Page 7 of 8
Re: Gigaset Elements Cli - domoticz support
Posted: Tuesday 06 June 2017 9:27
by bfauquet
dynasticorpheus wrote:bfauquet wrote:dynasticorpheus wrote:
The 500 error is most likely on server (gigaset elements) side so I advise to use the --restart option. The 401 error is not showing in my logs so I suspect the DEV version wil solve this as this more often does the required re-authentication more often.
How do you install the dev version on an existing version ?
See OP but in short: (if needed run last step as admin)
git clone -b develop git://github.com/dynasticorpheus/gigasetelements-cli.git
cd gigasetelements-cli
python setup.py install --force
After update, I have the following error when running : gigasetelements-cli -c /home/pi/gigasetelements-cli/gigasetelements-cli.conf -tt
[-] Status | GREEN | Modus set from HOME to HOME
[-] Notification | TOKEN |
[-] Domoticz mode | STARTED | CTRL+C to exit
File "/usr/local/bin/gigasetelements-cli", line 9, in <module>
load_entry_point('gigasetelements-cli==1.5.0b3', 'console_scripts', 'gigasetelements-cli')()
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 779, in main
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 763, in base
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 517, in monitor
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 561, in domoticz
IndexError: list index out of range
Posted: Tuesday 06 June 2017 11:15
by dynasticorpheus
Please use the updated config file template and follow it's instruction inside. I believe this error is related to not having step 4 and 5 in place.
Unfortunately there is currently little to no error validation , something I definitely want to improve but not much time to improve current code for now
https://github.com/dynasticorpheus/giga ... f.template
Posted: Friday 07 July 2017 9:36
by bfauquet
Dear all,
I would like to go further with the Gigasetelements-cli.
When approching/leaving home, the alarm is desactivated/activated automatically, but there is a delay between the send command (from Domoticz) and the desactivation/activation of the alarm.
The information I get into the Status, Alart object in Domoticz is "bs01 | isl01.bs01.intrusion_mode_loaded" (from log).
How can we test the status of the Gigasetelements-cli to know exactly the status of the alarm ?
Thanks for answer
Posted: Wednesday 12 July 2017 11:38
by dynasticorpheus
bfauquet wrote:Dear all,
Thanks for answer
If you have setup the domoticz / gigasetelements-cli
dev version as per below instruction the alert and modus selector will sync to the actual status every minute.
Making the selector buttons actually change the status from Domoticz requires below configuration: (this will happen immediately)
viewtopic.php?f=38&t=8404&start=40#p85496
Posted: Wednesday 30 August 2017 10:50
by SonicRiff
@dynasticorpheus can you please contact me in PM ?. I would like to have admin access to my gigaset Camera
Thanks !
Posted: Friday 01 September 2017 13:26
by dynasticorpheus
SonicRiff wrote: Wednesday 30 August 2017 10:50
Thanks !
See PM
Posted: Friday 22 September 2017 20:43
by dsaaltink
If possible I would like to have admin access as well to my gigaset Camera to change it. Thanks and regards.
Posted: Tuesday 26 September 2017 19:56
by dynasticorpheus
dsaaltink wrote: Friday 22 September 2017 20:43
See PM
Posted: Wednesday 25 October 2017 13:13
by BRSS
Hi dynasticorpheus,
I've updated my running version from PIP based to GIT, modified the config file according to the new template but I'm getting this error :
root@OPZ:~/gigaset-elements# gigasetelements-cli -s
Gigaset Elements - Command-line Interface v1.5.0b5
[-] Identity | VERIFIED | User logged in successfully.
[-] Authentication | SUCCESS |
[-] Basestation | ONLINE | xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[-] Status | GREEN | Modus AWAY
load_entry_point('gigasetelements-cli==1.5.0b5', 'console_scripts', 'gigasetelements-cli')()
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 737, in main
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 664, in base
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 274, in collect_hw
KeyError: u'hb01'
Please note that my camera is currently offline (can you send me a PM for admin access
), but it was not an issue for the PIP version of CLI.
Thanks for your help.
Posted: Thursday 26 October 2017 20:34
by dynasticorpheus
BRSS wrote: Wednesday 25 October 2017 13:13
Hi dynasticorpheus,
KeyError: u'hb01'
Should be fixed with commit 86995d9 so can you please do a reinstall after doing a git pull? See PM for admin access to your camera
Posted: Friday 27 October 2017 11:19
by BRSS
Thanks (for cam also).
Just tried, another error raised : KeyError: u'hb01.hl01'
edit: just saw in your code that it's related to Hue bridge. So hl01 must be one of my Hue devices.
edit 2: It's works with this modification.
SENSOR_FRIENDLY = {'ws02': 'window_sensor', 'ps01': 'presence_sensor', 'ps02': 'presence_sensor', 'ds01': 'door_sensor', 'ds02': 'door_sensor',
'is01': 'indoor_siren', 'sp01': 'smart_plug', 'bn01': 'button', 'yc01': 'camera', 'sd01': 'smoke', 'um01': 'umos',
'hb01': 'hue_bridge', 'bs01': 'base_station',
'hb01.hl01': 'hue_device'}
May I suggest you to change this:
# access token to enable pushbullet notifications (optional)
# pbtoken=z9FaKeSCKQDi2cmPUSHB62aiXx5I57eiujTOKENfS34
to this, in
gigasetelements-cli.conf.template
# access token to enable pushbullet notification (optional)
# notify=z9FaKeSCKQDi2cmPUSHB62aiXx5I57eiujTOKENfS34
Regards,
BRSS
Posted: Friday 27 October 2017 16:03
by dynasticorpheus
BRSS wrote: Friday 27 October 2017 11:19
to this, in
Regards,
BRSS
Thanks for your input. I do not own any Hue devices hence cannot test. Also good catch on the pushbullet token template key. Both now corrected and pushed to github.
ps: admin acces to cam successful?
Posted: Friday 27 October 2017 16:27
by BRSS
Your last push works flawlessly, thanks a lot!
Unfortunately, I'm out of home till next week and my cam is offline (unpowered to be exact). I'll test it soon and PM you the result.
Posted: Monday 29 January 2018 19:12
by BRSS
Hi dysnasticorpheus,
Since this morning, the script raise an error : KeyError: u'system_health'.
Outage or API change ?
Posted: Monday 29 January 2018 19:31
by dynasticorpheus
BRSS wrote: Monday 29 January 2018 19:12
Indeed API change but already fixed in latest develop version via commit bcc86e0. Just update and all should be ok again, if not let me know.
Posted: Monday 29 January 2018 20:01
by BRSS
New error (a step further) : KeyError: u'status_msg_id'
Thanks.
Posted: Monday 29 January 2018 20:55
by dynasticorpheus
BRSS wrote: Monday 29 January 2018 20:01
Thanks.
Weird that they change the API without upping the version as well. Anyway should be fixed now, thanks for notifying me.
Posted: Monday 29 January 2018 21:46
by BRSS
Success!
By the way, I've tried "statusmsgid" (following the same pattern as "system_health" to "systemHealth") before asking you. It was "statusMsgId", typo kills me...
Thanks a lot for your work.
Posted: Tuesday 30 January 2018 18:57
by dynasticorpheus
BRSS wrote: Monday 29 January 2018 21:46
Success!
Seems they noticed changing production API's is not a good idea and reversed yesterdays changes
I therefore also reversed the last 2 commits hence you need to update once more
Posted: Tuesday 30 January 2018 19:04
by BRSS
Done.
Thanks, again.
How we can tell Gigaset not to let trainee play with the stuff marked "stable env"?
