Using BROADLINK RM2 on DOMOTICZ
l0gic
Domoticz version: Latest
Re: Using BROADLINK RM2 on DOMOTICZ
Post by l0gic »
Hi Guys,
I think I may have an issue with the installation of the Broadlink code.
When running the learn.py I hit the following issue
  File "./learn.py", line 19, in <module>
    device.enter_learning()
AttributeError: device instance has no attribute 'enter_learning'
I get a similar issue with the playcode.py
  File "./playcode.py", line 30, in <module>
    device.send_data(myhex.decode('hex'))
AttributeError: device instance has no attribute 'send_data'
As I'm having issues with both scripts I'm assuming the issue is with the installation of the broadlink code.
I installed the code using the setup.py install and it seemed to complete without issue.
Any ideas anyone?
Cheers
Kevin
Non credus crepitus
tezzlicious
Post by tezzlicious »
l0gic wrote:Hi Guys,
Any ideas anyone?
Cheers
Kevin
replace
device = broadlink.device(host=("<your RM3 IP address>",80), mac=bytearray.fromhex("<your RM3 mac>"))
with
device = broadlink.rm(host=("<your RM3 IP address>",80), mac=bytearray.fromhex("<your RM3 mac>"))
l0gic
Post by l0gic »
tezzlicious wrote:
replace
with
Nice one, working well now!
Many thanks
Kevin
Non credus crepitus
tuspam
Post by tuspam »
tuspam
Post by tuspam »
tezzlicious wrote: replace
with
root@raspberrypi:/home/pi/domoticz/scripts/python# python -V
Python 2.7.3
root@raspberrypi:/home/pi/domoticz/scripts/python# python learn.py
  File "learn.py", line 7, in <module>
ValueError: non-hexadecimal number found in fromhex() arg at position 0
Any instruction noobs frendly how to install and use for python-broadlink?
Thanks a lot.
l0gic
Post by l0gic »
Grab the code from github and drop it in a directory on the Pi, I put it in the domoticz area.
There is a file called setup.py, run it as follows "python setup.py install" (no "").
You may find it fails as some dependencies are not available, it did for me.
If so a quick google will set you right, install the required dependencies.
Once the setup.py file runs without error you have installed the code.
HTH
Kevin
Non credus crepitus
tuspam
Post by tuspam »
l0gic wrote:Hi,
HTH
Kevin
I did it before
root@raspberrypi:/home/pi/domoticz/scripts# python setup.py install
running install
running bdist_egg
running egg_info
creating broadlink.egg-info
writing broadlink.egg-info/PKG-INFO
writing top-level names to broadlink.egg-info/top_level.txt
writing dependency_links to broadlink.egg-info/dependency_links.txt
writing manifest file 'broadlink.egg-info/SOURCES.txt'
reading manifest file 'broadlink.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/broadlink
copying broadlink/__init__.py -> build/lib.linux-armv7l-2.7/broadlink
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
creating build/bdist.linux-armv7l/egg/broadlink
copying build/lib.linux-armv7l-2.7/broadlink/__init__.py -> build/bdist.linux-armv7l/egg/broadlink
byte-compiling build/bdist.linux-armv7l/egg/broadlink/__init__.py to __init__.pyc
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying broadlink.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
creating dist
creating 'dist/broadlink-0.1-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing broadlink-0.1-py2.7.egg
removing '/usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg' (and everything under it)
creating /usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg
Extracting broadlink-0.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
broadlink 0.1 is already the active version in easy-install.pth
Installed /usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg
Processing dependencies for broadlink==0.1
Finished processing dependencies for broadlink==0.1
Dependency file is empty
/usr/local/lib/python2.7/dist-packages/broadlink-0.1-py2.7.egg/EGG-INFO/dependency_links.txt
l0gic
Post by l0gic »
your broadlink looks like it has installed fine.
I'm guessing your issue is
You need to replace <your RM3 IP address> with the IP address of the broadlink unit and the same with the mac for <your RM3 mac>.
For the mac, remove the : e.g. aa:bb:cc:dd:ee:ff becomes aabbccddeeff
HTH Kevin
Non credus crepitus
tuspam
Post by tuspam »
l0gic wrote:Hi,
HTH Kevin
Thx Kevin
Too many choices - any details how exactly?
device = broadlink.rm(host=("<192.168.1.110>",80), mac=bytearray.fromhex("<aabbccddeeff>"))
device = broadlink.rm(host=("192.168.1.110",80), mac=bytearray.fromhex("aabbccddeeff"))
device = broadlink.rm(host=(192.168.1.110,80), mac=bytearray.fromhex(aabbccddeeff))
device = broadlink.rm(host=(192.168.001.110,80), mac=bytearray.fromhex("<aabbccddeeff>"))
etc.
    device = broadlink.rm(host=(192.168.1.110,80), mac=bytearray.fromhex(B4430DEEE880))
SyntaxError: invalid syntax
    device = broadlink.rm(host=(192168001110,80), mac=bytearray.fromhex(b4430deee880))
NameError: name 'b4430deee880' is not defined
l0gic
Post by l0gic »
device = broadlink.rm(host=("192.168.1.110",80), mac=bytearray.fromhex("B4430DEEE880"))
should do it for you, I've not got access to my Pi ATM so I can't check.
ATB
Kevin
Edit;
just checked and assuming your IP and MAC are correct then the syntax is good to go.
Non credus crepitus
tuspam
Post by tuspam »
l0gic wrote:Hi,
Bingo - thanks a lot
Edit:
Everything works like a charm with RM2 and RM mini (without android device).
I got about 2 sec delay between click dummy switch on domoticz to RM action. Now i can control Broadlink via HA bridge using google home and amazon dot.
Thanks again.
noddy119
Domoticz version: 3.5837
Post by noddy119 »
Did you comment out (insert an # at the beginning of the line) the 'time.sleep' lines in playcode.py ?
Without these lines (for test purposes) the script runs quicker.... :P
tuspam
Post by tuspam »
About 1 sec delay - awesome
korniza
Domoticz version: V3.6028
Post by korniza »
I bought broadlink black bean.
Searching on web I found this https://github.com/davorf/BlackBeanControl
Does anyone is using any API for this device?
>>>> Google Home <<<<<
Justintime
Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
Post by Justintime »
tuspam wrote:
l0gic wrote:Hi,
Edit:
Thanks again.
Just to be clear? The black bean works without interference of an Android device? Or only in combination with the RM2
So who is going to write a wiki? Because the information is not clear how to handle all this.
tuspam
Post by tuspam »
Justintime wrote:
tuspam wrote:
l0gic wrote:Hi,
Edit:
Thanks again.
Yes RM2 and RM mini (black bean) working without android device. I got 2 of them in different rooms.
Ps
In raspberry pi i have installed domoticz, ha-bridge, and python-broadlink - i can control all my devices via voice (Google Home in one room and Alexa in another)
Justintime
Re: RE: Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
tuspam wrote:
Justintime wrote:
Edit:
Thanks again.
Ps
Thanks... Cool that it works with Alexa etc.
But i am still looking for the Holy grail on IR support in Domoticz.
With one device independent from an Android device.
tuspam
Post by tuspam »
Justintime wrote:......
So, You find one.
Justintime
Re: RE: Re: RE: Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
So, You find one.
So i just need a rm2 than?
tuspam
Post by tuspam »
So, You find one.
YES rm2 or black bean.
