Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations https://forum.domoticz.com/
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Saturday 22 April 2017 14:38
by madrian
Manual merge request:
main.js, line 299/300
// $('#npTitle').fadeIn('slow');
// audio.pause();
Please enable audio.pause();
iOS Safari is having a bug, and because of this it won't load next station when you click on next. So you must press on pause button then again play button to play the actual station.
audio.pause(); stops current station when you click prev/next button and fixes the problem above and beside of this I think this is the correct behavior (not everybody want's to listen all station while switching).
Gratis question: is the station title changed in the last versions? It's now smaller.
Posted: Saturday 22 April 2017 14:47
by htilburgs
mvveelen wrote:Tried to get the newsfeed from Telegraaf.nl (http://feeds.feedburner.com/telegraaf/RiEs) but if I replace the Tweakers.net URL with the Telegraaf URL, the block disappears. Something wrong with the way I tried it?
PLEASE DO NOT USE THE PROXY ON A PRODUCTION SITE.
I cannot guarantee the stability of the service, and you will probably experience service interruptions.
Posted: Saturday 22 April 2017 15:58
by wizjos
EdKo66 wrote:Will I make this in the tab setup/More Option/User Variables?. If so, I get an err[rror]
Indeed, you need to do it that way. I wonder what causes the error then
Does this explain a bit more? BTW. The value of the variable is not really important when creating...
Same goes for MoonphaseCheck. That's a string variable as well.
Can you explain where the error occurs?
Wizjos
Posted: Saturday 22 April 2017 16:08
by EdwinK
I think that was the problem, indeed. Didn't know what to enter, tried it with and without anything in it. I used 'integer'. Now it seems to work.
Awaiting the update to really use it
04-22 16:12:00.461 LUA: script bin_selector executed
2017-04-22 16:12:00.504 LUA: MoonPhase - Update not allowed: Difference is 73 seconds
2017-04-22 16:13:00.192 LUA: script bin_selector executed
2017-04-22 16:13:00.201 LUA: MoonPhase - Update not allowed: Difference is 133 seconds
Posted: Saturday 22 April 2017 16:20
by madrian
About slides in Dashticz:
Hardware Acceleration
Superslides is compatible with the jQuery Animate Enhanced plugin. Simply include it before this plugin and it will automatically smooth out transitions using CSS instead of JavaScript.
Why not? I tried out:
With HW acceleration enabled the sliding animation is much smoother, but there is a little graphical glitch at the end (the flashing).
But this superslide project is very old and is not maintanced anymore, isn't there a better option? Like Swiper or any other project.
Posted: Saturday 22 April 2017 16:21
by htilburgs
@Robgeerts,
I still have the issue with the blinds and showing the STOP button. For that I've consulted the manuals from Fibaro and Qubino. There are 3 main types, which are defined in Domoticz:
Blinds (normal up - down)
Blinds percentage (up - down & percentage up/down)
Venetian blinds EU (In dutch: jaloezieën - EU Variant)
Furthermore there a several derivatives from the 3 main types:
Venetian blinds US (In dutch: jaloezieën - US Variant)
Only the Venetian blinds have the ability for the STOP function. For the blinds and blinds percentage the STOP button is not working (correct). The only thing that happens is no STOP, but a revert action (if going Open than Close / Close than Open).
I made an inventory of types, so maybe it's possible to make a correction?
Posted: Saturday 22 April 2017 16:22
by wizjos
EdKo66 wrote:I think that was the problem, indeed. Didn't know what to enter, tried it with and without anything in it. I used 'integer'. Now it seems to work.
Cool! I expect it to be working smoothly now... Let's await @robgeerts' new update
BTW You can set the interval a bit lower for one time only. I don't think Wunderground will charge you for it
Edited my initial post with the remark about the uservars both being 'text'...
Wizjos
Posted: Saturday 22 April 2017 17:15
by robgeerts
htilburgs wrote:@Robgeerts,
Well, I made an option to hide the stop button in latest version (coming tonight) ...
Can anyone confirm that ONLY venetian blinds have a stop button? I thought someone posted he needed the stop button with regular blinds...
by robgeerts
madrian wrote:About slides in Dashticz:
Thanks, will look into this!
Posted: Saturday 22 April 2017 17:22
by rbisschops
madrian wrote:Rob, do you know what causes this? Can we except a bugfix?
+I think whole bug reporting would be easier to follow if you migrate the project to GitHub and we can use GitHub's Issues page.
I agree with @madrian GitHub would be so much easier (also for forking this great project )
Also it is maybe good to start a stable (master) and and a beta (development) branche when moving to GitHub anyway. That way you can keep a lower pace on the stable releases based on wider tested beta's. Saving you a lot of bug reports I guess .
Another suggestion I would like to make is to have all the customised code (so custom.css, custom.js and config.js and potentially more in the future) in a separate directory that remains untouched in case of an update. It is now so easy to overwrite the custom files with an update .
Thx
Ralph
Posted: Saturday 22 April 2017 17:27
by robgeerts
Posted: Saturday 22 April 2017 17:33
by SwordFish
I have blinds as type and the stop button is working.
Posted: Saturday 22 April 2017 17:38
by EdwinK
2017-04-22 17:26:00.433 Error: EventSystem: in Moon: [string "-- Variables to customize..."]:59: attempt to concatenate global 'moonriseMinute' (a nil value)
Not quite
Will forward it if they do
Posted: Saturday 22 April 2017 17:45
by SwordFish
Posted: Saturday 22 April 2017 18:36
by rbisschops
I have tried with KAKU, stop is not working for this type.
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Saturday 22 April 2017 19:03
by robgeerts
Not quite
Is your tempfile writable?
I had the same problem..
Posted: Saturday 22 April 2017 19:13
by EdwinK
I think it is. chmod 777, not sure though how to make sure. It could be that the path isn't correct.
This is my path to the tmp file: ../volume1/web/tmp/Moon.tmp
Posted: Saturday 22 April 2017 19:22
by Jonb
You can change it to Fade instead of Slide function. I did it myself and it has a superb result! 100% smoothly and looks better too!
1. edit your jquery.superslides.js
2. find animation:"slide"
3. change to animation:"fade"
4. done (I'm sure you will like it)
You also can change the speed if you want, for me the standard speed value is great.
