ELV Max! Heating control system
jesperlykke
Re: ELV Max! Heating control system
Post by jesperlykke »
Hi here :D
I have been following this thread intense, but never got to give it a real try.
I am a bit of a Linux guy, as i have been using it for years, on mine laptop's at home. - So i understand most of the stuff written here...
I got 4 termostat+ 1 ecoswitch and 1 windowswitch, and ofcause the MAX!Cube running in our house.
But as there are a lot of threads, and solutions i am looking for a howto (wiki), for installing it from scratch (including downloading the maxbuddy files)
Does anyone here, have a working uptodate wiki?
I am having a full blown RPI setup for some home automation, allready running Domoticz.
Best rgds; Jesper
1970sITman
Post by 1970sITman »
Folks,
Anyone seen the problem that's developed with Max!buddy since the start of 2016 where you cannot set the "Holiday mode" function?
What happens is that the date shows as, for example, 19-Jan-0001 as opposed to 19-Jan-2016. It stays like that for a minute or two, then reverts back.
I did have a similar issue setting the Holiday Mode using the MAX! web front end and reported that to [email protected].
Amazingly............it looks like they fixed the issue quite quickly on the web front end by releasing a new version of the software - it's now 1.4.5
Now that the web front end is fixed, If I set the holiday mode using the MAX! front end, and then restart Max!buddy, that seems to work ok
However, there is either still an issue with the Cube firmware ( how is that updated?? ) or with Max!buddy preventing me from setting the holiday mode directly from Max!buddy
Anyone else?
Steve
4 pi(master+RFXtrx433 and 3 slaves+PiFace)
HE, BBSB, Lightwave, Micromark, Retrotouch & LIVOLO sockets, door switches, PIRs & Dimmers
EVE on iPad for Voice
Weather sensors
OWL CM160
eQ-3 MAX! Heating Controls (10 therms, 8 valves, 2 relays)
blackdog65
Post by blackdog65 »
Yesterday I decided to blow the dust off my ELV MAX! equipment and try again.
I dicovered :-
1) no way will it install how I want on a cubietruck... bummer! :cry:
2) Installed ok on a slave RasPi2... but virtual slave devices will not show on master device... double bummer! :cry: :cry:
3) I am way too stupid to be able to write a script to transfer the info from raspi/slave to cubie/master... TRIPLE BUMMER! :cry: :cry: :cry:
3) If I change the IP and HID in Domoticz.js from the slave info to the cubietruck info... IT WORKS! :ugeek: I AM AN I.T. GOD!!! :ugeek:
Ah... now for a lay down and wait for the pills to kick in... :lol: ;)
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
Just a quick survey...
which trv are you all using?
A)http://www.conrad-electronic.co.uk/ce/e ... view1&rb=1
B)http://www.conrad-electronic.co.uk/ce/e ... view1&rb=1
C)http://www.conrad-electronic.co.uk/ce/e ... view1&rb=1
I have B but is there any reason why A would not work? and what does C do for an extra fiver? :lol:
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Westcott
Post by Westcott »
I've got a B that I'd like to control from Domoticz.
blackdog65
do you have the cube too? without the cube, domoticz can't see it
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
@10gic
Hi Kevin,
I have your script installed ( viewtopic.php?f=34&t=841&start=60#p38160) and so far it's working fine. Many thanks! :D
My previous set up had a master on/off switch for heating which had timers. What would you advise as the quickest easiest way to add in a virtual switch. I've been looking at adding in several "and X switch = on" (or off) conditions to the "-- Perform logic" section but there is probably a much simpler and/or elegant method... any thoughts?
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
Has anyone seen this?
https://github.com/Bouni/max-cube-protocol
I wish I was a programmer as there appears to be enough information here to do everything we'd like.
Imagine that... a cheap, reliable heating control for domoticz :o
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
mvzut
Post by mvzut »
OK, received my ELV Max! set two days ago (two radiator thermostats "type A", two wall thermostats, one Cube), and followed the "Wiki" on page 2 of this thread. Bummer, it didn't work! I could see in the log that it found my Cube and the data was received correctly, but it didn't result in the creation of devices in Domoticz.
After a lot of debugging with my limited programming skills, I found out that the problem was in the Domoticz.js script. The line
if(device.getDeviceType() == 'WallMountedThermostat') {
(and the two similar if statements later in the script) were never true, so the code below it was never executed. This is because, apparently, device.getDeviceType() is not a string. So what I simply did was change these lines into
if(toString(device.getDeviceType()) == 'WallMountedThermostat') {
And it worked!
I followed the exact guideline, with one difference: I installed Java (openjdk) version 8 instead of version 7. Could this have caused the different behaviour?
Maybe others who have problems getting things to work are helped by this fix as well!
P.S. At first I also didn't get the last part working: starting the script in the background at startup. It didn't understand the "&& screen" part. I slightly changed the headless.sh script in ~/maxbuddy into:
#!/bin/bash
cd /home/pi/maxbuddy
java -cp "launcher.jar:./lib/*" org.fenwulf.maxbuddy.launcher.Launcher -headless
and then I changed the line in crontab into
@reboot sh /home/pi/maxbuddy/headless.sh > /dev/null 2>&1
Now it works like a charm
l0gic
Domoticz version: Latest
Post by l0gic »
blackdog65 wrote:@10gic
Hi Kevin,
Sean
Hi Sean,
Sorry I've only just seen this, I'm Bali at the moment so not focused on forums :)
I just made a dummy switch of type x10 as I don't have any x10 equipment in my systems.
If you are using x10 just use spare address to prevent clashes with what you have.
I'd love to be able to ditch the max buddy as I'm finding that it loses contact with the cube every now and again, so it is becoming unreliable.
I can't run max buddy alongside the duck DNS client as max buddy dies with the client running which s a bummer.
All the best
Kevin
Non credus crepitus
blackdog65
Hiya Kevin,
Sorry to disturb you in sunny Bali :mrgreen:
I think I mislead you; I meant how to add it into the script. I've actually done it now but it overrides the minvalves part... an emergency fix at 1am :shock:
Other than that, I now have a multi-position switch with "Off-Hot Water-Heating-Away" working sweetly, more valves on order and a happy Mrs.! :lol:
Enjoy your hols :D
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
l0gic
Post by l0gic »
Hi Sean,
my mistake - sorry.
Just had a quick look and if I understand your requirements correctly then adding another "if" line should do it.
 if (otherdevices['On Holiday'] == 'Off')then -- Not on holiday
       if (otherdevices['Heating Required'] == 'On')then -- It's time to heat the house <<--- New line DON'T FORGET TO CLOSE WITH AN 'END'
         if (otherdevices['Boiler On (B1)'] == 'Off') then --If a minimum of 'MinValves' valves are on by more that pre-set value BoilerOnPercent
I have assumed you set the timing control via the dummy switch called Heating Required in this case.
HTH
Kevin
Non credus crepitus
blackdog65
mvzut wrote: P.S. At first I also didn't get the last part working: starting the script in the background at startup. It didn't understand the "&& screen" part. I slightly changed the headless.sh script in ~/maxbuddy into:
#!/bin/bash
Yeah, I had that too. It turns out that screen is an app that needs to be installed 1st. Worked fine after.
@l0gic
Worked like a charm...ish :? I got about 2000 emails for missing device yesterday :o :shock: but that seems to have stopped... phew! Many thanks!
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
mvzut
Post by mvzut »
blackdog65 wrote:Yeah, I had that too. It turns out that screen is an app that needs to be installed 1st. Worked fine after.
Hmmm, interesting. This "screen" application makes the script run in a separate terminal session that you can always open when desired. Nevertheless, I don't think I really need that, it's fine if it just runs in the background and sends its output to /dev/null. In case of doubt, you can always check the log in ~/.maxbuddy/logs/
blackdog65
I took a risk this week and bought 2 of the slightly cheaper "MAX! Radiator Thermostat Basic"
Well done me! They work exactly the same as the others, look better and sound quieter... WOOHOO! :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
DomotRikz
Post by DomotRikz »
Is there also a way to let Domoticz control the set temperatures of the Max! system? As I understand it correctly, Domoticz now only can read the data in order to display it or to control the central heating system.
blackdog65
Hiya,
DomotRikz wrote:Is there also a way to let Domoticz control the set temperatures of the Max! system? As I understand it correctly, Domoticz now only can read the data in order to display it or to control the central heating system.
Quite true as things stand, but in this link https://github.com/Bouni/max-cube-protocol I believe there may be enough information for a programmer (I'm not!) to control a stat via lua/python or similar. If so, ELV Max! becomes something of a dream solution for Domoticz users :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Meza
Post by Meza »
Ordered a Cube, thermostats, Eco switch, window contacts and a whole load of basic TRVs from elv.de recently. Looking forward to receiving them and setting it up, but will first have to replace 8 standard rad valves with TRV bodies. Got a strange mix of 10mm and 8mm pipe in my system so may have a little difficulty to find bodies which fit the MAX! heads.
Any recommendations for manufacturers of bodies which fit the heads without needing adapter rings?
Sent from my PLK-L01 using Tapatalk
l0gic
Post by l0gic »
Guys,
been looking through the links that BlackDog put up regarding the Max protocols.
caviat - I am not a coder by any stretch of the imagination but, I fancy having a go at replacing my MaxBuddy with something newer.
I can faff around in Visual Studio and knock up the odd simple VB application but that will only be of use for Windows users.
I've had a quick look at C++ and it looks a fearsome mountain for me to climb.
But I assume using C++ will allow for cross compiling of the app to non windows environment.
Quick question, MaxBuddy runs with a GUI in Windows, how does it present when you run it on the Pi for example?
I could be selfish and knock up something for Windows or I could dive in deep and do something that could potentially hit all requirements.
So, what are you currently running MaxBuddy on?
Feedback and other thoughts please.
cheers
Kevin
Non credus crepitus
