Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations https://forum.domoticz.com/
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Saturday 22 April 2017 19:47
by madrian
Jonb wrote:
robgeerts wrote:
madrian wrote:About slides in Dashticz:
Why not? I tried out:
With HW acceleration enabled the sliding animation is much smoother, but there is a little graphical glitch at the end (the flashing).
But this superslide project is very old and is not maintanced anymore, isn't there a better option? Like Swiper or any other project.
Thanks, will look into this!
You can change it to Fade instead of Slide function. I did it myself and it has a superb result! 100% smoothly and looks better too!
1. edit your jquery.superslides.js
2. find animation:"slide"
3. change to animation:"fade"
4. done (I'm sure you will like it)
You also can change the speed if you want, for me the standard speed value is great.
Nice solution, but you don't need to change jquery.superslides.js.
This is a virtual switch. If I name it 'Thuis' it gives 'aanwezig' as status. If I leave it, obviously it gets the Domoticz name. In my case 'VirtualPresence'.
The first is the prevered state. But , I it does not show the set icon in that case (see screenshot). Should this be a custom image instead of the font awesome one?
Thx
Ralph
Posted: Saturday 22 April 2017 20:16
by htilburgs
I have blinds as type and the stop button is working.
Ok, I believe you
With the option to 'remove' the STOP button, both are happy.
I'm interested, Type RFY, RFY, Blinds, which hardware is this?
Posted: Saturday 22 April 2017 20:17
by mvveelen
Is it possible to implement the security panel?
When I add it now, it shows only "off", and I can't switch it on (using a code). Maybe a Dashticz-v2-style pop-up or something ?
Posted: Saturday 22 April 2017 20:19
by sonar
This is how Somfy protocol is called in Domoticz
Posted: Saturday 22 April 2017 20:24
by madrian
Please add this information to the Wiki, it's missing. +add info that graph_IDX === IDX is the actual IDX of the device. I searched for graph_IDX, but I then found that IDX is for device. Thanks.
//There is a bug with this graph with temp+hum+baro (or other multi output device), but we can fix this later if someone going to use it. Priority: low.
Thx
Ralph
This is some custom code Rob has put in main.js for me. Maybe it's better that he removes this part because we have custom.js now.
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Saturday 22 April 2017 20:25
by robgeerts
Thx
Ralph
Well, i had one exception for another user wich had a switch named Thuis. Will change this!
Posted: Saturday 22 April 2017 20:26
by robgeerts
mvveelen wrote:Is it possible to implement the security panel?
Will look into this. Only problem is that I dont have a security panel to test this..
Posted: Saturday 22 April 2017 20:28
by SwordFish
That's right
by madrian
I just bought an Envisalink module for my DSC alarm, but I am going to use simple buttons to control my alarm. Arm/Disarm/Bypass zones.
Posted: Saturday 22 April 2017 20:29
by htilburgs
I'm looking, but no Somfy in hardware setup.
Thx
Ralph
Maybe it was my question, if you remove this, how can i put it back in the custom.css
Posted: Saturday 22 April 2017 20:53
by htilburgs
madrian wrote:Please add this information to the Wiki, it's missing. +add info that graph_IDX === IDX is the actual IDX of the device. I searched for graph_IDX, but I then found that IDX is for device. Thanks.
Maybe I don't see it, but what information has to be added to the Wiki??
ps. You have also the possibility to add it yourself That's the nuce thing about the wiki Feel free and give it a try.
Posted: Saturday 22 April 2017 21:02
by HansieNL
Some pictures I use...
This swiping is works much better than current solution, but I don't know if Rob can change to this plugin.
Swiper is includes in the latest version!!
You were right, this works better, will push it within an hour.
Posted: Saturday 22 April 2017 21:20
by mvveelen
Oh, but I mean the security panel from Domoticz. When you click on the 'security panel switch', it shows a page with the security panel.
Other question:
It seems the nzbget and the traffic add-ons are deleted? In the older versions I see some settings for this, but no documentation for it for the v2. Is that right?
