatures fixed.
So the fault is in my own lua scripting, where I use Unix Time.
I learned that midnight is the beginning of the day (I thought it was at the end).
It is 86400 seconds earlier.
Posted: Tuesday 22 November 2016 8:14
by galadril
Pjedr wrote:Hello,
, after I fixed a
Also I had
Great to know!
Posted: Friday 25 November 2016 10:45
by EDsteve
Hey,
Do widgets work on your android devices when the Domoticz app is not open?
I have to open the Domoticz app every time in order to make widgets work.
Thx
Ed
Posted: Friday 25 November 2016 10:59
by emme
EDsteve wrote:Hey,
Thx
Ed
mee too... geofencing also affected by this issue
Re: RE: Re: Domoticz app 2.0
Posted: Sunday 27 November 2016 12:52
by twaddle
fergalom wrote:fergalom wrote:Don't think so but did Settings>Apps->Chrome->Clear Defaults and same result.
If I look at Settings>Apps->Domoticz - App links->Supported URLs and Supported Web addresses is blank?
It won't let me edit them however.
Any thoughts on this galadril, would like to get this solved
Sent from my SM-G930F using Tapatalk
Is this Solved?
I am using a Samsung S5 with android 6.01
Posted: Tuesday 29 November 2016 21:44
by duckhead
Leaving the switch page open do not reflect the actual states of my switches, if they are controlled through Another domoticz instance (web for example). Would it be possible that your (awsome) Domoticz app updates the device states once in a while? BR
Posted: Thursday 01 December 2016 18:34
by Smartie
Hello Everybody,
i have the problem thats all scenes that i add to the Rooms not shown at the app.
At the Browser are all Rooms Perfect but at the app they shown not the Szenes from the Plans.
Posted: Sunday 04 December 2016 17:09
by Domouser66
Hello I am new here but i follow the forum for a long time.
I have a problem with the android app.
I paid for the app but when i for example chose for geofencing it says that this is an premium function.
Is there an way to solve this.
For the rest I am a verry happy user
Posted: Sunday 04 December 2016 23:02
by tequila
emme wrote:EDsteve wrote:Hey,
Thx
Ed
I am also having issues with the widgets. Voice command does not work unless I have the app opened.
Re: RE: Re: RE: Re: Domoticz app 2.0
Posted: Monday 05 December 2016 14:50
by jjnj
tequila wrote:emme wrote:EDsteve wrote:Hey,
Thx
Ed
I'm afraid this all has to do with Doze. What kind of Android versions are you using?
Posted: Monday 05 December 2016 17:39
by tequila
Android 5.0.2
And not having issues with other widgets by the way.
Posted: Wednesday 07 December 2016 12:06
by Justintime
Is it possible to create a microphone widget for the app in a next version?
And there is a grammar fault in Dutch. "geadvanceerd" instead of "geavanceerd"
Posted: Thursday 08 December 2016 7:28
by Rolo
Hi, a question about the domiticz app for android :
Is there a reason why values are rounded down when placed on the app dashboard ? For example a thermometer, shows 19.5 C in the Temerature section but on the dasboard it shows 19 (without a C).
Would be nice if the sensor showed the real info on the dashboard.
Thanks.
Posted: Friday 09 December 2016 10:03
by galadril
Did you install the app via the google play store?
Posted: Friday 09 December 2016 10:06
by galadril
Rolo wrote:Is there a reason why values are rounded down when placed on the app dashboard ? For example a thermometer, shows 19.5 C in the Temerature section but on the dasboard it shows 19 (without a C).
No thats not intended, ill look into this
