Page 7 of 7
Re: RFLink - USB Gateway - Introduction
Posted: Wednesday 15 February 2017 19:41
by Stuntteam
put a piece of wire between arduino mega pin 12 and 13 (the ones close to the usb connector)
reboot rflink, remove wire, reboot rflink again.
then it should work
Posted: Wednesday 15 February 2017 20:24
by Huubke80
Stuntteam wrote:put a piece of wire between arduino mega pin 12 and 13 (the ones close to the usb connector)
then it should work
You are the best, Thnx!! So what I have done resetting the EEPROM?
Posted: Wednesday 15 February 2017 20:37
by Stuntteam
yes, resetting the settings that are stored in eeprom..
r46 will have a better solution
Posted: Saturday 18 March 2017 11:39
by patrickjetten
Since a few day's ago mij RFlink doesn't functioned anymore on mij Synology NAS. In the log I get the report
RFLink: Error opening serial port!
Now I reinstall everything, but i still get this reports.
Can someone help me with it en has someone the same problem?
Posted: Saturday 18 March 2017 11:52
by Stuntteam
Might be a driver issue.. make sure you get the package from
http://www.jadahl.com/
Posted: Thursday 20 April 2017 12:07
by markjgabb
Ok my rflink has arrived I've flashed the latest firmware. With debugging turned on I can see the button presses on my lamp/fan
But when I plug it into demoticz it doesn't learn any of my button presses....
It doesn't even recognise I pressed a button.....am I missing some things?
Posted: Thursday 20 April 2017 12:58
by Stuntteam
See your other post..
Posted: Thursday 20 April 2017 16:32
by phoenixblue
Small question I know I'm maybe not the first one.
But is there already an expected date with an firmware that is compatible with the cc1101?
Posted: Monday 05 June 2017 5:20
by Harald777
Hi guys, I just have build an raspberry pi + rflink gateway set bought from the nodo shop.
The build went smoothly and almost all is working great.
I have a whole bunch of "klikaanklikuit" switches, dimmers and door contacts and 6 flamingo smoke detectors.
All added without any problem to the set which is running on Domoticz.
Just one thing I cannot get it to work.
I used blockly to program an action that when a door contact opens a light must switch on.
Very simple I thought but it won't work.
In the log it shows that domoticz sees that the door contact opens and the command to turn on the light is made but the light does not switch on.
Manual light switching is working fine.
Any tips on such an issue are much appreciated.
Posted: Monday 05 June 2017 10:05
by Koensk
Hi Harold,
Can you post a screenshot of your blocky screen?
Verstuurd vanaf mijn Moto X Play met Tapatalk
Posted: Monday 05 June 2017 16:56
by Harald777
Koensk wrote:Hi Harold,
Tried this blockly with and without the 3 seconds time delay.
Gr Harald
Posted: Monday 05 June 2017 17:12
by DutchHans
Does your sensor say open?.. not Alarm, On or anything.. check the logfile or the actual settings in blockly...
Gr, Hans
Posted: Monday 05 June 2017 17:37
by Harald777
DutchHans wrote:Does your sensor say open?.. not Alarm, On or anything.. check the logfile or the actual settings in blockly...
Gr, Hans
The "Switch Widget" on the switch page shows Open - Close. The log of the switch shows On - Off.
The Domoticz log shows:
2017-06-05 17:30:30.765 (RFLink Gateway) Light/Switch (Voordeur Schakelaar)
2017-06-05 17:30:33.785 2017-06-05 17:30:33.785 RFLink Sending: 10;Kaku;00004c;6;ON
Gr Harald
Posted: Monday 05 June 2017 19:18
by Harald777
Harald777 wrote:DutchHans wrote:Does your sensor say open?.. not Alarm, On or anything.. check the logfile or the actual settings in blockly...
Gr, Hans
Gr Harald
Just discovered that I had selected "contact" instead of "door contact".
Switched to "door contact" and now the blockly function is working but only if I ad a time delay of 3 second for switching on the light.
I have read somewhere that receiving and sending signals at the same time does not properly work.
Thanks for all the responses.
Gr Harald
Posted: Sunday 17 September 2017 18:06
by IanPH
I was wondering if it's possible to have
one Arduino with RFLink firmware and connect both 433 and 868 MHz receiver/transmitter?
I've been scrolling over
http://www.rflink.nl/blog2/wiring but I can't find anything on how to connect 868 MHz modules and what 868 MHz modules are working/recommended while connecting both 443 MHz and 2.4 GHz are very well documented.
Also I was wondering if an Arduino with RFLink firmware R47 and 868 MHz modules is able to control an "Itho Ecofan CVE RFT afzuigunit" which also uses 868 MHz signals.
