Page 7 of 13
Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Saturday 26 November 2016 22:38
by l0gic
Hi Guys,
I think I may have an issue with the installation of the Broadlink code.
When running the learn.py I hit the following issue
  File "./learn.py", line 19, in <module>
    device.enter_learning()
AttributeError: device instance has no attribute 'enter_learning'
I get a similar issue with the playcode.py
  File "./playcode.py", line 30, in <module>
    device.send_data(myhex.decode('hex'))
AttributeError: device instance has no attribute 'send_data'
As I'm having issues with both scripts I'm assuming the issue is with the installation of the broadlink code.
I installed the code using the setup.py install and it seemed to complete without issue.
Any ideas anyone?
Cheers
Kevin
Posted: Sunday 27 November 2016 10:32
by tezzlicious
l0gic wrote:Hi Guys,
Any ideas anyone?
Cheers
Kevin
replace
device = broadlink.device(host=("<your RM3 IP address>",80), mac=bytearray.fromhex("<your RM3 mac>"))
with
device = broadlink.rm(host=("<your RM3 IP address>",80), mac=bytearray.fromhex("<your RM3 mac>"))
Posted: Sunday 27 November 2016 20:20
by l0gic
tezzlicious wrote:
replace
with
Nice one, working well now!
Many thanks
Kevin
Posted: Monday 28 November 2016 19:50
by tuspam
Posted: Monday 28 November 2016 21:11
by tuspam
tezzlicious wrote: replace
with
root@raspberrypi:/home/pi/domoticz/scripts/python# python -V
Python 2.7.3
root@raspberrypi:/home/pi/domoticz/scripts/python# python learn.py
  File "learn.py", line 7, in <module>
ValueError: non-hexadecimal number found in fromhex() arg at position 0
Any instruction noobs frendly how to install and use for python-broadlink?
Thanks a lot.
Posted: Monday 28 November 2016 21:51
by l0gic
Grab the code from github and drop it in a directory on the Pi, I put it in the domoticz area.
There is a file called setup.py, run it as follows "python setup.py install" (no "").
You may find it fails as some dependencies are not available, it did for me.
If so a quick google will set you right, install the required dependencies.
Once the setup.py file runs without error you have installed the code.
HTH
Kevin
Posted: Monday 28 November 2016 21:56
by tuspam
l0gic wrote:Hi,
HTH
Kevin
I did it before
root@raspberrypi:/home/pi/domoticz/scripts# python setup.py install
running install
running bdist_egg
running egg_info
creating broadlink.egg-info
writing broadlink.egg-info/PKG-INFO
writing top-level names to broadlink.egg-info/top_level.txt
writing dependency_links to broadlink.egg-info/dependency_links.txt
writing manifest file 'broadlink.egg-info/SOURCES.txt'
reading manifest file 'broadlink.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/broadlink
copying broadlink/__init__.py -> build/lib.linux-armv7l-2.7/broadlink
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
creating build/bdist.linux-armv7l/egg/broadlink
copying build/lib.linux-armv7l-2.7/broadlink/__init__.py -> build/bdist.linux-armv7l/egg/broadlink
byte-compiling build/bdist.linux-armv7l/egg/broadlink/__init__.py to __init__.pyc
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
creating dist
creating 'dist/broadlink-0.1-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing broadlink-0.1-py2.7.egg
removing '/usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg' (and everything under it)
creating /usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg
Extracting broadlink-0.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
broadlink 0.1 is already the active version in easy-install.pth
Installed /usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg
Processing dependencies for broadlink==0.1
Finished processing dependencies for broadlink==0.1
Dependency file is empty
/usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg/EGG-INFO/dependency_links.txt
Posted: Tuesday 29 November 2016 11:24
by l0gic
your broadlink looks like it has installed fine.
I'm guessing your issue is
You need to replace <your RM3 IP address> with the IP address of the broadlink unit and the same with the mac for <your RM3 mac>.
For the mac, remove the : e.g. aa:bb:cc:dd:ee:ff becomes aabbccddeeff
HTH Kevin
Posted: Tuesday 29 November 2016 15:33
by tuspam
l0gic wrote:Hi,
HTH Kevin
Thx Kevin
Too many choices - any details how exactly?
device = broadlink.rm(host=("<192.168.1.110>",80), mac=bytearray.fromhex("<aabbccddeeff>"))
device = broadlink.rm(host=("192.168.1.110",80), mac=bytearray.fromhex("aabbccddeeff"))
device = broadlink.rm(host=(192.168.1.110,80), mac=bytearray.fromhex(aabbccddeeff))
device = broadlink.rm(host=(192.168.001.110,80), mac=bytearray.fromhex("<aabbccddeeff>"))
etc.
    device = broadlink.rm(host=(192.168.1.110,80), mac=bytearray.fromhex(B4430DEEE880))
SyntaxError: invalid syntax
    device = broadlink.rm(host=(192168001110,80), mac=bytearray.fromhex(b4430deee880))
NameError: name 'b4430deee880' is not defined
Posted: Tuesday 29 November 2016 16:10
by l0gic
device = broadlink.rm(host=("192.168.1.110",80), mac=bytearray.fromhex("B4430DEEE880"))
should do it for you, I've not got access to my Pi ATM so I can't check.
ATB
Kevin
Edit;
just checked and assuming your IP and MAC are correct then the syntax is good to go.
Posted: Tuesday 29 November 2016 16:47
by tuspam
l0gic wrote:Hi,
Bingo - thanks a lot
Edit:
Everything works like a charm with RM2 and RM mini (without android device).
I got about 2 sec delay between click dummy switch on domoticz to RM action. Now i can control Broadlink via HA bridge using google home and amazon dot.
Thanks again.
Posted: Tuesday 29 November 2016 20:57
by noddy119
Did you comment out (insert an # at the beginning of the line) the 'time.sleep' lines in playcode.py ?
Without these lines (for test purposes) the script runs quicker.... :P
Posted: Tuesday 29 November 2016 21:21
by tuspam
About 1 sec delay - awesome
Posted: Saturday 03 December 2016 19:31
by korniza
I bought broadlink black bean.
Searching on web I found this https://github.com/davorf/BlackBeanControl
Does anyone is using any API for this device?
Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Sunday 04 December 2016 10:58
by Justintime
tuspam wrote:
l0gic wrote:Hi,
Edit:
Thanks again.
Just to be clear? The black bean works without interference of an Android device? Or only in combination with the RM2
So who is going to write a wiki? Because the information is not clear how to handle all this.
Posted: Sunday 04 December 2016 18:50
by tuspam
Justintime wrote:
tuspam wrote:
l0gic wrote:Hi,
Edit:
Thanks again.
Yes RM2 and RM mini (black bean) working without android device. I got 2 of them in different rooms.
Ps
In raspberry pi i have installed domoticz, ha-bridge, and python-broadlink - i can control all my devices via voice (Google Home in one room and Alexa in another)
Re: RE: Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Sunday 04 December 2016 19:56
by Justintime
tuspam wrote:
Justintime wrote:
Edit:
Thanks again.
Ps
Thanks... Cool that it works with Alexa etc.
But i am still looking for the Holy grail on IR support in Domoticz.
With one device independent from an Android device.
Posted: Sunday 04 December 2016 21:27
by tuspam
Justintime wrote:......
So, You find one.
Re: RE: Re: RE: Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Sunday 04 December 2016 22:03
by Justintime
So, You find one.
So i just need a rm2 than?
Posted: Monday 05 December 2016 11:19
by tuspam
So, You find one.
YES rm2 or black bean.
