Locked
madrian
Re: Dashticz v2.0, custom positioning and multiple screens
Post by madrian »
Jonb wrote:
robgeerts wrote:
madrian wrote:About slides in Dashticz:
Why not? I tried out:
With HW acceleration enabled the sliding animation is much smoother, but there is a little graphical glitch at the end (the flashing).
But this superslide project is very old and is not maintanced anymore, isn't there a better option? Like Swiper or any other project.
Thanks, will look into this!
You can change it to Fade instead of Slide function. I did it myself and it has a superb result! 100% smoothly and looks better too!
1. edit your jquery.superslides.js
2. find animation:"slide"
3. change to animation:"fade"
4. done (I'm sure you will like it)
You also can change the speed if you want, for me the standard speed value is great.
Nice solution, but you don't need to change jquery.superslides.js.
In main.js line 105, find:
$slides.superslides({
hashchange: true/*,
animation: 'fade'*/
and remove comments. I tried with/without jquery.superslides.js, I have not seeing any difference with fade animation.
+the best would be if slide animation followed your finger while sliding, like in native applications.
Swiper example:
http://idangero.us/swiper/demos/02-responsive.html
This swiping is works much better than current solution, but I don't know if Rob can change to this plugin.
rbisschops
Domoticz version: 2.2563
Post by rbisschops »
Hi @robgeerts
Another strange one (bug?):
    blocks[136] = {}
    blocks[136]['width'] = 6;
    blocks[136]['title']  = 'Thuis'
    blocks[136]['icon']   = 'fa-home'
This is a virtual switch. If I name it 'Thuis' it gives 'aanwezig' as status. If I leave it, obviously it gets the Domoticz name. In my case 'VirtualPresence'.
The first is the prevered state. But , I it does not show the set icon in that case (see screenshot). Should this be a custom image instead of the font awesome one?
Thx
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
htilburgs
Post by htilburgs »
I have blinds as type and the stop button is working.
Ok, I believe you ;)
With the option to 'remove' the STOP button, both are happy.
I'm interested, Type RFY, RFY, Blinds, which hardware is this?
Hardware:
mvveelen
Post by mvveelen »
Is it possible to implement the security panel?
When I add it now, it shows only "off", and I can't switch it on (using a code). Maybe a Dashticz-v2-style pop-up or something :) ?
sonar
Domoticz version: 3.8153
Post by sonar »
This is how Somfy protocol is called in Domoticz
madrian
Post by madrian »
Please add this information to the Wiki, it's missing. +add info that graph_IDX === IDX is the actual IDX of the device. I searched for graph_IDX, but I then found that IDX is for device. Thanks. ;)
//There is a bug with this graph with temp+hum+baro (or other multi output device), but we can fix this later if someone going to use it. Priority: low.
HansieNL
Post by HansieNL »
rbisschops wrote:Hi @robgeerts
    blocks[136] = {}
Thx
Ralph
This is some custom code Rob has put in main.js for me. Maybe it's better that he removes this part because we have custom.js now.
Blah blah blah
robgeerts
Domoticz version: 3.7067
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
hashchange: true/*,
animation: 'fade'*/
Swiper example:
Yes, i can!
robgeerts
Post by robgeerts »
    blocks[136] = {}
Thx
Ralph
Well, i had one exception for another user wich had a switch named Thuis. Will change this!
robgeerts
Post by robgeerts »
mvveelen wrote:Is it possible to implement the security panel?
Will look into this. Only problem is that I dont have a security panel to test this.. ;)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
That's right :P
madrian
Post by madrian »
I just bought an Envisalink module for my DSC alarm, but I am going to use simple buttons to control my alarm. Arm/Disarm/Bypass zones.
htilburgs
Post by htilburgs »
I'm looking, but no Somfy in hardware setup. :shock:
Hardware:
gielie
Domoticz version: latest β
Post by gielie »
    blocks[136] = {}
Thx
Ralph
Maybe it was my question, if you remove this, how can i put it back in the custom.css
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
SwordFish
Post by SwordFish »
It's not under hardware. You have to add a switch manual.
See this post https://www.domoticz.com/forum/viewtopic.php?t=2567
htilburgs
Post by htilburgs »
SwordFish wrote:It's not under hardware. You have to add a switch manual.
Thanx for the information. Back to Dashticz ;)
Hardware:
htilburgs
Post by htilburgs »
madrian wrote:Please add this information to the Wiki, it's missing. +add info that graph_IDX === IDX is the actual IDX of the device. I searched for graph_IDX, but I then found that IDX is for device. Thanks. ;)
Maybe I don't see it, but what information has to be added to the Wiki??
ps. You have also the possibility to add it yourself ;) That's the nuce thing about the wiki Feel free and give it a try.
Hardware:
HansieNL
Post by HansieNL »
Some pictures I use...
Blah blah blah
robgeerts
Post by robgeerts »
madrian wrote: Swiper example:
Swiper is includes in the latest version!!
You were right, this works better, will push it within an hour.
mvveelen
Post by mvveelen »
Oh, but I mean the security panel from Domoticz. When you click on the 'security panel switch', it shows a page with the security panel.
Other question:
It seems the nzbget and the traffic add-ons are deleted? In the older versions I see some settings for this, but no documentation for it for the v2. Is that right?
Locked
