RFLink - USB Gateway - Introduction
Stuntteam
Re: RFLink - USB Gateway - Introduction
Post by Stuntteam »
put a piece of wire between arduino mega pin 12 and 13 (the ones close to the usb connector)
reboot rflink, remove wire, reboot rflink again.
then it should work
Huubke80
Domoticz version: 3.6722
Post by Huubke80 »
Stuntteam wrote:put a piece of wire between arduino mega pin 12 and 13 (the ones close to the usb connector)
then it should work
You are the best, Thnx!! So what I have done resetting the EEPROM?
Stuntteam
Post by Stuntteam »
yes, resetting the settings that are stored in eeprom..
r46 will have a better solution
patrickjetten
Post by patrickjetten »
Since a few day's ago mij RFlink doesn't functioned anymore on mij Synology NAS. In the log I get the report
RFLink: Error opening serial port!
Now I reinstall everything, but i still get this reports.
Can someone help me with it en has someone the same problem?
Stuntteam
Post by Stuntteam »
Might be a driver issue.. make sure you get the package from
http://www.jadahl.com/
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
Ok my rflink has arrived I've flashed the latest firmware. With debugging turned on I can see the button presses on my lamp/fan
But when I plug it into demoticz it doesn't learn any of my button presses....
It doesn't even recognise I pressed a button.....am I missing some things?
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
Stuntteam
Post by Stuntteam »
See your other post..
phoenixblue
Post by phoenixblue »
Small question I know I'm maybe not the first one.
But is there already an expected date with an firmware that is compatible with the cc1101?
Harald777
Domoticz version: Latest
Post by Harald777 »
Hi guys, I just have build an raspberry pi + rflink gateway set bought from the nodo shop.
The build went smoothly and almost all is working great.
I have a whole bunch of "klikaanklikuit" switches, dimmers and door contacts and 6 flamingo smoke detectors.
All added without any problem to the set which is running on Domoticz.
Just one thing I cannot get it to work.
I used blockly to program an action that when a door contact opens a light must switch on.
Very simple I thought but it won't work.
In the log it shows that domoticz sees that the door contact opens and the command to turn on the light is made but the light does not switch on.
Manual light switching is working fine.
Any tips on such an issue are much appreciated.
Koensk
Post by Koensk »
Hi Harold,
Can you post a screenshot of your blocky screen?
Verstuurd vanaf mijn Moto X Play met Tapatalk
Harald777
Post by Harald777 »
Koensk wrote:Hi Harold,
Tried this blockly with and without the 3 seconds time delay.
Gr Harald Image
DutchHans
Post by DutchHans »
Does your sensor say open?.. not Alarm, On or anything.. check the logfile or the actual settings in blockly...
Gr, Hans
Harald777
Post by Harald777 »
DutchHans wrote:Does your sensor say open?.. not Alarm, On or anything.. check the logfile or the actual settings in blockly...
Gr, Hans
The "Switch Widget" on the switch page shows Open - Close. The log of the switch shows On - Off.
The Domoticz log shows:
2017-06-05 17:30:30.765 (RFLink Gateway) Light/Switch (Voordeur Schakelaar)
2017-06-05 17:30:33.785 2017-06-05 17:30:33.785 RFLink Sending: 10;Kaku;00004c;6;ON
Gr Harald
Harald777
Post by Harald777 »
Gr, Hans
Gr Harald
Just discovered that I had selected "contact" instead of "door contact".
Switched to "door contact" and now the blockly function is working but only if I ad a time delay of 3 second for switching on the light.
I have read somewhere that receiving and sending signals at the same time does not properly work.
Thanks for all the responses.
Gr Harald
IanPH
Post by IanPH »
I was wondering if it's possible to have one Arduino with RFLink firmware and connect both 433 and 868 MHz receiver/transmitter?
I've been scrolling over http://www.rflink.nl/blog2/wiring but I can't find anything on how to connect 868 MHz modules and what 868 MHz modules are working/recommended while connecting both 443 MHz and 2.4 GHz are very well documented.
Also I was wondering if an Arduino with RFLink firmware R47 and 868 MHz modules is able to control an "Itho Ecofan CVE RFT afzuigunit" which also uses 868 MHz signals.
