Re: Domoticz app 2.0
Posted: Tuesday 13 September 2016 16:01
On your galaxy s7 for you fingerprint works ok ?
I don't have the beta app so no option to use fingerprint and try itpiokuc wrote:On your galaxy s7 for you fingerprint works ok ?
mcduarte2000 wrote:I did it also, as URL It opens chrome and says "Not Found" "The requested URL /app was not found on this server." As a text it says "New tag collected" "http://www.domoticz.com/app".galadril wrote:Please check my comment here:mcduarte2000 wrote:How can we make the NFC tags to work?
I can add an NFC tag, I can associate Domoticz app with a switch, the phone recognizes the tag, but no visible action...
The phone just says "New tag collected"...
Update 1: If I write "nl.hnogames.domoticz.premium", I can start the app automatically. Still no action besides that...
viewtopic.php?f=37&t=8884&start=1040#p89135
My Android is 6.0.1. Maybe related with it?
Hi, Sorry if it was not clear on how to configure NFC tags. I've now made a wiki page on github to describe the NFC setup:fergalom wrote: Has anyone got the NFC feature to work on Android 6? (I have a stock S7)
I think you've probably selected Chrome as the default app to open URL NFC tagsfergalom wrote:Thanks but had tried both text and url types before.
Installed the NFC app you used to write to the tag, same result
Still opens a webpage and Error 404 - Domoticz app does not pick it up and toggle the switch.
My tag is a standard NXP Mifare Ultralight
I have the same problem/question. I can see the Lite version , but with the note 'Je apparaat is niet compatibel met deze versie'.wergeld wrote:What happened with the tablet support for Nexus 7 (2012)?
No clue at this moment why Nexus 7 is not shown as compatibleSweetPants wrote:I have the same problem/question. I can see the Lite version , but with the note 'Je apparaat is niet compatibel met deze versie'.wergeld wrote:What happened with the tablet support for Nexus 7 (2012)?
I run Android 4.4.4 on this Nexus 7 because Lolipop makes the tablet very slow. However, on my HTC Desire 610 that runs Android 4.4.2 Domoticz Lite and Premium works fine. What is the problem here? Would it run if I upgrade the tablet to Lolipop?
I don't think that upgrade to lollipop will make a difference. Mine is running 5.1.1 and i get the same message from google play store.SweetPants wrote:I have the same problem/question. I can see the Lite version , but with the note 'Je apparaat is niet compatibel met deze versie'.wergeld wrote:What happened with the tablet support for Nexus 7 (2012)?
What am I looking for? I'm not an Android app programmergaladril wrote:If anyone likes to assist on this... you can check the manifest on github ..
https://github.com/domoticz/domoticz-an ... evelopment
Any thoughts on this galadril, would like to get this solvedfergalom wrote:Don't think so but did Settings>Apps->Chrome->Clear Defaults and same result.
If I look at Settings>Apps->Domoticz - App links->Supported URLs and Supported Web addresses is blank?
It won't let me edit them however.
No not yet.. I've tested this on multiple devices.. all work (nexus 5, 6, 5x.. android 5 and 7)fergalom wrote:Any thoughts on this galadril, would like to get this solved
I was able to get the source code from Github build to an .apk using Android Studio, and guess what, I can install the Lite version on the Nexus 7 (2012) tablet using the manifest in the source code. When installing Lite version from Play Store, same problem 'Je apparaat is niet compatible met deze versie'. When i try to build the Paid version, i get a (paid) .apk, get it installed, but it starts in Lite mode and I can't upgrade (same error)SweetPants wrote:What am I looking for? I'm not an Android app programmergaladril wrote:If anyone likes to assist on this... you can check the manifest on github ..
